You can connect to your Google Ads data from Power BI via the high-performance Google Ads ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Google Ads
  • Working with Google Ads data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Google Ads Connector.
Create data source using Google Ads ODBC Driver
To get data from Google Ads using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Google Ads" from the list of Popular Connectors. If "Google Ads" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    GoogleAdsDSN
    Google Ads
    • Configure the authentication in Google Ads.
    User Account
    Google Ads authentication
    User accounts represent a developer, administrator, or any other person who interacts with Google APIs and services. User accounts are managed as Google Accounts, either with Google Workspace or Cloud Identity. They can also be user accounts that are managed by a third-party identity provider and federated with Workforce Identity Federation. [API reference]
    Follow these steps on how to create Client Credentials (User Account principle) to authenticate and access Google Ads API in SSIS package or ODBC data source:
    WARNING: If you are planning to automate processes, we recommend that you use a Service Account authentication method. In case, you still need to use User Account, then make sure you use a system/generic account (e.g. automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.
    Manager Account Setup - Obtain Developer Token
    To access Google Ads API (your data or someone else data) you must perform the following steps (high level). Detailed steps listed in the next sections.
    1. Create a Google Ads Manager account (formally known as MCC).
    2. Apply for Production data access (Upgrade Developer Token access Level to Basic).
    3. Link manager account with Google Ads Account.
    4. Create a new Project and obtain Client Id and Client Secret
    Step-1: Create a Google Ads Manager account (formally known as MCC)
    Very first step to access Google Ads API for your own account or someone else account, you will need something called Google Manager Account (formally known as MCC). It will look like a Normal Google Ads Account with some difference so dont get confused if you see similar interface as Ads account.
    See Google Ads Help: Create a manager account (https://support.google.com/google-ads/answer/7459399) for step-by-step instructions. Once you created a manager account, you can login or switch between Ads account and Manager account like below. You can identify manager account using "Manager" word next to the account id when you click Profile dropdown. Login as Google Ads Account Manager (formally known as MCC)
    Step-2: Obtain Developer Token
    Once you have created and logged in to your Google Ads Manager Account (formally known as MCC) we are ready for the next step which is obtain Developer Token. To access Google Ads API you need to pass developer token in each API call. By default Developer Token is only allowed to access Sandbox (Test) account. If you like to access Production data (Live Ads Account) then you must apply for Basic Access by clicking link under Access Level (See next section for information).
    Here is how to can obtain your Developer Token.
    • Log in as Manager account (Or change Top-Right Profile > Choose Manager account ID
    • Click on Admin icon
    • Click on API Center (This option will be missing if you are logged in to Regular Ads account as Client and not using Manager Account (MMC)
    • Expand Access Level, Click Apply for Basic Access if it says "Test". By default Developer Token is created with Test Account access only. To access Production Ads account you must apply for higher access level. Must be Basic or Standard (not Test). After click the link you will see form with few questions, please fill out that and submit the form. Apploval process may take 3-5 days (or longer in some cases if you did not provide enough information).
    • If your token is already approved for the basic access then copy the token and paste on the Google Ads Connector - Connection UI (For Developer Token property)
    See Google Ads API: Get a developer token (https://developers.google.com/google-ads/api/docs/get-started/dev-token) for detailed instructions
    Developer Token for Google Ads API Access in API Center (Visible when logged in as Manager Account)
    Link Manager Account to Google Ads Account
    After you have manager account ready, next step is to link manager account with Google Ads Account. You have to send invitation from Manager account to access Google Ads account (it can be your own account or someone else). Here is how to send invite to link Google Ads account.
    • Click on Accounts icon > Sub-account settings > Send Link Request
    • Click on Add Sign (+) and select + Link existing account option
    • When prompted enter Account Id(s) you like to link with this Manager Account. Link Google Manager Account with Ads Account
    • Click Send Request. You can find Ad Account Id usually at the Top-Right corner after you login to the Google Ads account. Send Invitation to link Google Manager Account with Ads Account
    • Now ask Google Ads Account owner to check email. Click Accept Invitation link in the email (If prompted login as Google Ads Account owner).
      -OR-
      Another way to see Invitation, Login to Google Ads account (Or Switch from the Top-Right corner by clicking Profile icon). Go to Admin icon > Access and security > Managers Tab. Find the pending invitation and click ACCEPT. Accept Manager account to Google Ads Account link invitation
    • That's it. Now your Manager account is linked to the Google Ads account
    Obtain ClientId and ClientSecret
    Step-1: Create project
    This step is optional, if you already have a project in Google Cloud and can use it. However, if you don't, proceed with these simple steps to create one:
