You can connect to your Apache Druid data from Power BI via the high-performance Apache Druid ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Druid
  • Working with Apache Druid data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Druid.
Download Apache Druid JDBC driver
To connect to Apache Druid, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Druid website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Druid\avatica-1.28.0-shadow.jar.
Create data source using Apache Druid ODBC Driver
To get data from Apache Druid using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Druid.
    Broker SQL (Avatica)
    Apache Druid authentication
    Apache Druid JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Use the Router or Broker host. Default SQL Avatica path is /druid/v2/sql/avatica/ on port 8888.
    2. If the cluster uses basic auth, fill user and password from the Druid coordinator.
    3. Prefer HTTPS only when TLS is terminated on that endpoint (see Druid SQL JDBC docs).
    3. Finally, hit OK button:
    • Connection string: jdbc:avatica:remote:url=http://[$HostName$]:[$Port$]/druid/v2/sql/avatica/
    • Driver class: org.apache.calcite.avatica.remote.Driver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Druid\avatica-1.28.0-shadow.jar
    • Host: MyHostName
    • TCP port: 8888
    • User name:
    • Password:
    ApacheDruidDSN
    optional for Apache Druid
    Find full details in the Apache Druid Connector authentication reference.
    Jump to troubleshooter
    ApacheDruidDSN
    SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'druid' ORDER BY TABLE_NAME
Connect to Apache Druid data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheDruidDSN and continue:
    ApacheDruidDSN
    ApacheDruidDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Druid in a Power BI report:
If you wish to import Apache Druid data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheDruidDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Druid ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheDruidDSN"}
    dsn=ApacheDruidDSN
    dsn=ApacheDruidDSN
    = Odbc.Query("dsn=ApacheDruidDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Druid data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Druid Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_DRUID_IN_GATEWAY], 'SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = ''druid'' ORDER BY TABLE_NAME')
    DirectQuery option for Power BI (read Apache Druid data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Druid data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Druid
    Query Apache Druid SQL through Avatica JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheDruidDSN
    ApacheDruidDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:avatica:remote:url=http://[$HostName$]:[$Port$]/druid/v2/sql/avatica/';ClassName='org.apache.calcite.avatica.remote.Driver';DriverPath='C:\ZappySys\Jdbc\Apache Druid\avatica-1.28.0-shadow.jar';UserName='';UserPassword='';ConnParams='optional for Apache Druid'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.calcite.avatica.remote.Driver):
  6. Go to the Libraries tab, click Add File, and select your Apache Druid driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Druid\avatica-1.28.0-shadow.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:avatica:remote:url=http://[$HostName$]:[$Port$]/druid/v2/sql/avatica/), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Druid data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Druid data source in the gateway
In this section we will create a data source for Apache Druid in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheDruidDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Druid ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheDruidDSN
      ApacheDruidDSN
      ApacheDruidDSN
  5. Then set the default database property to ApacheDruidDSN (the one we used in the Data Gateway):
    ApacheDruidDSN
    ApacheDruidDSN
Finally, we are ready to read data from Apache Druid in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Druid data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Druid in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Druid, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
