You can connect to your SharePoint Online data from Power BI via the high-performance SharePoint Online ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to SharePoint Online
- Working with SharePoint Online data directly inside Power BI
Create data source using SharePoint Online ODBC Driver
To get data from SharePoint Online using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "SharePoint Online" from the list of Popular Connectors. If "SharePoint Online" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
SharepointOnlineDSNSharePoint Online
- Configure the authentication in SharePoint Online.
User Credentials
SharePoint Online authentication
WARNING: If you are planning to automate processes, we recommend that you use a Application Credentials authentication method. In case, you still need to use User Credentials, then make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.- Navigate to the Azure Portal and log in using your credentials.
- Access Microsoft Entra ID.
Register a new application by going to App registrations and clicking on New registration button:
Supported account type
- Use
- Use
Redirect URI:
- Set the type to
- Set the type to
Copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
In the Scope field use the default or pick labeled permissions. Prefer
User.Read,Files.Read, orFiles.ReadWritewhen you want lower-impact, user-consent-friendly access; addSites.*.All/Files.*.Allonly when you need full site or file coverage (those often need an admin to approve the app for the organization).-
offline_access -
openid -
profile -
User.Read -
Sites.ReadWrite.All -
Files.ReadWrite.All
- Broad scopes such as
Sites.Read.All,Sites.ReadWrite.All,Files.Read.All, andFiles.ReadWrite.Allmay still require admin consent.
- Optional step. Choose Default Site Id from the drop down menu.
SharepointOnlineDSNSharePoint OnlineUser Credentials [OAuth]https://graph.microsoft.com/v1.0Required Parameters Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Permissions (Scope) Fill-in the parameter... Return URL Fill-in the parameter... Default Site Id (select after pressing 'Generate Token') Fill-in the parameter... Optional Parameters Client Secret Default Drive Id (select after pressing 'Generate Token') Login Prompt Option RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503|423 RetryCountMax 5 RetryMultiplyWaitTime True Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed) Extra Headers (e.g. Header1:AAA||Header2:BBB) IsAppCred 0
Find full details in the SharePoint Online Connector authentication reference.Application Credentials
Follow these simple steps to create Microsoft Entra ID application with application access permissions:
- Create an OAuth app
- Configure App Permissions
Grant granular permissions to the OAuth application (optional)
This step allows to grant OAuth application granular permissions, i.e. access configured specificSites,Lists, andList Items.Step-1: Create OAuth app
App registrations
- e.g. select
Accounts in this organizational directory onlyif you need access to data in your organization only.
- e.g. select
Redirect URI:
- Set the type to
Public client/native (mobile & desktop). - Leave the URL field empty.
- Set the type to
Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs:
Continue and create Client secret:
Then copy the Client secret for later steps:
Step-2: Configure App Permissions
Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission:
Select Microsoft Graph:
Then choose Application permissions option:
Continue by adding these Sites permissions (search for
site):Enable only one of the site-wide Microsoft Graph application permissions that fits your scenario:
Sites.Read.All(read all sites),Sites.ReadWrite.All(read/write all sites), orSites.Selected(least privilege: only sites you explicitly grant). These levels overlap in purpose; do not select all of them because an illustrative screenshot may show several checkboxes. If you chooseSites.Selected, there is no Entra ID or SharePoint UI to pick individual sites—you must grant access per site (or list/item) using the PowerShell / Graph steps in Grant SharePoint permissions to the OAuth app (optional) below.
INFO: If you want to access specific lists or list items (table-level vs row-level security) rather than the full site, then addLists.SelectedOperations.SelectedorListItems.SelectedOperations.Selectedpermissions , just like in the previous step (search forlist).WARNING: If you add any of these permissions -Sites.Selected,Lists.SelectedOperations.Selected, orListItems.SelectedOperations.Selected- you must grant the app the SharePoint permissions for the specific resource (e.g. aSite, aList, or aListItem). Follow instructions in Grant SharePoint permissions to the OAuth app (optional) section on how to accomplish that. -
Finish by clicking Add permissions button:
Now it's time to Grant admin consent for your application:
Confirm all the permissions are granted:
Now go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
- In the Client Secret field paste the Client secret value you copied in the previous step.
- Done!
Step-3 (optional): Grant SharePoint permissions to the OAuth app
If you used
Sites.Selected,Lists.SelectedOperations.SelectedorListItems.SelectedOperations.Selectedpermission in the previous section, you must grant the app the SharePoint permissions for the specific resource (e.g. aSite, aList, or aListItem). You can do it using PowerShell or SharePoint admin center (obsolete method).Granting SharePoint permissions using PowerShell
Unfortunately, there is no user interface available to control these permissions yet. For now, granting permissions has to be accomplished via Microsoft Graph API [Microsoft reference]:
You must be the owner of the resource to grant permissions (i.e. belong to SharePoint owners group or be the owner of theSiteorList).- Open PowerShell (run as admin).
