You can connect to your YouTube data from Power BI via the high-performance YouTube ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to YouTube
- Working with YouTube data directly inside Power BI
Create data source using YouTube ODBC Driver
To get data from YouTube using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "YouTube" from the list of Popular Connectors. If "YouTube" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
YoutubeDSNYouTube
- Configure the authentication in YouTube.
API Key
YouTube authentication
This walkthrough will help you create an API Key which you will be able to use in all requests and authenticate accordingly.- Go to Google API Console
- From the Project Dropdown (usually found at the top bar) click Select Project
- On Project Popup click CREATE PROJECT
- Once project is created you can click Select Project to switch the context (You can click on Notification link or Choose from Top Dropdown)
- Click ENABLE APIs AND SERVICES
- Now we need to Enable three APIs one by one (YouTube Data API, YouTube Analytics API, YouTube Reporting API).
- Search YouTube Data API. Select and click ENABLE
- Search YouTube Analytics API. Select and click ENABLE
- Search YouTube Reporting API. Select and click ENABLE
- Go to back to main screen of Google API Console
- Click OAuth Consent Screen Tab. Enter necessary details and Save.
- Click Credentials Tab
- Click CREATE CREDENTIALS (some where in topbar) and select API key option.
- In the popup, copy API Key from the field "Your API key", close this window, and use it in the UI configuration, "key" field
API Key [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
YoutubeDSNYouTubeAPI Key [Http]https://youtube.googleapis.com/youtube/v3Required Parameters key Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 403|429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the YouTube Connector authentication reference.User Account
To register a custom app, perform the following steps (detailed steps found in the help link at the end)- Go to Google API Console
- Click CREATE CREDENTIALS (some where in topbar) and select OAuth Client ID option.
- When prompted Select Application Type as Desktop App and click Create to receive your ClientID and Secret. Later on you can use this information now to configure Connection.
- Go to OAuth Consent Screen tab. Under Publishing Status click PUBLISH APP to ensure your refresh token doesnt expire often. If you planning to use App for Private use then do not have to worry about Verification Status after Publish.
User Account [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
YoutubeDSNYouTubeUser Account [OAuth]https://youtube.googleapis.com/youtube/v3Required Parameters UseCustomApp Fill-in the parameter... Optional Parameters ClientId ClientSecret Scope https://www.googleapis.com/auth/youtube~https://www.googleapis.com/auth/youtube.readonly~https://www.googleapis.com/auth/youtubepartner~https://www.googleapis.com/auth/youtube.force-ssl~https://www.googleapis.com/auth/youtube.upload~https://www.googleapis.com/auth/youtubepartner-channel-audit~https://www.googleapis.com/auth/yt-analytics-monetary.readonly~https://www.googleapis.com/auth/yt-analytics.readonly RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 403|429 RetryCountMax 5 RetryMultiplyWaitTime True Redirect URL (Only for Web App)
Find full details in the YouTube Connector authentication reference.Service Account (Using *.json OR *.p12 key file)
Use these steps to authenticate as service account rather than Google / GSuite User. Learn more about service account here Basically to call Google API as Service account we need to perform following steps listed in 3 sections (Detailed steps found in the help link at the end)Create Project
First thing is create a Project so we can call Google API. Skip this section if you already have Project (Go to next section)- Go to Google API Console
Create Service Account
Once Project is created and APIs are enabled we can now create a service account under that project. Service account has its ID which looks like some email ID (not to confuse with Google /Gmail email ID)- Go to Create Service Account
- Enter Service account name and Service account description
- For Role, do not select anything for now and Click Continue and then click Done. Next we will create Key.
Create Key
Once service account is created we need to create key file (i.e. credentials).- In the Cloud Console, click the email address for the service account that you created.
- Click Keys.
- Click Add key, then click Create new key.
- Click Create and select P12 format. A P12 key file is downloaded to your computer. We will use this file in our API connection.
