You can connect to your Zendesk data from Power BI via the high-performance Zendesk ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Zendesk
- Working with Zendesk data directly inside Power BI
Create data source using Zendesk ODBC Driver
To get data from Zendesk using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Zendesk" from the list of Popular Connectors. If "Zendesk" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZendeskDSNZendesk
- Configure the authentication in Zendesk.
Zendesk authentication
Recommended for unattended automation: This authentication method does not require an interactive user login and does not use a refresh token. When the access token expires, ZappySys automatically requests a new access token using the same Client ID and Client Secret.- Sign in to Zendesk as an administrator.
- Go to Admin Center > Apps and integrations > APIs > Zendesk API.
- Open the OAuth Clients section and create an OAuth client.
- Configure the OAuth client as a Confidential client.
- Enter a unique Client ID.
- Copy the generated Client Secret and store it securely.
- Configure the permissions/scopes required by your integration.
- In the ZappySys connection, enter your Zendesk Sub Domain, Client ID, Client Secret, and desired Permissions.
- Click Test Connection.
Security: Client Credentials should only be used in trusted server-side environments where the Client Secret can be stored securely. Do not expose the Client Secret in browser-side or client-side applications.The access token is associated with the Zendesk user linked to the OAuth client and inherits that user's permissions. For automated integrations, consider using a dedicated Zendesk service account with only the permissions required by the integration.No Redirect URL, browser login, authorization code, or refresh token is required for this authentication method.
OAuth - Client Credentials (Server-to-Server) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
ZendeskDSNZendeskOAuth - Client Credentials (Server-to-Server) [OAuth]https://[$Domain$].zendesk.com/api/v2Required Parameters Sub Domain (e.g. mycompany) Fill-in the parameter... OAuth Client ID Fill-in the parameter... OAuth Client Secret Fill-in the parameter... Permissions Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zendesk Connector authentication reference.OAuth - User Login (Interactive)
Configure the following Redirect URL for the OAuth client:
https://zappysys.com/oauth - In the ZappySys connection, enter your Zendesk Sub Domain, Client ID, Client Secret, and desired Permissions.
- Start the authorization process and sign in to Zendesk when the browser opens.
- Approve access when prompted.
Token renewal: Zendesk access tokens expire. ZappySys uses the OAuth refresh token to obtain new access tokens without requiring the user to sign in again. The latest refresh token must be stored securely because Zendesk rotates refresh tokens during renewal.If the refresh token expires, is revoked, or cannot be restored from the saved connection, the interactive Zendesk login process must be performed again.For unattended server-side integrations where you do not want to maintain a refresh token, consider OAuth - Client Credentials (Server-to-Server).
OAuth - User Login (Interactive) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
ZendeskDSNZendeskOAuth - User Login (Interactive) [OAuth]https://[$Domain$].zendesk.com/api/v2Required Parameters Sub Domain (e.g. mycompany) Fill-in the parameter... ClientId Fill-in the parameter... ClientSecret Fill-in the parameter... Permissions Fill-in the parameter... RedirectUrl Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zendesk Connector authentication reference.Token Authentication (Legacy)
Deprecated by Zendesk: Zendesk is removing API token authentication. Existing API tokens are scheduled to stop working on April 30, 2027. For new integrations, use OAuth instead.- Sign in to Zendesk as an administrator.
- Make sure Token access is enabled.
- Create or select an existing API token.
- Copy the generated token and store it securely.
- Enter your Zendesk Sub Domain.
- Enter your Zendesk User ID / Email.
- Paste the API token into the Token field.
Migration: For unattended ETL, scheduled jobs, and server-side integrations, use OAuth - Client Credentials (Server-to-Server).API Connection Manager configuration
Token Authentication (Legacy) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ZendeskDSNZendeskToken Authentication (Legacy) [Http]https://[$Domain$].zendesk.com/api/v2Required Parameters Sub Domain (e.g. mycompany) Fill-in the parameter... UserId Fill-in the parameter... Token Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zendesk Connector authentication reference.Basic Authentication (User ID + Password)
Important: This method cannot be used when two-factor authentication (2FA) is enabled for the Zendesk user. Password access to the API must also be enabled in Zendesk.- Sign in to Zendesk as an administrator.
- Make sure Password access is enabled.
For example, if your Zendesk URL is:
https://mycompany.zendesk.com, entermycompany. - Enter your Zendesk User ID / Email and Password.