    1. First of all, go to Google API Console.
    2. Then click Select a project button and then click NEW PROJECT button:
      Start creating a new project in Google Cloud
    3. Name your project and click CREATE button:
      Create a new project in Google Cloud
    4. Wait until the project is created:
      Wait until project is created in Google Cloud
    5. Done! Let's proceed to the next step.
    Step-2: Enable Google Ads API
    In this step we will enable Google Ads API:
    1. Select your project on the top bar:
      Select project in Google Cloud
    2. Then click the "hamburger" icon on the top left and access APIs & Services:
      Access APIs and services in Google Cloud
    3. Now let's enable several APIs by clicking ENABLE APIS AND SERVICES button:
      Enable API for project in Google Cloud
    4. In the search bar search for Ads and then locate and select Google Ads API:
      Search for API in Google Cloud
    5. Enable Google Ads API:
    6. Done! Let's proceed to the next step.
    Step-3: Create OAuth application
    1. First of all, click the "hamburger" icon on the top left and then hit VIEW ALL PRODUCTS:
      View all products in Google Cloud
    2. Then access Google Auth Platform to start creating an OAuth application:
      Open Google Auth Platform in Google Cloud
    3. Start by pressing GET STARTED button:
      Start creating an app in Google Cloud
    4. Next, continue by filling in App name and User support email fields:
      Fill app info in Google Cloud
    5. Choose Internal option, if it's enabled, otherwise select External:
      Choose app audience in Google Cloud
    6. Optional step if you used Internal option in the previous step. Nevertheless, if you had to use External option, then click ADD USERS to add a user:
      Add test user in Google Cloud app
    7. Then add your contact Email address:
      Enter app contact info in Google Cloud
    8. Finally, check the checkbox and click CREATE button:
      Create app in Google Cloud
    9. Done! Let's create Client Credentials in the next step.
    Step-4: Create Client Credentials
    1. In Google Auth Platform, select Clients menu item and click CREATE CLIENT button:
      Start creating app client in Google Cloud
    2. Choose Desktop app as Application type and name your credentials:
      Create OAuth app client in Google Cloud
    3. Continue by opening the created credentials:
      View app client credentials in Google Cloud
    4. Finally, copy Client ID and Client secret for the later step:
      Use client ID and secret to read Google REST API data
    5. Done! We have all the data needed for authentication, let's proceed to the last step!
    Step-5: Configure connection
    1. Now go to SSIS package or ODBC data source and use previously copied values in User Account authentication configuration:
      • In the ClientId field paste the Client ID value.
      • In the ClientSecret field paste the Client secret value.
      • In the DeveloperToken field paste the Developer Token value.
    2. Press Generate Token button to generate Access and Refresh Tokens.
    3. Finally, click Test Connection to confirm the connection is working.
    4. Done! Now you are ready to use Google Ads Connector!
    1. Set Authentication Type to User Account [OAuth]
    GoogleAdsDSN
    Google Ads
    https://googleads.googleapis.com/[$ApiVersion$]
    UseCustomApp Fill-in the parameter...
    CustomerId (without dash e.g. 2125557752) Fill-in the parameter...
    DeveloperToken Fill-in the parameter...
    ClientId
    ClientSecret
    Scope https://www.googleapis.com/auth/adwords
    Login CustomerId (without dash e.g. 2125557752)
    Linked CustomerId (without dash e.g. 2125557752)
    API Version v26
    Redirect URL (Only for Web App)
    Find full details in the Google Ads Connector authentication reference.
    Service Account (Using *.json OR *.p12 key file)
    Service accounts are accounts that do not represent a human user. They provide a way to manage authentication and authorization when a human is not directly involved, such as when an application needs to access Google Cloud resources. Service accounts are managed by IAM. [API reference]
    1. Create a Manager account.
    4. Inside Manager account apply for Basic API Access level so you can use Developer Token to access Live data (Production Ads account). Without Basic access level Developer Token can be only used for Test / Sandbox Ads account.
    5. Create a new Project and obtain Client Id and Client Secret
    4. Create a new Project and obtain Service Account details
      -OR-
    4. In the search bar search for ads and then locate and select Google Ads API:
    Step-3: Create Service Account
    Use the steps below to create a Service Account in Google Cloud:
    1. First of all, go to IAM & Admin in Google Cloud console:
      Access IAM & Admin in Google Cloud
    2. Once you do that, click Service Accounts on the left side and click CREATE SERVICE ACCOUNT button:
      Start creating service account in Google Cloud
    3. Then name your service account and click CREATE AND CONTINUE button:
      Create service account in Google Cloud
    4. Continue by clicking Select a role dropdown and start granting service account Project Viewer roles:
      Start granting service account project roles in Google Cloud
    5. Find Project group and select Viewer role:
      Grant service account project viewer role
    6. Finish adding roles by clicking CONTINUE button:
      Finish granting service account project roles in Google Cloud
      You can always add or modify permissions later in IAM & Admin.
