You can connect to your Arrow Flight SQL data from SAP Crystal Reports via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  1. Visit Arrow Flight SQL website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using Arrow Flight SQL ODBC Driver
Watch this quick walkthrough to see how to configure your Arrow Flight SQL ODBC data source, or scroll down for the step-by-step written guide.
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Arrow Flight SQL.
To get data from Arrow Flight SQL using SAP Crystal Reports, we first need to create an ODBC data source. We will later read this data in SAP Crystal Reports. Perform these steps:
    • Configure the authentication in Arrow Flight SQL.
    User and password
    1. Note the Flight SQL host and port (Dremio often uses 32010; other servers differ). Default encryption is on.
    2. Create a database user on the Flight SQL server. Paste user and password.
    3. If the Bridge JVM is Java 16 or newer, add --add-opens=java.base/java.nio=ALL-UNNAMED to the JDBC Bridge JVM options when Arrow reports module-access errors.
    4. After Finish, replace host and port. Set useEncryption=false only for a local plaintext lab.
    3. Finally, hit OK button:
    • Connection string: jdbc:arrow-flight-sql://[$HostName$]:[$Port$]
    • Driver class: org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar
    • Host: MyHostName
    • TCP port: 32010
    • User name:
    • Password:
    • Use encryption: true
    ArrowFlightSqlDSN
    optional for Arrow Flight SQL
    Find full details in the Arrow Flight SQL Connector authentication reference.
    Token
    1. Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
    2. Paste the token into Token. Leave user/password empty unless the server requires both.
    3. Java 16+ may need --add-opens=java.base/java.nio=ALL-UNNAMED on the Bridge JVM.
    4. After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
    • Host: MyHostName
    • TCP port: 32010
    • Token:
    ArrowFlightSqlDSN
    Jump to troubleshooter
    ArrowFlightSqlDSN
    SELECT * FROM information_schema.tables
Read data in SAP Crystal Reports from the ODBC data source
  1. First of all, open SAP Crystal Reports and create the new Crystal Report.
    Create New Crystal Report
  2. And it will open the new data source selection window. Under ODBC(RDO) double click on the Make New Connection and Select the desired ODBC DSN, in our case we need to select ArrowFlightSqlDSN which we created in upper section. And Click on Next.
    ArrowFlightSqlDSN
    SAP Crystal Report - Select ODBC ArrowFlightSqlDSN DSN
  3. Expand the Connection and under the data select the desired table(s) or view(s) and click Add > button and click on Next. The list also shows the custom views (virtual tables, named vt__...) you created in the ArrowFlightSqlDSN data source, so you can select a saved SQL query just like a table. To type a SQL query instead, double click Add Command under the connection.
    Tip: Save frequently used SQL queries as custom views on the Custom Objects tab of the ArrowFlightSqlDSN data source. Each view appears here as a separate object, so one DSN can serve many API endpoints (e.g. /restaurants, /users) and every report reuses the same query instead of keeping its own Add Command SQL. See ODBC Drivers Custom Objects feature.
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
    SAP Crystal Report - Add ODBC ArrowFlightSqlDSN DSN Tables
  4. Add the desired Fields to Display in the Reports. Here we are adding all fields and click on Finish.
    SAP Crystal Report - Add Display Fields
  5. That's it and you will be able to load the data in the Report.
    SAP Crystal Report - ArrowFlightSqlDSN Data Output
Add ArrowFlightSqlDSN data to an existing Crystal Report
The steps above use the new report wizard. To use the ArrowFlightSqlDSN data source in a report you already have, add it with the Database Expert:
  1. Open the report and go to Database > Database Expert...
  2. Under Available Data Sources expand Create New Connection > ODBC (RDO), select the ArrowFlightSqlDSN DSN, click Next and then Finish. If you used this DSN before, it is listed under My Connections instead.
  3. Expand the connection and select the table(s), custom view(s) (vt__...) or Add Command for a SQL query, then click the > button to move them to Selected Tables and click OK.
  4. If the report already has other tables, Crystal Reports opens the Links tab. Link the new object to the existing tables on a common column (or remove the suggested links if they are not related).
  5. Open View > Field Explorer, expand Database Fields and drag the new fields onto the report.
Point an existing table to the ArrowFlightSqlDSN data source
To switch a table the report already uses (e.g. one from another DSN) to an object of ArrowFlightSqlDSN without rebuilding the report, go to Database > Set Datasource Location..., select the table in Current Data Source, select the new table or custom view under the ArrowFlightSqlDSN connection in Replace with and click Update. Then run Database > Verify Database to refresh the field list.
Tip: Prefer a custom view over a long Add Command query: the SQL lives in the DSN, so many reports can reuse it, and Set Datasource Location handles a view like a regular table (a command is harder to repoint). See ODBC Drivers Custom Objects feature.
Using ZappySys Driver Custom Views and Stored Procedure in SAP Crystal Report
You can create parameterized Stored Procedure and Virtual Tables on the same Data Source (ODBC DSN or Data Gateway Data Source). Please refer to this article for the same. You can create procedures to encapsulate custom logic and then only pass handful parameters rather than long SQL to execute your API call.
Using Custom Views in the SAP Crystal Report
After establishing the connection with ArrowFlightSqlDSN Data Source you can use the custom view in SQL Crystal Report. Custom views are listed next to the regular tables, both in the new report wizard and in Database Expert of an existing report.
ArrowFlightSqlDSN
ArrowFlightSqlDSN
SAP Crystal Report - Custom Views
Using Custom Stored Procedure in the SAP Crystal Report
  1. First of all, create the custom stored procedure in the ZappySys Driver. Please refer to this article to create the custom stored procedure.
    ZappySys Driver Custom Stored Procedure
  2. After establishing the connection with ArrowFlightSqlDSN Data Source you can use the custom Stored Procedure in SQL Crystal Report. Same way you can write custom queries also in the query box.
    ArrowFlightSqlDSN
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
  6. Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g. C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Arrow Flight SQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in SAP Crystal Reports (client-side) to connect to it.
Create Arrow Flight SQL data source in the gateway
    ArrowFlightSqlDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Arrow Flight SQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZappySys JDBC Bridge Driver - Arrow Flight SQL
      Query any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from SAP Crystal Reports. To achieve that, let's perform these steps:
  5. Then set the default database property to ArrowFlightSqlDSN (the one we used in the Data Gateway):
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
Access data in SAP Crystal Reports via the gateway
Finally, we are ready to read data from Arrow Flight SQL in SAP Crystal Reports via the Data Gateway. Follow these final steps:
  1. Go back to SAP Crystal Reports.
  2. First of all, open SAP Crystal Reports and create the new Crystal Report.
  3. And it will open the new data source selection window. Under ODBC(RDO) double click on the Make New Connection and Select the desired ODBC DSN, in our case we need to select ZappySysGatewayDSN which we created in upper section. And Click on Next.
    SAP Crystal Report - Select ODBC ZappySysGatewayDSN DSN
  4. Read the data the same way we discussed at the beginning of this article.
  5. That's it!
Now you can connect to Arrow Flight SQL data in SAP Crystal Reports via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Arrow Flight SQL in SAP Crystal Reports and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
