You can connect to your Shopify data from Power BI via the high-performance Shopify ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Shopify
  • Working with Shopify data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Shopify Connector.
Create data source using Shopify ODBC Driver
To get data from Shopify using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Shopify" from the list of Popular Connectors. If "Shopify" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ShopifyDSN
    Shopify
    • Configure the authentication in Shopify.
    Shopify authentication
    Quick Setup Summary:
    • Log in to your Shopify Admin and click Settings (the gear icon in the bottom left).
    • Select Apps from the left-side settings menu.
    • Click the Develop apps button at the top right of the page.
    • Open your app (or create a new one) and configure the necessary Admin API access scopes.
    • Click Install app. Once installed, navigate to the API credentials tab.
    1. Visit https://accounts.shopify.com and log into your Shopify store account.
    2. After logging in, select the store you wish to connect to.
    3. Select Settings (gear icon in the lower-left corner) to launch the Settings screen.
    4. On the left menu panel, select Apps. (Note: Sales channels are now managed in a separate menu item).
    5. On the Apps page, select Develop apps (near the top right of the screen).
      Note: If this is your first time accessing this section, you may need to click "Allow custom app development" to proceed.
    6. On the App development screen, select Create an app.
    7. Give the app a name (e.g., "ZappySys Connector"), select the appropriate developer from the drop-down, and select Create app.
    8. Click Configure Admin API scopes.
    9. In the Admin API access scopes screen, select the checkboxes based on which features you plan to use:
      • For Customers: read_customers, write_customers
      • For Orders: read_orders, write_orders
      • For Products: read_products, write_products
      • For Inventory: read_inventory, write_inventory
      • For Locations: read_locations
      • For Payouts/Analytics: read_all_orders or read_analytics
    10. After selecting your scopes, click Save at the top or bottom of the page.
    11. Install the app by clicking the Install app button (upper-right corner). If prompted, confirm by selecting Install.
    1. Once the app is installed, you will be taken to the API credentials tab.
    2. Look for the Admin API access token section. Select Reveal token once to show the token (it starts with shpat_).
    3. IMPORTANT: Copy and save this token immediately in a secure location. You cannot view it again after leaving this page.
      Reveal Token Screenshot
    1. Open the ZappySys connector configuration screen.
    2. Enter Subdomain: Enter the unique subdomain of your Shopify store into the Subdomain parameter textbox.
      How to find your Subdomain:
      If you use a custom domain (e.g., www.my-store.com), you must still use your internal Shopify subdomain:
      • Method 1 (Admin URL): While logged into Shopify, check your browser address bar.
        • If the URL is admin.shopify.com/store/my-unique-slug, your subdomain is my-unique-slug.
        • If the URL is my-unique-slug.myshopify.com/admin, your subdomain is my-unique-slug.
      • Method 2 (Domains Setting): Go to Settings > Domains. Look for the "Primary domain for the online store" or the fallback domain ending in .myshopify.com. The part before the dots is your subdomain.
    3. Enter Access Token: Paste the shpat_xxx token you saved in Step 14 into the Admin API Access Token textbox.
      Tip: Click the ellipses (...) button inside the textbox to open a larger dialog for easier pasting.
    4. Click Test Connection to verify the settings.
    5. If the test is successful, click OK to save the configuration.
    1. Set Authentication Type to Admin Access Token (Custom App) [Http]
    ShopifyDSN
    Shopify
    https://[$Subdomain$].myshopify.com/admin/api/2026-10
    Sub-domain Fill-in the parameter...
    Admin API Access Token Fill-in the parameter...
    Find full details in the Shopify Connector authentication reference.
    OAuth Authorization Code Grant (3-legged) - RECOMMENDED
    1. Log in to the Shopify Dev Dashboard using your Partner account.
    2. Click Apps in the left menu, then click Create app.
    3. Select Start from Dev Dashboard (manual setup) and give your app a name.
    4. Step 1: Configure Scopes and URLs via "Versions"
      • Click the Versions tab at the top of the app screen.
      • Click Create version (or edit the Draft).
      • In the URLs section, enter https://zappysys.com/oauth into Allowed redirection URL(s).
      • Select your Admin API scopes based on which features you plan to use:
      • Click Release (top right). Note: Settings only become active once a version is Released.
    5. Step 2: Set Distribution Method
      • Click Distribution in the left-side menu.
      • Select Custom Distribution.
      • Enter your Shopify store URL (e.g., your-store.myshopify.com) and click Generate link.
      • Action Required: Copy the generated install link, open it in your browser, and follow the prompts to install/unlock the app for your store. You must complete this step before testing the connection in ZappySys.
    1. Click on Settings in the left-side navigation of your app.
    2. In the Client credentials section, copy the Client ID and Client Secret (click the eye icon to reveal).
    1. Open the ZappySys connector and select OAuth Authorization Code Grant (3-legged).
    2. Subdomain: Enter your store handle (the part before .myshopify.com).
    3. Client ID / Secret: Paste the credentials from Steps 6 and 7.
    4. Redirect URI: Enter https://zappysys.com/oauth.
    5. Click Test Connection. You will be prompted to authorize the app in your browser.
    Note on Tokens: Successful authorization generates an "Offline" Access Token (starting with shpca_). This token does not expire and does not require a refresh token.
    Troubleshooting: If you see "App no longer available," ensure you have completed the Distribution step and followed the Install Link in Step 5 to unlock the app for your store.
    1. Set Authentication Type to OAuth Authorization Code Grant (3-legged) - RECOMMENDED [OAuth]
    ShopifyDSN
    Shopify
    Redirect URI (***Must match App Settings***) Fill-in the parameter...
    ZappySys API Driver - Shopify
    Read and write Shopify data effortlessly. Integrate, manage, and automate customers, orders, products, and inventory — almost no coding required.
    ShopifyDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Shopify. Hit OK button to use this query in the next step.
    SELECT * FROM Products
    Some parameters configured in this window will be passed to the Shopify API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    ShopifyDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Shopify API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Shopify servers).
Connect to Shopify data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ShopifyDSN and continue:
    ShopifyDSN
    ShopifyDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Shopify in a Power BI report:
If you wish to import Shopify data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ShopifyDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Shopify ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ShopifyDSN"}
    dsn=ShopifyDSN
    dsn=ShopifyDSN
    = Odbc.Query("dsn=ShopifyDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Shopify data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Shopify Service
    SELECT * FROM OPENQUERY([LS_TO_SHOPIFY_IN_GATEWAY], 'SELECT * FROM Products')
    DirectQuery option for Power BI (read Shopify data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Shopify data is now linked live rather than imported.
    ShopifyDSN
    ShopifyDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://[$Subdomain$].myshopify.com/admin/api/2026-10;CredentialType=Token;AuthScheme={none};TokenAuthHeader=X-Shopify-Access-Token;
Shopify Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Shopify operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Shopify data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Shopify data source in the gateway
In this section we will create a data source for Shopify in the Data Gateway. Let's follow these steps to accomplish that:
    ShopifyDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Shopify ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ShopifyDSN
      ShopifyDSN
      ShopifyDSN
  5. Then set the default database property to ShopifyDSN (the one we used in the Data Gateway):
    ShopifyDSN
    ShopifyDSN
Finally, we are ready to read data from Shopify in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Shopify data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Shopify in Power BI and integrate your data — all without writing complex code.
