You can connect to your Arrow Flight SQL data from Excel via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Minimum required version: Java 11
Visit Arrow Flight SQL website or MVN Repository.
C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using Arrow Flight SQL ODBC Driver
Watch this quick walkthrough to see how to configure your Arrow Flight SQL ODBC data source, or scroll down for the step-by-step written guide.
To get data from Arrow Flight SQL using Excel, we first need to create an ODBC data source. We will later read this data in Excel. Perform these steps:
- Configure the authentication in Arrow Flight SQL.
User and password
- Note the Flight SQL host and port (Dremio often uses
32010; other servers differ). Default encryption is on. - Create a database user on the Flight SQL server. Paste user and password.
- If the Bridge JVM is Java 16 or newer, add
--add-opens=java.base/java.nio=ALL-UNNAMEDto the JDBC Bridge JVM options when Arrow reports module-access errors. - After Finish, replace host and port. Set
useEncryption=falseonly for a local plaintext lab. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:arrow-flight-sql://[$HostName$]:[$Port$] -
Driver class :org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar -
Host :MyHostName -
TCP port :32010 -
User name : -
Password : -
Use encryption :true
ArrowFlightSqlDSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jaroptional for Arrow Flight SQL
Find full details in the Arrow Flight SQL Connector authentication reference.Token
- Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
- Paste the token into Token. Leave user/password empty unless the server requires both.
- Java 16+ may need
--add-opens=java.base/java.nio=ALL-UNNAMEDon the Bridge JVM. - After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
Host :MyHostName -
TCP port :32010 -
Token : -
ArrowFlightSqlDSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jaroptional for Arrow Flight SQLoptional for Arrow Flight SQLoptional for Arrow Flight SQL
Find full details in the Arrow Flight SQL Connector authentication reference. -
ArrowFlightSqlDSNSELECT * FROM information_schema.tables
SELECT * FROM information_schema.tablesYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read data in Excel from the DSN
In Excel click Data, then select Get Data, proceed with From Other Sources and choose From ODBC item. This will get data from ODBC data source we created:
A small window opens, then simply select the data source you created in previous steps:
ArrowFlightSqlDSN
ArrowFlightSqlDSN
Finally, finally, use data extracted from Arrow Flight SQL API in an Excel worksheet:
Refresh data source in Excel
When data updates in Arrow Flight SQL, it is not automatically refreshed in Excel. To update the worksheet, go to Data or Table Design tab and click the Refresh button:
Open DBeaver.
org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g.
C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Arrow Flight SQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Excel (client-side) to connect to it.
Create Arrow Flight SQL data source in the gateway
ArrowFlightSqlDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Arrow Flight SQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZappySys JDBC Bridge Driver - Arrow Flight SQLQuery any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ArrowFlightSqlDSN
ArrowFlightSqlDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Arrow Flight SQLQuery any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ArrowFlightSqlDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Excel. To achieve that, let's perform these steps:
ArrowFlightSqlDSN(the one we used in the Data Gateway):ArrowFlightSqlDSNArrowFlightSqlDSN
Access data in Excel via the gateway
Finally, we are ready to read data from Arrow Flight SQL in Excel via the Data Gateway. Follow these final steps:
Go back to Excel.
Now you can connect to Arrow Flight SQL data in Excel via the ZappySys Data Gateway.
john and your password.
In this guide, we demonstrated how to connect to Arrow Flight SQL in Excel and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
