You can connect to your Azure Blob JSON File data from Power BI via the high-performance Azure Blob JSON File ODBC Driver. We'll walk you through the entire setup.
Create data source using Azure Blob JSON File ODBC Driver
To get data from Azure Blob JSON File using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  3. Create a User data source (User DSN) based on the ZappySys Azure Blob JSON Driver driver:
    Create new User DSN for ZappySys Azure Blob JSON Driver
  4. Create and configure a connection for the Azure Blob storage account.
    Create Azure Blob Storage Connection
  5. You can use select your desired single file by clicking [...] path button.
    mybucket/dbo.tblNames.json
    dbo.tblNames.json
    Read Azure Blob JSON File data
    ----------OR----------
    You can also read the multiple files stored in Azure Blob Storage using wildcard pattern supported e.g. dbo.tblNames*.json.
    Note: If you want to operation with multiple files then use wild card pattern as below
    (when you use wild card pattern in source path then system will treat target path as folder regardless you end with slash)
    mybucket/dbo.tblNames.json (will read only single .JSON file)
    mybucket/dbo.tbl*.json (all files starting with file name)
    mybucket/*.json (all files with .json Extension and located under folder subfolder)
    mybucket/dbo.tblNames*.json
    Use wildcard pattern .* to read multiple Azure Blob Files data
    You can also read the zip and gzip compressed files also without extracting it in using Azure Blob JSON Source File Task.
    mybucket/dbo.tblNames*.gz
    Reading zip and gzip compressed files (stream mode)
  6. Now select/enter Path expression in Path textbox to extract only specific part of JSON string as below ($.value[*] will get content of value attribute from JSON document. Value attribute is array of JSON documents so we have to use [*] to indicate we want all records of that array)
    NOTE: Here, We are using our desired filter, but you need to select your desired filter based on your requirement.
    Go to Preview Tab.
    Azure Blob JSON Driver Select Filter
  7. Navigate to the Preview Tab and let's explore the different modes available to access the data.
    1. --- Using Direct Query ---
      Click on Preview Tab, Select Table from Tables Dropdown and select [value] and click Preview.
      ZappySys ODBC Driver - Preview Data
    2. --- Using Stored Procedure ---
      Note : For this you have to Save ODBC Driver configuration and then again reopen to configure same driver. For more information click here.
      Click on the Custom Objects Tab, Click on Add button and select Add Procedure and Enter an appropriate name and Click on OK button to create.
      ZappySys ODBC Driver - Custom Objects
      1. --- Without Parameters ---
        Now Stored Procedure can be created with or without parameters (see example below). If you use parameters then Set default value otherwise it may fail to compilation)
        ZappySys ODBC Driver : Without Parameters
      2. --- With Parameters ---
        Note : Here you can use Placeholder with Paramters in Stored Procedure. Example : SELECT * FROM $ WHERE OrderID = '<@OrderID, FUN_TRIM>' or CustId = '<@CustId>' and Total >= '<@Total>'
        ZappySys ODBC Driver : With Parameters
    3. --- Using Virtual Table ---
      ZappySys APi Drivers support flexible Query language so you can override Default Properties you configured on Data Source such as URL, Body. This way you don't have to create multiple Data Sources if you like to read data from multiple EndPoints. However not every application support supplying custom SQL to driver so you can only select Table from list returned from driver.
      Many applications like MS Access, Informatica Designer wont give you option to specify custom SQL when you import Objects. In such case Virtual Table is very useful. You can create many Virtual Tables on the same Data Source (e.g. If you have 50 Buckets with slight variations you can create virtual tables with just URL as Parameter setting).
      vt__Customers
      DataPath=mybucket_1/customers.json
      vt__Orders
      DataPath=mybucket_2/orders.json
      vt__Products
      DataPath=mybucket_3/products.json
      1. Click on the Custom Objects Tab, Click on Add button and select Add Table and Enter an appropriate name and Click on OK button to create.
      2. Once you see Query Builder Window on screen Configure it.
        ZappySys ODBC Driver - Custom Objects : Virtual Table Query Builder
      3. Click on Preview Tab, Select Virtual Table(prefix with vt__) from Tables Dropdown or write SQL query with Virtual Table name and click Preview.
        ZappySys ODBC Driver - Custom Objects : Virtual Table Query Execute
  8. Click OK to finish creating the data source
  9. That's it; we are done. In a few clicks we configured the to Read the Azure Blob JSON File data using ZappySys Azure Blob JSON File Connector
Connect to Azure Blob JSON File data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose AzureBlobJsonFileDSN and continue:
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Azure Blob JSON File in a Power BI report:
If you wish to import Azure Blob JSON File data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
                ProductID,
                ProductName,
                SupplierID,
                CategoryID,
                QuantityPerUnit,
                UnitPrice
            FROM _root_
            WHERE UnitPrice > 20
Be aware, that if you type an invalid SQL query, Power BI may try to import a table instead of importing data using a query. In SQL query, make sure you do not use $ as the table name, e.g., SELECT * FROM $. Use _root_ instead, e.g., SELECT * FROM _root_.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Azure Blob JSON File ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=AzureBlobJsonFileDSN"}
    = Odbc.Query("dsn=AzureBlobJsonFileDSN",
                            "SELECT * FROM _root_
                            WITH (SRC='http://my-api-provider.com/api/" & MyParameter & "/items')")
By default, Power BI imports Azure Blob JSON File data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Azure Blob JSON File Service
    SELECT * FROM OPENQUERY([LS_TO_AZURE_BLOB_JSON_FILE_IN_GATEWAY], 'SELECT * FROM Orders')
    DirectQuery option for Power BI (read Azure Blob JSON File data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Azure Blob JSON File data is now linked live rather than imported.
    ZappySys Azure Blob JSON Driver - Configuration [Version: 2.0.1.10418]
    ZappySys Azure Blob JSON Driver - Azure Blob JSON File
    Read and write JSON files in Azure Blob effortlessly. Streamline, manage, and automate JSON files in Blob containers for analytics, reporting, and data pipelines — almost no coding required.
    DRIVER={ZappySys Azure Blob JSON Driver};DataPath='my-container/file-*.json';AccountName='my-storage-account';AccountKey='my-account-key'
In some situations, you may need to provide Azure Blob JSON File data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Azure Blob JSON File data source in the gateway
In this section we will create a data source for Azure Blob JSON File in the Data Gateway. Let's follow these steps to accomplish that:
    • Then select Native - ZappySys Azure Blob JSON Driver
  4. When the ZappySys Azure Blob JSON Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Azure Blob JSON File ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
  5. Then set the default database property to AzureBlobJsonFileDSN (the one we used in the Data Gateway):
Finally, we are ready to read data from Azure Blob JSON File in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Azure Blob JSON File data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Azure Blob JSON File in Power BI and integrate your data — all without writing complex code.
