You can connect to your Apache Kylin data from Power BI via the high-performance Apache Kylin ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Apache Kylin
- Working with Apache Kylin data directly inside Power BI
Download Apache Kylin JDBC driver
To connect to Apache Kylin, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache Kylin website or MVN Repository.
C:\ZappySys\Jdbc\Apache Kylin\kylin-jdbc-5.0.4.jar.
Create data source using Apache Kylin ODBC Driver
To get data from Apache Kylin using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Apache Kylin.
Kylin connection
Apache Kylin authentication
Apache Kylin 5 JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. User and password are the Kylin REST user (the same account you use in the Kylin web UI), not a Hadoop principal unless you configured that.
- Note the Kylin query/REST host and HTTP port (default
7070) and the project name. - In the Kylin web UI create (or reuse) a user with query permission on that project. Paste user and password here. Do not use a personal employee login for unattended refresh.
- The wizard downloads
kylin-jdbc5.0.4 (shaded). After Finish, replace the host (e.g. MyHostName) and project in the JDBC URL. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:kylin://[$HostName$]:[$Port$]/[$Project$] -
Driver class :org.apache.kylin.jdbc.Driver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache Kylin\kylin-jdbc-5.0.4.jar -
Host :MyHostName -
TCP port :7070 -
Project :MyProject -
User name : -
Password :
ApacheKylinDSNjdbc:kylin://[$HostName$]:[$Port$]/[$Project$]org.apache.kylin.jdbc.DriverC:\ZappySys\Jdbc\Apache Kylin\kylin-jdbc-5.0.4.jaroptional for Apache Kylin
Find full details in the Apache Kylin Connector authentication reference.SSL
Kylin 5 JDBC over HTTPS. User and password remain the Kylin REST user.
- Use the HTTPS port of the Kylin server (often 443 or a custom TLS port). This Auth sets
ssl=true. - Create a Kylin REST user with query access to the project. Paste user and password.
- After Finish, replace host, port, and project. If the certificate is private, import it into the Java truststore used by JDBC Bridge.
Connection string :jdbc:kylin://[$HostName$]:[$Port$]/[$Project$]?ssl=[$Ssl$] -
Host :MyHostName -
TCP port :443 -
User name : -
Password : -
SSL :true
ApacheKylinDSNjdbc:kylin://[$HostName$]:[$Port$]/[$Project$]?ssl=[$Ssl$]org.apache.kylin.jdbc.DriverC:\ZappySys\Jdbc\Apache Kylin\kylin-jdbc-5.0.4.jaroptional for Apache Kylin
Find full details in the Apache Kylin Connector authentication reference. -
ApacheKylinDSNSELECT * FROM KYLIN_SALES LIMIT 100
SELECT * FROM KYLIN_SALES LIMIT 100You can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Apache Kylin data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ApacheKylinDSN and continue:
ApacheKylinDSN
ApacheKylinDSN
Finally, finally, read extracted data from Apache Kylin in a Power BI report:
If you wish to import Apache Kylin data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Kylin ODBC data source:
ODBC{"connectionstring":"dsn=ApacheKylinDSN"}
dsn=ApacheKylinDSN
dsn=ApacheKylinDSN
= Odbc.Query("dsn=ApacheKylinDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Apache Kylin data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_APACHE_KYLIN_IN_GATEWAY], 'SELECT * FROM KYLIN_SALES LIMIT 100')
SELECT * FROM OPENQUERY([LS_TO_APACHE_KYLIN_IN_GATEWAY], 'SELECT * FROM KYLIN_SALES LIMIT 100') - Click OK and load the data. Your Apache Kylin data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Apache KylinQuery Apache Kylin 5 cubes with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheKylinDSN
ApacheKylinDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:kylin://[$HostName$]:[$Port$]/[$Project$]';ClassName='org.apache.kylin.jdbc.Driver';DriverPath='C:\ZappySys\Jdbc\Apache Kylin\kylin-jdbc-5.0.4.jar';UserName='';UserPassword='';ConnParams='optional for Apache Kylin'
Open DBeaver.
org.apache.kylin.jdbc.Driver):
Go to the Libraries tab, click Add File, and select your Apache Kylin driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache Kylin\kylin-jdbc-5.0.4.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:kylin://[$HostName$]:[$Port$]/[$Project$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Apache Kylin data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Kylin data source in the gateway
In this section we will create a data source for Apache Kylin in the Data Gateway. Let's follow these steps to accomplish that:
ApacheKylinDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Kylin ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ApacheKylinDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Apache KylinQuery Apache Kylin 5 cubes with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheKylinDSN
ApacheKylinDSN(the one we used in the Data Gateway):ApacheKylinDSNApacheKylinDSN
Finally, we are ready to read data from Apache Kylin in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Apache Kylin data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Kylin in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Kylin, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