Recommendation: For new integrations, OAuth is preferred over storing a user's password. For unattended server-side integrations, consider OAuth - Client Credentials (Server-to-Server).API Connection Manager configuration
Basic Authentication (User ID + Password) [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
ZendeskDSNZendeskBasic Authentication (User ID + Password) [Http]https://[$Domain$].zendesk.com/api/v2Required Parameters Sub Domain (e.g. mycompany) Fill-in the parameter... UserName (2FA Must be OFF) Fill-in the parameter... Password Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zendesk Connector authentication reference. -
ZappySys API Driver - ZendeskRead and write Zendesk data effortlessly. Manage tickets, users, and organizations — almost no coding required.ZendeskDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Zendesk. Hit OK button to use this query in the next step.
SELECT * FROM Tickets
Some parameters configured in this window will be passed to the Zendesk API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - ZendeskRead and write Zendesk data effortlessly. Manage tickets, users, and organizations — almost no coding required.ZendeskDSNSELECT * FROM Tickets
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zendesk API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zendesk servers). -
Connect to Zendesk data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ZendeskDSN and continue:
ZendeskDSN
ZendeskDSN
Finally, finally, read extracted data from Zendesk in a Power BI report:
If you wish to import Zendesk data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Zendesk ODBC data source:
ODBC{"connectionstring":"dsn=ZendeskDSN"}
dsn=ZendeskDSN
dsn=ZendeskDSN
= Odbc.Query("dsn=ZendeskDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Zendesk data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_ZENDESK_IN_GATEWAY], 'SELECT * FROM Tickets')
SELECT * FROM OPENQUERY([LS_TO_ZENDESK_IN_GATEWAY], 'SELECT * FROM Tickets') - Click OK and load the data. Your Zendesk data is now linked live rather than imported.
ZendeskDSNDRIVER={ZappySys API Driver};ServiceUrl=https://[$Domain$].zendesk.com/api/v2;Provider=Custom;OAuthVersion=OAuth2;GrantType=ClientCredentials;TokenUrl=https://[$Domain$].zendesk.com/oauth/tokens;ClientId=[$ClientId$];ClientSecret=[$ClientSecret$];Scope=[$Permissions$];ScopeSeparator={space};ContentType=application/json
Zendesk Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zendesk operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Read Tickets (All)
- Read Tickets (Incremental) changed after a specified date
- Read Users (Incremental) changed after a specified date
- Read Organizations (Incremental) changed after a specified date
- Read Ticket Events (Incremental) changed after a specified date
- Read Ticket Metric Events (Incremental) changed after a specified date
- Read Ticket(s) by ID
- Read User(s) by ID
- Read Organization(s) by ID
- Read Tickets for Organization
- Read Tickets for User (Requested)
- Read Tickets for User (CCed)
- Read Tickets for User (Assigned)
- Read Tickets (Recent)
- Read Tickets Count (All)
- Read Tickets Count (for Organization)
- Read Ticket Metrics
- Read Ticket Fields
- Read Ticket Forms
- Read Ticket Comments
- Read Ticket Attachments
- Read Ticket ActivityStream
- Read Ticket ActivityStream Details
- Search Records - WITH Sorting and Extra Columns (Max 1000 rows)
- Search Records - NO Sorting (Allows more than 1000 rows)
- Read Organization Count
- Read Organization Fields
- Read Tags
- Read Groups
- Read User Fields
- Read Current User Info
- Read Brands
- Read Views
- Read Macros
- Read Sessions
- Read User Sessions
- Read Requests
- Read Requests Search
- Read Attachment
- Delete Attachment
- Upload Attachment (Single file)
- Delete Upload Session
- Create Ticket (Single)
- Create Tickets (Bulk)
- Delete Tickets (Bulk)
- Update Tickets (Bulk)
- Update Ticket (Single)
- Delete Ticket
- Read Users (All)
- Read Organizations (All)
- Upsert Users (Bulk) - Create or Update
- Delete User
- Update User
- Create User
- Upsert User - Create or Update
- Delete Organization
- Update Organization
- Create Organization
- Upsert Organization - Create or Update
In some situations, you may need to provide Zendesk data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Zendesk data source in the gateway
In this section we will create a data source for Zendesk in the Data Gateway. Let's follow these steps to accomplish that:
ZendeskDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zendesk ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZendeskDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - ZendeskRead and write Zendesk data effortlessly. Manage tickets, users, and organizations — almost no coding required.ZendeskDSN
ZendeskDSN(the one we used in the Data Gateway):ZendeskDSNZendeskDSN
Finally, we are ready to read data from Zendesk in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Zendesk data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Zendesk in Power BI and integrate your data — all without writing complex code.
