You can connect to your H2 data from Power BI via the high-performance H2 ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to H2
  • Working with H2 data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for H2.
Download H2 JDBC driver
To connect to H2, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit H2 website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\H2\h2-2.3.232.jar.
Create data source using H2 ODBC Driver
To get data from H2 using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in H2.
    In-memory
    H2 authentication
    H2 in-memory JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. No server to install. Data lives in the Java process for this DSN and is gone when the connection closes unless you add DB_CLOSE_DELAY=-1.
    2. Optional user/password: default lab user is often sa with empty password.
    3. Finally, hit OK button:
    • Connection string: jdbc:h2:mem:[$Database$]
    • Driver class: org.h2.Driver
    • JDBC driver file(s): C:\ZappySys\Jdbc\H2\h2-2.3.232.jar
    • Database name: MyDatabase
    • User name:
    • Password:
    H2DSN
    org.h2.Driver
    optional for H2
    Find full details in the H2 Connector authentication reference.
    Local file
    H2 authentication
    H2 file JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. The wizard downloads the H2 JAR into C:\ZappySys\Jdbc\H2. The database file is created next to it as h2db.mv.db.
    2. Point the URL at another folder after Finish if you already have an H2 file.
    3. Optional user/password (sa / empty is common for local files).
    • Connection string: jdbc:h2:file:C:\ZappySys\Jdbc\H2\h2db
    • User name:
    • Password:
    H2DSN
    org.h2.Driver
    optional for H2
    TCP server
    H2 authentication
    H2 TCP JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Start the H2 server (default TCP 9092) or connect to an existing one.
    2. Replace the host (e.g. MyHostName), port (e.g. 9092), and database path. Fill user and password from that server.
    • Connection string: jdbc:h2:tcp://[$HostName$]:[$Port$]/~/[$Database$]
    • Host: MyHostName
    • TCP port: 9092
    • User name:
    • Password:
    H2DSN
    org.h2.Driver
    optional for H2
    Jump to troubleshooter
    H2DSN
    SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'PUBLIC' ORDER BY TABLE_NAME
Connect to H2 data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose H2DSN and continue:
    H2DSN
    H2DSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from H2 in a Power BI report:
If you wish to import H2 data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
H2DSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local H2 ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=H2DSN"}
    dsn=H2DSN
    dsn=H2DSN
    = Odbc.Query("dsn=H2DSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports H2 data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from H2 Service
    SELECT * FROM OPENQUERY([LS_TO_H2_IN_GATEWAY], 'SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = ''PUBLIC'' ORDER BY TABLE_NAME')
    DirectQuery option for Power BI (read H2 data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your H2 data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - H2
    Read and write H2 embedded or TCP databases from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    H2DSN
    H2DSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:h2:mem:[$Database$]';ClassName='org.h2.Driver';DriverPath='C:\ZappySys\Jdbc\H2\h2-2.3.232.jar';UserName='';UserPassword='';ConnParams='optional for H2'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.h2.Driver):
    org.h2.Driver
  6. Go to the Libraries tab, click Add File, and select your H2 driver library file(s), e.g. C:\ZappySys\Jdbc\H2\h2-2.3.232.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:h2:mem:[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide H2 data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create H2 data source in the gateway
In this section we will create a data source for H2 in the Data Gateway. Let's follow these steps to accomplish that:
    H2DSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the H2 ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      H2DSN
      H2DSN
      H2DSN
  5. Then set the default database property to H2DSN (the one we used in the Data Gateway):
    H2DSN
    H2DSN
Finally, we are ready to read data from H2 in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to H2 data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to H2 in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to H2, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
