You can connect to your Apache Solr data from Power BI via the high-performance Apache Solr ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Solr
  • Working with Apache Solr data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Solr.
Download Apache Solr JDBC driver
To connect to Apache Solr, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Solr website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Solr\solr-solrj-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-streaming-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-zookeeper-9.10.1.jar.
  4. There is no official Solr JDBC fat JAR. The wizard downloads SolrJ 9.10.1 plus solr-solrj-streaming (JDBC DriverImpl) and solr-solrj-zookeeper (ZooKeeper mode).
  5. Copy the remaining runtime JARs from a matching Solr 9 install: $SOLR_TIP/server/solr-webapp/webapp/WEB-INF/lib/* and $SOLR_TIP/server/lib/ext/*. Add those paths on the DSN Main UI (semicolon-separated) if Test Connection reports missing classes.
  6. The target collection must expose the /sql request handler. Pin SolrJ 9.x (not 10) to match EngineVersion 11.
  7. Done! That was easy, wasn't it? Let's proceed to the next step.
Create data source using Apache Solr ODBC Driver
To get data from Apache Solr using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Solr.
    ZooKeeper (SolrCloud)
    Apache Solr authentication
    Apache Solr SQL JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. The collection must expose /sql. This Auth uses ZooKeeper (SolrCloud).
    1. Note the ZooKeeper host and port (often 2181, or Solr's embedded ZK on 9983 in local examples) and the collection name.
    2. Confirm the collection has the /sql handler in solrconfig.xml.
    3. The wizard downloads SolrJ 9.10.1 + streaming + ZooKeeper modules. If Test Connection fails on a missing class, add WEB-INF/lib and server/lib/ext JARs from the same Solr 9 install (see additional download instructions).
    4. After Finish, replace zkHost and collection on the DSN Main UI. Driver class is org.apache.solr.client.solrj.io.sql.DriverImpl (not auto-obvious from SPI).
    3. Finally, hit OK button:
    • Connection string: jdbc:solr://[$HostName$]:[$Port$]?collection=[$Collection$]
    • Driver class: org.apache.solr.client.solrj.io.sql.DriverImpl
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Solr\solr-solrj-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-streaming-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-zookeeper-9.10.1.jar
    • Host: MyHostName
    • TCP port: 2181
    • Collection: MyCollection
    • User name:
    • Password:
    ApacheSolrDSN
    optional for Apache Solr
    Find full details in the Apache Solr Connector authentication reference.
    HTTP
    Solr SQL over HTTP (no ZooKeeper in the JDBC URL). Still requires /sql on the collection.
    1. Note the Solr node host and HTTP port (default 8983) and the collection name.
    2. If the node is SolrCloud, ZooKeeper Auth is usually more reliable. Use HTTP for standalone Solr or a single node you can reach directly.
    3. Keep SolrJ 9.x. Do not mix Solr 10 JARs with this EngineVersion 11 profile.
    4. After Finish, replace host, port, and collection.
    • Host: MyHostName
    • TCP port: 2181
    • User name:
    • Password:
    ApacheSolrDSN
    Jump to troubleshooter
    ApacheSolrDSN
    SELECT id FROM MyCollection LIMIT 10
Connect to Apache Solr data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheSolrDSN and continue:
    ApacheSolrDSN
    ApacheSolrDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Solr in a Power BI report:
If you wish to import Apache Solr data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheSolrDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Solr ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheSolrDSN"}
    dsn=ApacheSolrDSN
    dsn=ApacheSolrDSN
    = Odbc.Query("dsn=ApacheSolrDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Solr data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Solr Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_SOLR_IN_GATEWAY], 'SELECT id FROM MyCollection LIMIT 10')
    DirectQuery option for Power BI (read Apache Solr data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Solr data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Solr
    Query Apache Solr collections with SQL JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheSolrDSN
    ApacheSolrDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:solr://[$HostName$]:[$Port$]?collection=[$Collection$]';ClassName='org.apache.solr.client.solrj.io.sql.DriverImpl';DriverPath='C:\ZappySys\Jdbc\Apache Solr\solr-solrj-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-streaming-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-zookeeper-9.10.1.jar';UserName='';UserPassword='';ConnParams='optional for Apache Solr'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.solr.client.solrj.io.sql.DriverImpl):
  6. Go to the Libraries tab, click Add File, and select your Apache Solr driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Solr\solr-solrj-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-streaming-9.10.1.jar;C:\ZappySys\Jdbc\Apache Solr\solr-solrj-zookeeper-9.10.1.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:solr://[$HostName$]:[$Port$]?collection=[$Collection$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Solr data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Solr data source in the gateway
In this section we will create a data source for Apache Solr in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheSolrDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Solr ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheSolrDSN
      ApacheSolrDSN
      ApacheSolrDSN
  5. Then set the default database property to ApacheSolrDSN (the one we used in the Data Gateway):
    ApacheSolrDSN
    ApacheSolrDSN
Finally, we are ready to read data from Apache Solr in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Solr data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Solr in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Solr, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
