You can connect to your InfluxDB 3 data from Power BI via the high-performance InfluxDB 3 ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to InfluxDB 3
- Working with InfluxDB 3 data directly inside Power BI
Minimum required version: Java 11
Download InfluxDB 3 JDBC driver
To connect to InfluxDB 3, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit InfluxDB 3 website or MVN Repository.
C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using InfluxDB 3 ODBC Driver
To get data from InfluxDB 3 using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in InfluxDB 3.
Flight SQL (token)
InfluxDB 3 authentication
InfluxDB 3 SQL is exposed over Arrow Flight SQL. Create an API token in the Influx console (same idea as a Stripe secret key).
- Log in to your InfluxDB 3 Cloud or Core/Enterprise UI.
- Open API Tokens (or
influx auth createon Core) and create a token with query permission on the database. - Copy the host (no
https://) and Flight/SQL port. Cloud often uses 443 with TLS. - Paste the token into Token. Set database name to your Influx database/bucket equivalent.
- Do not point the Flight URL at a random redirect; this is host:port of the Flight SQL endpoint, not an OAuth callback.
Connection string :jdbc:arrow-flight-sql://[$HostName$]:[$Port$]?useEncryption=true -
Driver class :org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar -
Host :MyHostName -
TCP port :443 -
Token : -
Database : -
Use encryption :true
Influxdb3DSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]?useEncryption=trueorg.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jaroptional for InfluxDB 3optional for InfluxDB 3optional for InfluxDB 3
Find full details in the InfluxDB 3 Connector authentication reference. -
Influxdb3DSNSELECT * FROM information_schema.tables
SELECT * FROM information_schema.tablesYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to InfluxDB 3 data in Power BI
Another window opens and asks to select a Data Source we already created. Choose Influxdb3DSN and continue:
Influxdb3DSN
Influxdb3DSN
Finally, finally, read extracted data from InfluxDB 3 in a Power BI report:
If you wish to import InfluxDB 3 data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local InfluxDB 3 ODBC data source:
ODBC{"connectionstring":"dsn=Influxdb3DSN"}
dsn=Influxdb3DSN
dsn=Influxdb3DSN
= Odbc.Query("dsn=Influxdb3DSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports InfluxDB 3 data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_INFLUXDB_3_IN_GATEWAY], 'SELECT * FROM information_schema.tables')
SELECT * FROM OPENQUERY([LS_TO_INFLUXDB_3_IN_GATEWAY], 'SELECT * FROM information_schema.tables') - Click OK and load the data. Your InfluxDB 3 data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - InfluxDB 3Query InfluxDB 3 with SQL over Arrow Flight JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.Influxdb3DSN
Influxdb3DSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:arrow-flight-sql://[$HostName$]:[$Port$]?useEncryption=true';ClassName='org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver';DriverPath='C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar';UserName='optional for InfluxDB 3';UserPassword='optional for InfluxDB 3';ConnParams='optional for InfluxDB 3'
Open DBeaver.
org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
Go to the Libraries tab, click Add File, and select your InfluxDB 3 driver library file(s), e.g.
C:\ZappySys\Jdbc\InfluxDB 3\flight-sql-jdbc-driver-19.0.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:arrow-flight-sql://[$HostName$]:[$Port$]?useEncryption=true), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide InfluxDB 3 data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create InfluxDB 3 data source in the gateway
In this section we will create a data source for InfluxDB 3 in the Data Gateway. Let's follow these steps to accomplish that:
Influxdb3DSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the InfluxDB 3 ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
Influxdb3DSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - InfluxDB 3Query InfluxDB 3 with SQL over Arrow Flight JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.Influxdb3DSN
Influxdb3DSN(the one we used in the Data Gateway):Influxdb3DSNInfluxdb3DSN
Finally, we are ready to read data from InfluxDB 3 in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to InfluxDB 3 data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to InfluxDB 3 in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to InfluxDB 3, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
