You can connect to your Dropbox data from Power BI via the high-performance Dropbox ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Dropbox
  • Working with Dropbox data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Dropbox Connector.
Create data source using Dropbox ODBC Driver
To get data from Dropbox using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Dropbox" from the list of Popular Connectors. If "Dropbox" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    DropboxDSN
    Dropbox
    • Configure the authentication in Dropbox.
    User Account
    Dropbox authentication
    To use OAuth authentication, firstly, you need to create OAuth application:
    1. Log into your Dropbox account.
    2. Go to Dropbox My Apps.
    3. Then press Create app button to create a new app: My OAuth apps in Dropbox
    4. Once a new page opens, select Scoped access option: Create OAuth app to get Dropbox REST API data
    5. Next, select Full Dropbox to access all files and folders or App folder to access specific folder's files and folders option.
    6. Continue by giving your app a name.
    7. Then check I agree to Dropbox API Terms and Conditions checkbox.
    8. Click Create app button.
    9. Once a new page opens, click Enable additional teams and Enable additional users buttons: Configure OAuth app in Dropbox
    10. Then copy App key and App secret and copy paste them into your favorite text editor (you will need them later).
    11. Proceed by setting a Redirect URI and clicking Add button.
      NOTE: If you don't have a working Redirect URI, you can use https://zappysys.com/oauth (it's safe).
    12. Then click on Permissions tab and select application scopes: Set OAuth app permissions in Dropbox
    13. Select all Individual Scopes and Team Scopes if you want to manage team data.
    14. Click Submit button.
    15. Now go to SSIS package or ODBC data source and in User Account authentication set these parameters:
      1. For ClientId field use App key value.
      2. For ClientSecret field use App secret value.
      3. For ReturnUrl field use Redirect URI value.
    16. Done! Now you are ready to use Dropbox Connector!
    NOTE: If you are planning to use your current data connection/token for automated processes, we recommend that you use a generic account for token generation when the login box appears (e.g. sales_automation@mycompany.com instead of bob_smith@mycompany.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will fail. Another potentially unwanted effect of using a personal token is incorrect logging; the API calls (e.g. Read, Edit, Delete, Upload) made with that token will record the specific user as performing the calls instead of an automated process.
    1. Set Authentication Type to User Account [OAuth]
    DropboxDSN
    Dropbox
    https://api.dropboxapi.com/2/
    UseCustomApp Fill-in the parameter...
    ClientId
    ClientSecret
    Scope
    Find full details in the Dropbox Connector authentication reference.
    ZappySys API Driver - Dropbox
    Read and write Dropbox data effortlessly. Integrate, manage, and automate files and folders — almost no coding required.
    DropboxDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Dropbox. Hit OK button to use this query in the next step.
    SELECT *
    FROM list_folder
    Some parameters configured in this window will be passed to the Dropbox API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    DropboxDSN
    SELECT *
    FROM list_folder
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Dropbox API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Dropbox servers).
Connect to Dropbox data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose DropboxDSN and continue:
    DropboxDSN
    DropboxDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Dropbox in a Power BI report:
If you wish to import Dropbox data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
DropboxDSN
SELECT *
FROM list_folder
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Dropbox ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=DropboxDSN"}
    dsn=DropboxDSN
    dsn=DropboxDSN
    = Odbc.Query("dsn=DropboxDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Dropbox data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Dropbox Service
    SELECT * FROM OPENQUERY([LS_TO_DROPBOX_IN_GATEWAY], 'SELECT * FROM list_folder')
    DirectQuery option for Power BI (read Dropbox data example using SQL Server Linked Server and ZappySys Data Gateway)
    FROM list_folder')
  7. Click OK and load the data. Your Dropbox data is now linked live rather than imported.
    DropboxDSN
    DropboxDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://api.dropboxapi.com/2/;Provider=DropBox;AuthorizeInFullBrowser=True;ExtraAttributesForAuthRequest=token_access_type=offline;ScopeSeparator={space};ReturnUrl=[$ReturnUrl$]
Dropbox Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Dropbox operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Dropbox data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Dropbox data source in the gateway
In this section we will create a data source for Dropbox in the Data Gateway. Let's follow these steps to accomplish that:
    DropboxDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Dropbox ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      DropboxDSN
      DropboxDSN
      DropboxDSN
  5. Then set the default database property to DropboxDSN (the one we used in the Data Gateway):
    DropboxDSN
    DropboxDSN
Finally, we are ready to read data from Dropbox in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Dropbox data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Dropbox in Power BI and integrate your data — all without writing complex code.
