You can connect to your Salesforce Data Cloud (Data 360) data from Power BI via the high-performance Salesforce Data Cloud (Data 360) ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Salesforce Data Cloud (Data 360)
- Working with Salesforce Data Cloud (Data 360) data directly inside Power BI
Download Salesforce Data Cloud (Data 360) JDBC driver
To connect to Salesforce Data Cloud (Data 360), you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Salesforce Data Cloud (Data 360) website or MVN Repository.
C:\ZappySys\Jdbc\Salesforce Data Cloud (Data 360)\jdbc-0.29.0-shaded.jar.
Create data source using Salesforce Data Cloud (Data 360) ODBC Driver
To get data from Salesforce Data Cloud (Data 360) using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Salesforce Data Cloud (Data 360).
Production (login.salesforce.com)
Salesforce Data Cloud (Data 360) authentication
Follow these steps to create a Salesforce External Client App (or a legacy Connected App) so the Data Cloud JDBC driver can authenticate. JDBC Bridge then exposes Data Cloud SQL to Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
WARNING: As of 21 Feb 2026 Salesforce no longer lets you create new Connected Apps. Use an External Client App. If you already have a Connected App, you can keep using it with username/password + consumer key/secret. Do not use a personal employee login for unattended jobs (Power BI refresh, Linked Server, ADF). Use a dedicated integration user.- Sign in to Salesforce Setup as an administrator.
- Go to App Manager (or External Client Apps) and create a new External Client App / Connected App. Enable OAuth Settings.
Callback URL (Redirect URI) must be exactly:
https://zappysys.com/oauthINFO: Use this ZappySys capture page so the authorizationcodeappears in the page title and URL during the 3-legged dance. Do not use localhost, a Salesforce "try it" page, or any other URL -- those often redirect again or drop the query string, so the code is not visible. - Select OAuth scopes your org requires for Data Cloud query (typically includes Data Cloud / CDP query and API access). Save.
- Open Manage Consumer Details and copy Consumer Key (Client ID) and Consumer Secret (Client Secret).
- Paste username, password (plus security token if your org requires it), Client ID, and Client Secret into this Auth profile.
- If you complete a browser authorization, wait until the browser lands on
https://zappysys.com/oauthand thecodeis in the title or address bar. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:salesforce-datacloud://[$LoginHost$] -
Driver class :com.salesforce.datacloud.jdbc.DataCloudJDBCDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Salesforce Data Cloud (Data 360)\jdbc-0.29.0-shaded.jar -
Login host :login.salesforce.com -
User name : -
Password : -
Client ID (Consumer Key) : -
Client Secret (Consumer Secret) : -
Data space :default
SalesforceDataCloudData360DSNjdbc:salesforce-datacloud://[$LoginHost$]com.salesforce.datacloud.jdbc.DataCloudJDBCDriverC:\ZappySys\Jdbc\Salesforce Data Cloud (Data 360)\jdbc-0.29.0-shaded.jaroptional for Salesforce Data Cloud (Data 360)
Find full details in the Salesforce Data Cloud (Data 360) Connector authentication reference.Sandbox (test.salesforce.com)
Login host :test.salesforce.com -
User name : -
Password : -
Data space :default
Find full details in the Salesforce Data Cloud (Data 360) Connector authentication reference.JWT Bearer (External Client App)
JWT Bearer Flow with an External Client App (current Salesforce recommendation for JDBC). No refresh-token dance; you still register the callback URL so the app is valid.
- Create an External Client App in Salesforce Setup. Enable OAuth and JWT Bearer.
- Callback URL must be exactly
https://zappysys.com/oauth(do not use localhost or another capture URL). - Upload or generate a certificate. Download the private key as PEM (
-----BEGIN PRIVATE KEY-----). - Copy the Consumer Key (Client ID).
- Paste Client ID, integration username, and the full PEM into this profile. Do not check a private key into source control.
User name : -
Private key (PEM) : -
Data space :default
SalesforceDataCloudData360DSNjdbc:salesforce-datacloud://[$LoginHost$]com.salesforce.datacloud.jdbc.DataCloudJDBCDriverC:\ZappySys\Jdbc\Salesforce Data Cloud (Data 360)\jdbc-0.29.0-shaded.jaroptional for Salesforce Data Cloud (Data 360)optional for Salesforce Data Cloud (Data 360)
Find full details in the Salesforce Data Cloud (Data 360) Connector authentication reference. -
SalesforceDataCloudData360DSNSHOW TABLES
SHOW TABLESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Salesforce Data Cloud (Data 360) data in Power BI
Another window opens and asks to select a Data Source we already created. Choose SalesforceDataCloudData360DSN and continue:
Finally, finally, read extracted data from Salesforce Data Cloud (Data 360) in a Power BI report:
If you wish to import Salesforce Data Cloud (Data 360) data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
SHOW TABLES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Salesforce Data Cloud (Data 360) ODBC data source:
ODBC{"connectionstring":"dsn=SalesforceDataCloudData360DSN"}
= Odbc.Query("dsn=SalesforceDataCloudData360DSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Salesforce Data Cloud (Data 360) data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_SALESFORCE_DATA_CLOUD_DATA_360_IN_GATEWAY], 'SHOW TABLES')
SELECT * FROM OPENQUERY([LS_TO_SALESFORCE_DATA_CLOUD_DATA_360_IN_GATEWAY], 'SHOW TABLES') - Click OK and load the data. Your Salesforce Data Cloud (Data 360) data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Salesforce Data Cloud (Data 360)Read Salesforce Data Cloud (Data 360) with SQL. Query data graphs and lake objects from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.SalesforceDataCloudData360DSN
SalesforceDataCloudData360DSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:salesforce-datacloud://[$LoginHost$]';ClassName='com.salesforce.datacloud.jdbc.DataCloudJDBCDriver';DriverPath='C:\ZappySys\Jdbc\Salesforce Data Cloud (Data 360)\jdbc-0.29.0-shaded.jar';UserName='';UserPassword='';ConnParams='optional for Salesforce Data Cloud (Data 360)'
Open DBeaver.
com.salesforce.datacloud.jdbc.DataCloudJDBCDriver):
Go to the Libraries tab, click Add File, and select your Salesforce Data Cloud (Data 360) driver library file(s), e.g.
C:\ZappySys\Jdbc\Salesforce Data Cloud (Data 360)\jdbc-0.29.0-shaded.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:salesforce-datacloud://[$LoginHost$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Salesforce Data Cloud (Data 360) data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Salesforce Data Cloud (Data 360) data source in the gateway
In this section we will create a data source for Salesforce Data Cloud (Data 360) in the Data Gateway. Let's follow these steps to accomplish that:
SalesforceDataCloudData360DSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Salesforce Data Cloud (Data 360) ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Salesforce Data Cloud (Data 360)Read Salesforce Data Cloud (Data 360) with SQL. Query data graphs and lake objects from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.SalesforceDataCloudData360DSN
SalesforceDataCloudData360DSN(the one we used in the Data Gateway):SalesforceDataCloudData360DSNSalesforceDataCloudData360DSN
Finally, we are ready to read data from Salesforce Data Cloud (Data 360) in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Salesforce Data Cloud (Data 360) data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Salesforce Data Cloud (Data 360) in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Salesforce Data Cloud (Data 360), but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
