You can connect to your Zoom data from Power BI via the high-performance Zoom ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Zoom
  • Working with Zoom data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoom Connector.
Create data source using Zoom ODBC Driver
To get data from Zoom using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoom" from the list of Popular Connectors. If "Zoom" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZoomDSN
    Zoom
    • Configure the authentication in Zoom.
    User Credentials (Access Your Data)
    Zoom authentication
    OAuth App must be created under Admin Console > Channel > API > Settings. [API reference]
    Follow the steps below to create a Zoom OAuth app and obtain the required credentials (Client ID and Client Secret):
    1. Go to the Zoom App Marketplace and sign in with your Zoom account.
    2. From the top navigation bar, open the Develop dropdown and select Build App.
    3. In the What kind of app are you creating window, select General App, click the Create button.
    4. Enter a name for your app and select the app type.
      (E.g. Zoom-General App)
    5. Click Create to continue.
    6. In the Redirect URL for OAuth field, enter the following URI and add it to the allow list:
      https://zappysys.com/oauth/
    7. Copy your Client ID and Client Secret, then paste them into the ZappySys API Component/Driver UI under the required parameters.
    8. From the Scopes window, please add the appropriate Granular scopes. You can search for the scopes listed below and enable them as needed.
      Scope Levels:
      • User-Level: Grants access only to the authenticated user’s data. Suitable for apps where users connect with their own Zoom account.
      • Admin-Level: Grants access to data across all users in the account, provided the user has admin permissions. Best for organization-wide apps.
      • Master-Level: Grants access at the highest level, typically for apps that need full account control (including sub-accounts). Requires Master Account credentials.
      Recommended Scopes:
      User-Level
      • user:read:settings
      • meeting:read:list_meetings
      • meeting:read:meeting
      • meeting:read:list_registrants
      • meeting:read:past_meeting
      • meeting:read:list_registration_questions
      • webinar:read:list_webinars
      • webinar:read:webinar
      • webinar:read:list_registrants
      • report:read:user
      Admin-Level
      • user:read:settings:admin
      • user:write:user:admin
      • meeting:read:list_meetings:admin
      • meeting:read:meeting:admin
      • meeting:read:list_registrants:admin
      • meeting:read:past_meeting:admin
      • meeting:read:list_registration_questions:admin
      • user:read:list_users:admin
      • webinar:read:list_webinars:admin
      • webinar:read:webinar:admin
      • webinar:read:list_registrants:admin
      • report:read:user:admin
      Master-Level
      • user:read:settings:master
      • meeting:read:list_meetings:master
      • meeting:read:meeting:master
      • meeting:read:list_registrants:master
      • user:read:list_users:master
      • webinar:read:list_webinars:master
      • webinar:read:webinar:master
      • webinar:read:list_registrants:master
      • report:read:user:master
    9. That’s it! After adding the scopes, click Continue to complete the process.
    10. In the ZappySys API Component/Driver UI, enter your Zoom app Client ID and Client Secret, then click Generate Token to obtain the access tokens.
    11. You’re done!
    1. Set Authentication Type to User Credentials (Access Your Data) [OAuth]
    ZoomDSN
    Zoom
    https://api.zoom.us/v2
    Client Id Fill-in the parameter...
    Redirect Url Fill-in the parameter...
    Token Url Fill-in the parameter...
    Authorization Url Fill-in the parameter...
    Retry Mode RetryWhenStatusCodeMatch
    Retry Status Code 429
    Retry Count Max 5
    Retry Multiply Wait Time True
    Find full details in the Zoom Connector authentication reference.
    App Credentials (Access Account Level Data)
    Zoom authentication
    Server-to-Server OAuth authentication method that lets applications access the Zoom API directly without user login or consent, using a Client ID and Secret to generate short-lived tokens. [API reference]
    3. In the What kind of app are you creating window, select Server to Server OAuth App, click the Create button.
      (E.g. Basic OAuth App)
    6. Copy your Account ID, Client ID, and Client Secret, then paste them into the ZappySys API Component/Driver UI under the required parameters.
    7. In the Information window, enter the company name, developer name, and email address, then click Continue.
      Scope Levels:
      Recommended Scopes:
      Admin-Level
      Master-Level
    10. In the ZappySys API Component/Driver UI, enter your Zoom app Account ID, Client ID, and Client Secret, then click Test Connection.