Call the following PowerShell code to grant
readandwritepermission for the app we created earlier (assuming Application (client) ID is89ea5c94-aaaa-bbbb-cccc-3fa95f62b66e):##### CONFIGURATION ############################################################################################ # More info at: # - https://learn.microsoft.com/en-us/graph/permissions-selected-overview?tabs=powershell # - https://learn.microsoft.com/en-us/powershell/module/microsoft.graph.sites/?view=graph-powershell-1.0 # Find SharePoint Site Id by following these steps: # - Login into SharePoint Online # - Open this URL https://{your-company}.sharepoint.com/_api/site in the browser # NOTE: For a subsite use https://{your-company}.sharepoint.com/sites/{your-subsite}/_api/site # - Find 'Id' element in the response (e.g. <d:Id m:type="Edm.Guid">efcdd21a-aaaa-bbbb-cccc-5d8104d8b5e3</d:Id>) # - Copy the Site Id, i.e.: efcdd21a-aaaa-bbbb-cccc-5d8104d8b5e3 # Set $siteId variable to the retrieved Site Id: $siteId="efcdd21a-aaaa-bbbb-cccc-5d8104d8b5e3" # Find your Application Id (i.e. Client Id) in the Azure Portal, in App Registrations page: # https://portal.azure.com/#view/Microsoft_AAD_RegisteredApps/ApplicationsListBlade $applicationId="89ea5c94-aaaa-bbbb-cccc-3fa95f62b66e" # Set one of app permissions: read, write, fullcontrol, owner ('write' includes 'read' permission) $appPermission="write" ##### SCRIPT ################################################################################################### # Step-1: Install 'Microsoft.Graph.Sites' module if it's not installed if (-not (Get-Module Microsoft.Graph.Sites -ListAvailable)) { Install-Module Microsoft.Graph.Sites } # Step-2: Load module Import-Module Microsoft.Graph.Sites # Step-3: Login (use Azure admin or SharePoint owner account) DisConnect-MgGraph Connect-MgGraph # Step-4: Set parameters for API call (set permissions, Site ID and Application ID) $params = @{ roles = @($appPermission) grantedTo = @{ application = @{id = $applicationId} } } # Step-5: Grant permissions New-MgSitePermission -SiteId $siteId -BodyParameter $params # Done! Write-Host "Granted SharePoint permissions to application '$applicationId' for site '$siteId'." - That's it! Now you can use the connector.
Granting SharePoint permissions using SharePoint admin center (obsolete method)
If you used
Site.Selectedpermission you can link it SharePoint site in SharePoint admin center [SharePoint reference]. Follow these simple steps to accomplish that:-
Log in to SharePoint admin center using this URL:
(replace
YOURCOMPANYwith your company name):https://YOURCOMPANY-admin.sharepoint.com/_layouts/15/appinv.aspx
INFO: To view all the registered apps in SharePoint, visit this page:https://YOURCOMPANY-admin.sharepoint.com/_layouts/15/appprincipals.aspx?Scope=Web. - In the App Id field enter Application (client) ID you copied in the previous step.
In the Permission Request XML field enter XML snippet which describes which SharePoint permissions you want to grant to the OAuth app, e.g.:
<AppPermissionRequests AllowAppOnlyPolicy="true"> <AppPermissionRequest Scope="http://sharepoint/content/tenant" Right="FullControl" /> </AppPermissionRequests>INFO: This example gives appFullControl, but you can also grant itReadorWritepermissions. - Click Create to grant the permission to your OAuth app.
Application Credentials [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
SharepointOnlineDSNSharePoint OnlineApplication Credentials [OAuth]https://graph.microsoft.com/v1.0Required Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Client Secret Fill-in the parameter... Default Site Id Fill-in the parameter... Optional Parameters Scope https://graph.microsoft.com/.default Default Drive Id RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503|423 RetryCountMax 5 RetryMultiplyWaitTime True Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed) Extra Headers (e.g. Header1:AAA||Header2:BBB) IsAppCred 1
Application Credentials with Certificate (Sign JWT with Private Key)
- Create Public/Private Key Pair
- Upload Public Key
- Configure ZappySys Connection for Private Key use
Grant granular permissions (optional)
App registrations
- e.g. select
- e.g. select
Sites.Read.All(read all sites),Sites.ReadWrite.All(read/write all sites), orSites.Selected(least privilege: only sites you explicitly grant). These levels overlap in purpose; do not select all of them because an illustrative screenshot may show several checkboxes. If you chooseSites.Selected, there is no Entra ID or SharePoint UI to pick individual sites—you must grant access per site (or list/item) using the PowerShell / Graph steps in Step-6 (optional): Grant granular permissions to the OAuth app below.