    7. Finally, in the last step, just click button DONE:
      Finish configuring service account in Google Cloud
    8. Done! We are ready to add a Key to this service account in the next step.
    Step-4: Add Key to Service Account
    We are ready to add a Key (JSON or P12 key file) to the created Service Account:
    1. In Service Accounts open newly created service account:
      Open service account in Google Cloud
    2. Next, copy email address of your service account for the later step:
      Copy service account email address in Google Cloud
    3. Continue by selecting KEYS tab, then press ADD KEY dropdown, and click Create new key menu item:
      Start creating key for service account in Google Cloud
    4. Finally, select JSON (Engine v19+) or P12 option and hit CREATE button:
      Create JSON or P12 key for service account in Google Cloud
    5. Key file downloads into your machine. We have all the data needed for authentication, let's proceed to the last step!
    Step-5: Give Permissions to Service Account
    Now it's time to grant permission to Service Account we just created:
    1. Login to https://ads.google.com/aw/settings/account with Google Ads account credentials (If propmpted choose your Ads account).
    2. Go to Admin section, Access and security, Click on Users tab.
    3. Click on Add Icon (+) and enter service account email address which you like to use for data access and choose permissions.
    4. That's it! Let's proceed to the configuration!
    Step-6: Configure connection
    1. Now go to SSIS package or ODBC data source and configure these fields in Service Account authentication configuration:
      • In the Service Account Email field paste the service account Email address value you copied in the previous step.
      • In the Service Account Private Key Path (i.e. *.json OR *.p12) field use downloaded key file path.
    2. Done! Now you are ready to use Google Ads Connector!
    If you received an error saying DEVELOPER_TOKEN_PROHIBITED then read the following workaround.
    Each Google API Console project can be associated with the developer token from only one manager account. Once you make a Google Ads API request, the developer token is permanently paired to the Google API Console project. If you don't use a new Google API Console project, you'll get a DEVELOPER_TOKEN_PROHIBITED error when making a request. Unfortunatly there is no other way to Unlink old Developer Token from the API Project, so for now just create a new Project as a workaround to fix this error.
    1. Set Authentication Type to Service Account (Using *.json OR *.p12 key file) [OAuth]
    GoogleAdsDSN
    Google Ads
    Service Account Email Fill-in the parameter...
    Service Account Private Key Path (i.e. *.json OR *.p12) Fill-in the parameter...
    API Version v26
    Impersonate As (Google account email address)
    ZappySys API Driver - Google Ads
    Read and write Google Ads data effortlessly. Integrate, manage, and automate campaigns, ad groups, keywords, and performance — almost no coding required.
    GoogleAdsDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Google Ads. Hit OK button to use this query in the next step.
    SELECT *
    FROM get_campaigns
    --OR--
    --SELECT * FROM get_resource_data WITH(Resource='Campaign') --slightly faster
    Some parameters configured in this window will be passed to the Google Ads API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    GoogleAdsDSN
    SELECT *
    FROM get_campaigns
    --OR--
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Google Ads API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Google Ads servers).
Connect to Google Ads data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose GoogleAdsDSN and continue:
    GoogleAdsDSN
    GoogleAdsDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Google Ads in a Power BI report:
If you wish to import Google Ads data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
GoogleAdsDSN
SELECT *
FROM get_campaigns
--OR--
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Google Ads ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=GoogleAdsDSN"}
    dsn=GoogleAdsDSN
    dsn=GoogleAdsDSN
    = Odbc.Query("dsn=GoogleAdsDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Google Ads data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Google Ads Service
    SELECT * FROM OPENQUERY([LS_TO_GOOGLE_ADS_IN_GATEWAY], 'SELECT * FROM get_campaigns --OR-- --SELECT * FROM get_resource_data WITH(Resource=''Campaign'') --slightly faster')
    DirectQuery option for Power BI (read Google Ads data example using SQL Server Linked Server and ZappySys Data Gateway)
    FROM get_campaigns
    --OR--
  7. Click OK and load the data. Your Google Ads data is now linked live rather than imported.
    GoogleAdsDSN
    GoogleAdsDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://googleads.googleapis.com/[$ApiVersion$];Provider=GoogleAdWords;ScopeSeparator={space};RetryMode=[$RetryMode$];RetryStatusCodeList=[$RetryStatusCodeList$]
Google Ads Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Google Ads operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Google Ads data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Google Ads data source in the gateway
In this section we will create a data source for Google Ads in the Data Gateway. Let's follow these steps to accomplish that:
    GoogleAdsDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Google Ads ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      GoogleAdsDSN
      GoogleAdsDSN
      GoogleAdsDSN
  5. Then set the default database property to GoogleAdsDSN (the one we used in the Data Gateway):
    GoogleAdsDSN
    GoogleAdsDSN
Finally, we are ready to read data from Google Ads in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Google Ads data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Google Ads in Power BI and integrate your data — all without writing complex code.