    11. You’re done!
    1. Set Authentication Type to App Credentials (Access Account Level Data) [OAuth]
    ZoomDSN
    Zoom
    Account Id Fill-in the parameter...
    Retry Count Max 5
    User Credentials (Access Your Data) - With Legacy Scopes
    Zoom authentication
    Perform the following steps to get the Zoom OAuth credentials (i.e. Client ID and Client Secret)
    1. Go to Zoom Marketplace Portal and sign in there.
    2. Once you successfully login then select "Build App" option from Develop dropdown from top left on the page.
    3. Click on Create button of OAuth panel section of page.
    4. Enter the name for your application and choose app type (Recommneded "Account-Level App") option for your API
    5. Then proceed with clicking Create button.
    6. In Redirect URL for OAuth enter this https://zappysys.com/oauth/ as Redirect URI and add it to allow lists.
    7. Copy Client ID and Client Secret here and paste it into Connection Manager Required Paramters section in respective place holders
    8. Add appropiate scopes from the Scopes menu option to the right side of page for your API as below :
      NOTE: If you need to read/write data for all users (not just 'me') then add :admin suffix in the scope (e.g. meeting:read:admin)
      • meeting:read
      • meeting:write
      • user:read
      • user:write
      • user_info:read
      • meeting:read
      • chat_channel:read
      • chat_channel:write
      • chat_contact:read
      • chat_message:read
      • chat_message:write
      • contact:read
      • pac:read
      • pac:write
      • phone:read
      • phone:write
      • phone_call_control:read
      • phone_call_control:write
      • phone_call_log:read
      • phone_call_log:write
      • phone_e911:read
      • phone_recording:read
      • phone_recording:write
      • phone_sms:read
      • phone_sms:write
      • phone_voicemail:read
      • phone_voicemail:write
      • recording:read
      • recording:write
      • tsp:read
      • tsp:write
      • user:read
      • user:write
      • user_info:read
      • user_zak:read
      • webinar:read
      • webinar:write
      • report:read:user
    9. Click Generate Token button on Connection Manager UI to generate tokens.
    10. That's it!
    1. Set Authentication Type to User Credentials (Access Your Data) - With Legacy Scopes [OAuth]
    ZoomDSN
    Zoom
    RedirectUrl Fill-in the parameter...
    TokenUrl Fill-in the parameter...
    AuthorizationUrl Fill-in the parameter...
    Scope
    ZappySys API Driver - Zoom
    Read and write Zoom data effortlessly. Integrate, manage, and automate meetings, users, accounts, and invitations — almost no coding required.
    ZoomDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Zoom. Hit OK button to use this query in the next step.
    SELECT * FROM Meetings
    WITH(
      UserId ='me' -- enter user id or email
    Some parameters configured in this window will be passed to the Zoom API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    ZoomDSN
    WITH(
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoom API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoom servers).
Connect to Zoom data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ZoomDSN and continue:
    ZoomDSN
    ZoomDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Zoom in a Power BI report:
If you wish to import Zoom data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ZoomDSN
WITH(
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Zoom ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ZoomDSN"}
    dsn=ZoomDSN
    dsn=ZoomDSN
    = Odbc.Query("dsn=ZoomDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Zoom data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Zoom Service
    SELECT * FROM OPENQUERY([LS_TO_ZOOM_IN_GATEWAY], 'SELECT * FROM Meetings WITH( UserId =''me'' -- enter user id or email )')
    DirectQuery option for Power BI (read Zoom data example using SQL Server Linked Server and ZappySys Data Gateway)
    WITH(
  7. Click OK and load the data. Your Zoom data is now linked live rather than imported.
    ZoomDSN
    ZoomDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://api.zoom.us/v2;Provider=Custom;AuthorizeInFullBrowser=True;OAuthVersion=OAuth2;
Zoom Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoom operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Zoom data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Zoom data source in the gateway
In this section we will create a data source for Zoom in the Data Gateway. Let's follow these steps to accomplish that:
    ZoomDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zoom ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZoomDSN
      ZoomDSN
      ZoomDSN
  5. Then set the default database property to ZoomDSN (the one we used in the Data Gateway):
    ZoomDSN
    ZoomDSN
Finally, we are ready to read data from Zoom in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Zoom data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Zoom in Power BI and integrate your data — all without writing complex code.