INFO: If you want to access specific lists or list items (table-level vs row-level security) rather than the full site, then addLists.SelectedOperations.SelectedorListItems.SelectedOperations.Selectedpermissions , just like in the previous step (search forlist).WARNING: If you add any of these permissions -Sites.Selected,Lists.SelectedOperations.Selected, orListItems.SelectedOperations.Selected- you must grant the app the SharePoint permissions for the specific resource (e.g. aSite, aList, or aListItem). Follow instructions in Step-6 (optional): Grant granular permissions to the OAuth app on how to accomplish that. -
Step-3: Generate a Self-Signed Certificate
# Run this in PowerShell #Change .AddYears(1) to desired number. By default it expires certificate in one year as per below code. $cert = New-SelfSignedCertificate ` -Subject "CN=MyClientAppCert" ` -KeySpec Signature ` -KeyExportPolicy Exportable ` -KeyLength 2048 ` -CertStoreLocation "Cert:\CurrentUser\My" ` -KeyAlgorithm RSA ` -HashAlgorithm SHA256 ` -NotAfter (Get-Date).AddYears(1) ` -Provider "Microsoft Enhanced RSA and AES Cryptographic Provider" # Export private key (.pfx) - Keep this with you to make API calls (SECRET KEY - DONOT SHARE) $pfxPath = "$env:USERPROFILE\Desktop\private_key.pfx" $pwd = ConvertTo-SecureString -String "yourStrongPassword123" -Force -AsPlainText Export-PfxCertificate -Cert $cert -FilePath $pfxPath -Password $pwd # Export public certificate (.cer) - UPLOAD this to Azure Portal $cerPath = "$env:USERPROFILE\Desktop\public_key.cer" Export-Certificate -Cert $cert -FilePath $cerPathStep-4: Upload the Certificate (i.e. Public Key *.cer)
Once we have certificate file generated.- In your App Registration, go to Certificates & secrets
- Under Certificates, click Upload certificate
- Select the
.cerfile (public certificate)
- Click Select a file (Browse button)
- Select public key file (*.cer) from local machine and click OK to upload
Step-5: Configure ZappySys Connection - Use private key (i.e. *.pfx or *.pem)
Now its time to use certificate pfx file (private key) generated in the previous step (NOTE: PFX file contains both private key and public key).-
Go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
- Configure private key
- go to
Certificate Tab - Change Storage Mode to
Disk File: *.pfx format (PKCS#12).NOTE: You can also useStored In LocalMachinemode if PFX file already imported in the Local Certificate Storage Area - User Store OR Machine Store. If you used OpenSSL to generate key pair then useDisk File: *.pem format (PKCS#8 or PKCS#1)Mode for Cert Store Location. - Supply the key file path
- Supply the certificate password (same password used in earlier PowerShell script)
- go to
- Now go back to General Tab, choose Default Site Id and Default Drive Id from the drop down menu.
- Click Test connection see everything is good
If you used
Application Credentials with Certificate (Sign JWT with Private Key) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
SharepointOnlineDSNSharePoint OnlineApplication Credentials with Certificate (Sign JWT with Private Key) [OAuth]https://graph.microsoft.com/v1.0Required Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Certificate: *** Configure [Client Certificate] Tab *** Fill-in the parameter... Default Site Id Fill-in the parameter... Optional Parameters Default Drive Id RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503|423 RetryCountMax 5 RetryMultiplyWaitTime True Search Option For Non-Indexed Fields (Default=Blank - Search Only Indexed) Extra Headers (e.g. Header1:AAA||Header2:BBB) IsAppCred 1
ZappySys API Driver - SharePoint OnlineRead and write SharePoint Online data effortlessly. Integrate, manage, and automate sites, lists, document libraries, and files — almost no coding required.SharepointOnlineDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from SharePoint Online. Hit OK button to use this query in the next step.
SELECT * FROM Lists
Some parameters configured in this window will be passed to the SharePoint Online API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster .Now hit Preview Data button to preview the data using the generated SQL query. If you are satisfied with the result, use this query in Power BI:
ZappySys API Driver - SharePoint OnlineRead and write SharePoint Online data effortlessly. Integrate, manage, and automate sites, lists, document libraries, and files — almost no coding required.SharepointOnlineDSNSELECT * FROM Lists
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the SharePoint Online API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in SharePoint Online servers).Click OK to finish creating the data source.
