You can connect to your Power BI Service data from Power BI via the high-performance Power BI Service ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Power BI Service
- Working with Power BI Service data directly inside Power BI
Create data source using Power BI Service ODBC Driver
To get data from Power BI Service using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Power BI Service" from the list of Popular Connectors. If "Power BI Service" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
PowerBiServiceDSNPower BI Service
- Configure the authentication in Power BI Service.
User Credentials
Power BI Service authentication
WARNING: If you are planning to automate processes, we recommend that you use a Application Credentials authentication method. In case, you still need to use User Credentials, then make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.- Navigate to the Azure Portal and log in using your credentials.
- Access Microsoft Entra ID.
Register a new application by going to App registrations and clicking on New registration button:
Supported account type
- Use
- Use
Redirect URI:
- Set the type to
- Set the type to
Copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
In the Scope field use the default value or select individual scopes, e.g.:
offline_access -
https://analysis.windows.net/powerbi/api/Workspace.Read.All -
https://analysis.windows.net/powerbi/api/Dataset.Read.All -
https://analysis.windows.net/powerbi/api/Dataset.ReadWrite.All
- If tenant policy blocks user consent, an administrator must approve the requested delegated permissions.
- Optional step. Choose Default Workspace from the drop down menu.
- Choose Default Dataset from the drop down menu.
PowerBiServiceDSNPower BI ServiceUser Credentials [OAuth]https://api.powerbi.com/v1.0/myorgRequired Parameters Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Scope Fill-in the parameter... Default Dataset (select after generating tokens) Fill-in the parameter... Optional Parameters Client Secret Redirect URI (must match App Redirect URI) Default Workspace (Keep Empty for My Workspace - select after generating tokens) RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503 RetryCountMax 20 RetryWaitTimeMs 1000 RetryMultiplyWaitTime True Login options
Find full details in the Power BI Service Connector authentication reference. -
ZappySys API Driver - Power BI ServiceRead and write Microsoft Power BI data effortlessly. Access, refresh, and manage datasets, reports, and dashboards — almost no coding required.PowerBiServiceDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Power BI Service. Hit OK button to use this query in the next step.
SELECT * FROM Workspaces WHERE Id='aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee'
Some parameters configured in this window will be passed to the Power BI Service API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - Power BI ServiceRead and write Microsoft Power BI data effortlessly. Access, refresh, and manage datasets, reports, and dashboards — almost no coding required.PowerBiServiceDSNSELECT * FROM Workspaces WHERE Id='aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee'
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Power BI Service API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Power BI Service servers). -
Connect to Power BI Service data in Power BI
Another window opens and asks to select a Data Source we already created. Choose PowerBiServiceDSN and continue:
PowerBiServiceDSN
PowerBiServiceDSN
Finally, finally, read extracted data from Power BI Service in a Power BI report:
If you wish to import Power BI Service data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Power BI Service ODBC data source:
ODBC{"connectionstring":"dsn=PowerBiServiceDSN"}
= Odbc.Query("dsn=PowerBiServiceDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Power BI Service data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_POWER_BI_SERVICE_IN_GATEWAY], 'SELECT * FROM Workspaces WHERE Id=''aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee''')
SELECT * FROM OPENQUERY([LS_TO_POWER_BI_SERVICE_IN_GATEWAY], 'SELECT * FROM Workspaces WHERE Id=''aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee''') - Click OK and load the data. Your Power BI Service data is now linked live rather than imported.
PowerBiServiceDSNDRIVER={ZappySys API Driver};ServiceUrl=https://api.powerbi.com/v1.0/myorg;Provider=Custom;OAuthVersion=OAuth2;GrantType=Default;Scope=[$Scope$];ScopeSeparator={space};
Power BI Service Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Power BI Service operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Workspaces
- Get a Workspace
- Get Datasets
- Get a Dataset
- Create a Push Dataset
- Delete a Dataset
- Refresh a Dataset
- Get Tables
- Get Table Columns
- Get Table Rows
- Insert Rows into Push Dataset Table
- Truncate a Push Dataset Table
- Execute a DAX query
- Get Dataflows
- Refresh a Dataflow
In some situations, you may need to provide Power BI Service data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Power BI Service data source in the gateway
In this section we will create a data source for Power BI Service in the Data Gateway. Let's follow these steps to accomplish that:
PowerBiServiceDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Power BI Service ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
PowerBiServiceDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Power BI ServiceRead and write Microsoft Power BI data effortlessly. Access, refresh, and manage datasets, reports, and dashboards — almost no coding required.PowerBiServiceDSN
PowerBiServiceDSN(the one we used in the Data Gateway):PowerBiServiceDSNPowerBiServiceDSN
Finally, we are ready to read data from Power BI Service in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Power BI Service data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Power BI Service in Power BI and integrate your data — all without writing complex code.
