You can connect to your Smartsheet data from Power BI via the high-performance Smartsheet ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Smartsheet
  • Working with Smartsheet data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Smartsheet Connector.
Create data source using Smartsheet ODBC Driver
To get data from Smartsheet using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Smartsheet" from the list of Popular Connectors. If "Smartsheet" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    SmartsheetDSN
    Smartsheet
    • Configure the authentication in Smartsheet.
    OAuth (Dynamic Token)
    Smartsheet authentication
    OAuth Walkthrough
    Apps connect to Smartsheet using OAuth 2.0 to authenticate and authorize users. If you are building an app, this documentation will walk you through the steps you need to authenticate your users. The Smartsheet SDKs contain APIs for OAuth 2.0.
    NOTE: For users of apps like AWS AppFabric, you will need a Tenant ID. You can find your Tenant ID in Admin Center under Security & Controls. There is a Smartsheet Tenant ID pane.
    First Steps
    Before you can start using OAuth 2.0 with your app, Smartsheet needs the following information:
    1. You must register with Smartsheet to get a developer account*. The developer account gives you access to "Developer Tools", which is where you manage your app.
    2. In "Developer Tools", complete any required fields in your developer profile.
    3. In "Developer Tools", register your app so Smartsheet can assign a client Id and a client secret to the app.
    4. Review the list of access scopes. You'll need to choose which ones your app needs to get to a user's Smartsheet data, and then ask the user to consent to that access.
    5. After you've worked through these steps, you'll be ready to implement the OAuth Flow.
    Open Developer Tools
    1. Log in to Smartsheet with your developer account.
    2. Click the "Account" button in the lower-left corner of your Smartsheet screen, and then click "Developer Tools".
    3. Do one of the following:
      • If you need to register an app, click "Create New App".
      • If you need to manage an app, click "view/edit" for the app.
    Register Your App Using Developer Tools
    2. Click the "Account" button in the upper-right corner of your Smartsheet screen, and then click "Developer Tools".
    3. In the "Create New App" form, provide the following information:
      • Name: the name the user sees to identify your app
      • Description: a brief description intended for the user
      • URL: the URL to launch your app, or the landing page if not a web app
      • Contact/support: support information for the user
      • Redirect URL: also known as a callback URL. The URL within your application that will receive the OAuth 2.0 credentials After you click "Save", Smartsheet assigns a client Id and secret to your app. Make a note of these Ids for the next steps; however, you can always look them up again in "Developer Tools".
    1. Set Authentication Type to OAuth (Dynamic Token) [OAuth]
    SmartsheetDSN
    Smartsheet
    https://api.smartsheet.com/2.0
    RetryStatusCodeList 429|503
    Find full details in the Smartsheet Connector authentication reference.
    Static Token
    Raw Token Requests
    If you want to get started quickly, or are developing a standalone application that can run with your credentials, follow these instructions:
    1. Click the "Account" button in the lower-left corner of the Smartsheet screen, and then click "Personal Settings".
    2. Click the "API Access" tab.
    3. Click the "Generate new access token" button to obtain an access token.
    The access token must be sent with every API call in an HTTP authorization header (except for therequests to Get Access Token or Refresh Access Token). Once you have an access token, include it in the Authorization header for every request you make:
    Authorization: Bearer JKlMNOpQ12RStUVwxYZAbcde3F5g6hijklM789
    The header name is Authorization and the value of the header is Bearer JKlMNOpQ12RStUVwxYZAbcde3F5g6hijklM789. Since the access token is being transmitted in clear text, all API calls are done over HTTPS.
    NOTE: A best practice is to use a shared account, such as ticket-processor@example.com, rather than your individual work account.
    1. Set Authentication Type to Static Token [Http]
    SmartsheetDSN
    Smartsheet
    Static Token [Http]
    Access Token Fill-in the parameter...
    ZappySys API Driver - Smartsheet
    Read and write Smartsheet data effortlessly. Integrate, manage, and automate sheets, rows, and reports — almost no coding required.
    SmartsheetDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Smartsheet. Hit OK button to use this query in the next step.
    SELECT * FROM Sheets --Where Id='5815807987847055'
    Some parameters configured in this window will be passed to the Smartsheet API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    SmartsheetDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Smartsheet API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Smartsheet servers).
Connect to Smartsheet data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose SmartsheetDSN and continue:
    SmartsheetDSN
    SmartsheetDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Smartsheet in a Power BI report:
If you wish to import Smartsheet data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
SmartsheetDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Smartsheet ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=SmartsheetDSN"}
    dsn=SmartsheetDSN
    dsn=SmartsheetDSN
    = Odbc.Query("dsn=SmartsheetDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Smartsheet data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Smartsheet Service
    SELECT * FROM OPENQUERY([LS_TO_SMARTSHEET_IN_GATEWAY], 'SELECT * FROM Sheets --Where Id=''5815807987847055''')
    DirectQuery option for Power BI (read Smartsheet data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Smartsheet data is now linked live rather than imported.
    SmartsheetDSN
    SmartsheetDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://api.smartsheet.com/2.0;ScopeSeparator={space};AuthorizeInFullBrowser=True;ReturnUrl=https://zappysys.com/oauth;AuthUrl=https://app.smartsheet.com/b/authorize;TokenUrl=https://api.smartsheet.com/2.0/token;Scope=[$Scope$];UseCustomApp=True;
Smartsheet Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Smartsheet operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Smartsheet data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Smartsheet data source in the gateway
In this section we will create a data source for Smartsheet in the Data Gateway. Let's follow these steps to accomplish that:
    SmartsheetDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Smartsheet ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      SmartsheetDSN
      SmartsheetDSN
      SmartsheetDSN
  5. Then set the default database property to SmartsheetDSN (the one we used in the Data Gateway):
    SmartsheetDSN
    SmartsheetDSN
Finally, we are ready to read data from Smartsheet in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Smartsheet data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Smartsheet in Power BI and integrate your data — all without writing complex code.
