You can connect to your ElasticSearch data from Power BI via the high-performance ElasticSearch ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to ElasticSearch
- Working with ElasticSearch data directly inside Power BI
Create data source using ElasticSearch ODBC Driver
To get data from ElasticSearch using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "ElasticSearch" from the list of Popular Connectors. If "ElasticSearch" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ElasticsearchDSNElasticSearch
- Configure the authentication in ElasticSearch.
Basic Authentication (UserId/Password)
ElasticSearch authentication
Use HTTP Basic Authentication with any Elasticsearch-compatible cluster (self-hosted, Elastic Cloud, OpenSearch, or other managed hosts).
- Set Service URL to your cluster base URL (for example
https://your-host:9200or the HTTPS URL from your provider). - Enter User Name and Password for a user that can call the Elasticsearch REST API. Some managed hosts label these as Access Key / Access Secret — use those values in the same fields.
- If you use a self-signed certificate and see a trust error, set Ignore certificate related errors to True (only if you trust the server).
- Click Test connection.
Optional — Bonsai example: On Bonsai, open
https://app.bonsai.io/clusters/{your-instance-id}/tokens, copy Access Key and Access Secret into User Name and Password, then test. Sample data (if needed):https://{your-cluster-id}.apps.bonsaisearch.net/app/home#/tutorial_directory.API Connection Manager configuration
Basic Authentication (UserId/Password) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ElasticsearchDSNElasticSearchBasic Authentication (UserId/Password) [Http]http://localhost:9200Optional Parameters User Name (or Access Key) Password (or Access Secret) Ignore certificate related errors
Find full details in the ElasticSearch Connector authentication reference.Windows Authentication (No Password)
No instructions available.
Windows Authentication (No Password) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ElasticsearchDSNElasticSearchWindows Authentication (No Password) [Http]http://localhost:9200Optional Parameters Ignore certificate related errors
Find full details in the ElasticSearch Connector authentication reference. -
ZappySys API Driver - ElasticSearchRead and write Elasticsearch data effortlessly. Integrate, manage, and automate indexes and documents — almost no coding required.ElasticsearchDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from ElasticSearch. Hit OK button to use this query in the next step.
SELECT * FROM Indexes
Some parameters configured in this window will be passed to the ElasticSearch API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - ElasticSearchRead and write Elasticsearch data effortlessly. Integrate, manage, and automate indexes and documents — almost no coding required.ElasticsearchDSNSELECT * FROM Indexes
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the ElasticSearch API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ElasticSearch servers). -
Connect to ElasticSearch data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ElasticsearchDSN and continue:
ElasticsearchDSN
ElasticsearchDSN
Finally, finally, read extracted data from ElasticSearch in a Power BI report:
If you wish to import ElasticSearch data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local ElasticSearch ODBC data source:
ODBC{"connectionstring":"dsn=ElasticsearchDSN"}
= Odbc.Query("dsn=ElasticsearchDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports ElasticSearch data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_ELASTICSEARCH_IN_GATEWAY], 'SELECT * FROM Indexes')
SELECT * FROM OPENQUERY([LS_TO_ELASTICSEARCH_IN_GATEWAY], 'SELECT * FROM Indexes') - Click OK and load the data. Your ElasticSearch data is now linked live rather than imported.
ElasticsearchDSNDRIVER={ZappySys API Driver};ServiceUrl=http://localhost:9200;UserName=[$UserName$];Password=[$Password$]
ElasticSearch Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential ElasticSearch operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Create Index
- Delete Index
- List indexes
- List aliases
- Get Index or Alias metadata
- Get documents from Index or Alias
- Get document by ID from Index or Alias
- Search / Query documents
- Count documents
- Insert documents
- Upsert documents
- Update documents
- Delete documents
In some situations, you may need to provide ElasticSearch data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create ElasticSearch data source in the gateway
In this section we will create a data source for ElasticSearch in the Data Gateway. Let's follow these steps to accomplish that:
ElasticsearchDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the ElasticSearch ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ElasticsearchDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - ElasticSearchRead and write Elasticsearch data effortlessly. Integrate, manage, and automate indexes and documents — almost no coding required.ElasticsearchDSN
ElasticsearchDSN(the one we used in the Data Gateway):ElasticsearchDSNElasticsearchDSN
Finally, we are ready to read data from ElasticSearch in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to ElasticSearch data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to ElasticSearch in Power BI and integrate your data — all without writing complex code.