- Click Close.
- Now you may use downloaded *.p12 key file as secret file and Service Account Email as Client ID (e.g. some-service-account-name@your-project-id.iam.gserviceaccount.com ).
Add Permission
Now last thing is give read/write permission to Service Account. Basically you can create or open Google Sheet and add the Service Account as an editor to it as below.- Copy the email address of your service account we created in previous step (its usually like this some-service-account-name@your-project-id.iam.gserviceaccount.com).
- Create or select an existing Google Sheet.
- Navigate to Sheet for which you like to give read/write access to Service Account.
- Click on the Share button in the top right, and add the email address of the service account as an editor. Here is how to share file(s) with specific people. Juse share with Service Account (use Service Account Email found on previous section)
Service Account (Using *.json OR *.p12 key file) [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
YoutubeDSNYouTubeService Account (Using *.json OR *.p12 key file) [OAuth]https://youtube.googleapis.com/youtube/v3Required Parameters Service Account Email Fill-in the parameter... Service Account Private Key Path (i.e. *.p12) Fill-in the parameter... Optional Parameters Scope https://www.googleapis.com/auth/youtube https://www.googleapis.com/auth/youtube.readonly https://www.googleapis.com/auth/youtubepartner https://www.googleapis.com/auth/youtube.force-ssl https://www.googleapis.com/auth/youtube.upload https://www.googleapis.com/auth/youtubepartner-channel-audit https://www.googleapis.com/auth/yt-analytics-monetary.readonly https://www.googleapis.com/auth/yt-analytics.readonly RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 403|429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the YouTube Connector authentication reference. -
ZappySys API Driver - YouTubeRead and write YouTube data effortlessly. Integrate, manage, and automate videos, playlists, channels, and analytics — almost no coding required.YoutubeDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from YouTube. Hit OK button to use this query in the next step.
SELECT * FROM MyVideos
Some parameters configured in this window will be passed to the YouTube API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - YouTubeRead and write YouTube data effortlessly. Integrate, manage, and automate videos, playlists, channels, and analytics — almost no coding required.YoutubeDSNSELECT * FROM MyVideos
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the YouTube API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in YouTube servers). -
Connect to YouTube data in Power BI
Another window opens and asks to select a Data Source we already created. Choose YoutubeDSN and continue:
YoutubeDSN
YoutubeDSN
Finally, finally, read extracted data from YouTube in a Power BI report:
If you wish to import YouTube data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local YouTube ODBC data source:
ODBC{"connectionstring":"dsn=YoutubeDSN"}
dsn=YoutubeDSN
dsn=YoutubeDSN
= Odbc.Query("dsn=YoutubeDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports YouTube data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_YOUTUBE_IN_GATEWAY], 'SELECT * FROM MyVideos')
SELECT * FROM OPENQUERY([LS_TO_YOUTUBE_IN_GATEWAY], 'SELECT * FROM MyVideos') - Click OK and load the data. Your YouTube data is now linked live rather than imported.
YoutubeDSNDRIVER={ZappySys API Driver};ServiceUrl=https://youtube.googleapis.com/youtube/v3;
YouTube Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential YouTube operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get video details
- Get videos rating
- Get playlists
- Get playlist items
- Get comments
- Get channels
- Get videos
- Search
- Get report
In some situations, you may need to provide YouTube data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create YouTube data source in the gateway
In this section we will create a data source for YouTube in the Data Gateway. Let's follow these steps to accomplish that:
YoutubeDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the YouTube ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
YoutubeDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - YouTubeRead and write YouTube data effortlessly. Integrate, manage, and automate videos, playlists, channels, and analytics — almost no coding required.YoutubeDSN
YoutubeDSN(the one we used in the Data Gateway):YoutubeDSNYoutubeDSN
Finally, we are ready to read data from YouTube in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to YouTube data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to YouTube in Power BI and integrate your data — all without writing complex code.