Connect to SharePoint Online data in Power BI
Another window opens and asks to select a Data Source we already created. Choose SharepointOnlineDSN and continue:
SharepointOnlineDSN
SharepointOnlineDSN
Finally, finally, read extracted data from SharePoint Online in a Power BI report:
If you wish to import SharePoint Online data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Consider using Custom Objects feature in ODBC data source to encapsulate SQL query in a Virtual Table. This way, you can see a virtual table in Power BI table list where you can import multiple objects using the same connection rather than creating a new connection for each custom SQL query.Publish Power BI report to Power BI service
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local SharePoint Online ODBC data source:
Standard mode- Supports Power BI and other Microsoft Cloud services
Personal mode- Supports Power BI services only
We recommend using Personal mode for quick POCs or personal use, and Standard mode for production scenarios.Below are instructions on how to refresh the semantic model using both gateway types.
ODBC{"connectionstring":"dsn=SharepointOnlineDSN"}
Refer to Power Query M reference for more information on how to use its advanced features in your queries.Using parameters for dynamic queries
= Odbc.Query("dsn=SharepointOnlineDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports SharePoint Online data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Since the native Power BI ODBC connector limits you to
Importmode, we must bridge the connection via Microsoft SQL Server. To do this, we configure the ZappySys Data Gateway and create a Linked Server pointing to it:
This method requires an existing Microsoft SQL Server instance to act as the bridge.Follow these steps to use DirectQuery:
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_SHAREPOINT_ONLINE_IN_GATEWAY], 'SELECT * FROM Lists')
SELECT * FROM OPENQUERY([LS_TO_SHAREPOINT_ONLINE_IN_GATEWAY], 'SELECT * FROM Lists') - Click OK and load the data. Your SharePoint Online data is now linked live rather than imported.
Avoid usingDirectQueryunless it is required for very large datasets or real-time data needs. Data is fetched on demand, which can impact performance compared to the cachedImportmode.Using full ODBC connection string
SharepointOnlineDSNDRIVER={ZappySys API Driver};ServiceUrl=https://graph.microsoft.com/v1.0;Provider=Custom;OAuthVersion=OAuth2;ScopeSeparator={space};GrantType=Default;Scope=[$Scope$];ScopeSeparator={space};ContentType=application/x-www-form-urlencoded;
The DSN defined in the Data source name (DSN) field will be ignored.Have in mind that a full connection string has length limitations.
"Connection string exceeds maximum allowed length of 1024"But there is a solution to this by storing the full connection string in a file. Follow the steps below to achieve this:
This feature requires ODBC PowerPack v1.9.0 or later.SharePoint Online Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential SharePoint Online operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Read Main Site
- List Sites
- List Drives
- Read Drive
- List Folders
- List Files
- List Excel Files
- List SharePoint Lists
- List SharePoint System Lists
- Read List Fields
- Read List
- Read List Items
- Read List Items (Dynamic Columns)
- Read List Item (By ID)
- Create List Item
- Update List Item
- Delete List Item
- List Excel Worksheets of a File (i.e. List Tabs)
- Read Excel Worksheet (Auto Detect Range)
- Read Excel Worksheet (From Exact Range)
- Read CSV File (Generic)
- Create / Update CSV File (Generic)
- Read JSON File (Generic)
- Create / Update JSON File (Generic)
- Read File Data (As Byte Array)
- Download File
- Upload File
- Get Item (File or Folder)
- Delete Item (File or Folder)
- Move or rename item (File or Folder)
- Copy item (File or Folder)
In some situations, you may need to provide SharePoint Online data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Data Gateway Local ODBCdata sourceSimple configuration Installation Single machine Per machine Connectivity Local and remote Local only Connections limit Limited by License Unlimited Central data access Central access control More flexible cost To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Power BI (client-side) to connect to it.
Create SharePoint Online data source in the gateway
In this section we will create a data source for SharePoint Online in the Data Gateway. Let's follow these steps to accomplish that:
SharepointOnlineDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the SharePoint Online ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
SharepointOnlineDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - SharePoint OnlineRead and write SharePoint Online data effortlessly. Integrate, manage, and automate sites, lists, document libraries, and files — almost no coding required.SharepointOnlineDSN
SharepointOnlineDSN(the one we used in the Data Gateway):SharepointOnlineDSNSharepointOnlineDSN
Finally, we are ready to read data from SharePoint Online in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to SharePoint Online data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to SharePoint Online in Power BI and integrate your data — all without writing complex code.
Want more?Don't stop here. Discover more integrations.
Explore all Power BI connectors
Explore all SharePoint Online integration scenarios
