You can connect to your Arrow Flight SQL data from Power BI via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Arrow Flight SQL
  • Working with Arrow Flight SQL data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Arrow Flight SQL.
  1. Visit Arrow Flight SQL website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using Arrow Flight SQL ODBC Driver
To get data from Arrow Flight SQL using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Arrow Flight SQL.
    User and password
    1. Note the Flight SQL host and port (Dremio often uses 32010; other servers differ). Default encryption is on.
    2. Create a database user on the Flight SQL server. Paste user and password.
    3. If the Bridge JVM is Java 16 or newer, add --add-opens=java.base/java.nio=ALL-UNNAMED to the JDBC Bridge JVM options when Arrow reports module-access errors.
    4. After Finish, replace host and port. Set useEncryption=false only for a local plaintext lab.
    3. Finally, hit OK button:
    • Connection string: jdbc:arrow-flight-sql://[$HostName$]:[$Port$]
    • Driver class: org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar
    • Host: MyHostName
    • TCP port: 32010
    • User name:
    • Password:
    • Use encryption: true
    ArrowFlightSqlDSN
    optional for Arrow Flight SQL
    Find full details in the Arrow Flight SQL Connector authentication reference.
    Token
    1. Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
    2. Paste the token into Token. Leave user/password empty unless the server requires both.
    3. Java 16+ may need --add-opens=java.base/java.nio=ALL-UNNAMED on the Bridge JVM.
    4. After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
    • Host: MyHostName
    • TCP port: 32010
    • Token:
    ArrowFlightSqlDSN
    Jump to troubleshooter
    ArrowFlightSqlDSN
    SELECT * FROM information_schema.tables
Connect to Arrow Flight SQL data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ArrowFlightSqlDSN and continue:
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Arrow Flight SQL in a Power BI report:
If you wish to import Arrow Flight SQL data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ArrowFlightSqlDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Arrow Flight SQL ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ArrowFlightSqlDSN"}
    = Odbc.Query("dsn=ArrowFlightSqlDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Arrow Flight SQL data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Arrow Flight SQL Service
    SELECT * FROM OPENQUERY([LS_TO_ARROW_FLIGHT_SQL_IN_GATEWAY], 'SELECT * FROM information_schema.tables')
    DirectQuery option for Power BI (read Arrow Flight SQL data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Arrow Flight SQL data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Arrow Flight SQL
    Query any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:arrow-flight-sql://[$HostName$]:[$Port$]';ClassName='org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver';DriverPath='C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar';UserName='';UserPassword='';ConnParams='optional for Arrow Flight SQL'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
  6. Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g. C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Arrow Flight SQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Arrow Flight SQL data source in the gateway
    ArrowFlightSqlDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Arrow Flight SQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
  5. Then set the default database property to ArrowFlightSqlDSN (the one we used in the Data Gateway):
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
Finally, we are ready to read data from Arrow Flight SQL in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Arrow Flight SQL data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Arrow Flight SQL in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
