You can connect to your Amazon Selling Partner (SP-API) data from Power BI via the high-performance Amazon Selling Partner (SP-API) ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Amazon Selling Partner (SP-API)
- Working with Amazon Selling Partner (SP-API) data directly inside Power BI
Create data source using Amazon Selling Partner (SP-API) ODBC Driver
To get data from Amazon Selling Partner (SP-API) using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Amazon Selling Partner (SP-API)" from the list of Popular Connectors. If "Amazon Selling Partner (SP-API)" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
AmazonSellingPartnerSpApiDSNAmazon Selling Partner (SP-API)
- Configure the authentication in Amazon Selling Partner (SP-API).
Private app
Amazon Selling Partner (SP-API) authentication
Amazon Sellers can use SP-API to set up private integrations and build solutions exclusively for their Amazon store. Private app is available only to your organization and is self-authorized. A private developer builds application(s) that integrate their own company with Amazon APIs. [API reference]
Perform the following steps to authenticate calls using Amazon SP-API Private app:
- Register as an Amazon Private SP-API Developer. You may need to wait for a day or two to get approved (check approval status).
Once your developer account is approved,
login to your account, visit developer console
and click Add new app client button to create a Private app:
Continue by naming your application in the App name field,
choose
SP APIas API Type, and select the Roles for your app (i.e. permissions):
Once you do that, click View link in LWA credentials column to
copy Client identifier and Client secret (we will use them later):
Now it's time to Authorize your app:
Finish authorizing it by presing Authorize app button:
Finally, copy the Refresh Token (we will use it in the next step):
Now go to SSIS package or ODBC data source and use Private app authentication configuration:
- In the ClientId field paste the Client identifier value you copied in the previous step.
- In the ClientSecret field paste the Client secret value you copied in the previous step.
- Leave the default value in the TokenUrl field.
- In the Refresh Token field paste the Refresh Token value you copied in the previous step.
- Done! Now you are ready to use Amazon Selling Partner (SP-API) Connector!
Private app [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
AmazonSellingPartnerSpApiDSNAmazon Selling Partner (SP-API)Private app [OAuth]https://sellingpartnerapi-na.amazon.comRequired Parameters ClientId Fill-in the parameter... ClientSecret Fill-in the parameter... TokenUrl Fill-in the parameter... Optional Parameters TokenUIMode OnlyRefreshToken AuthUrl (Do not Use for Private app - Self Authorization) https://sellercentral.amazon.com/apps/authorize/consent?application_id=[YOUR-APPLICATION-ID]&version=beta OrdersApiVersion v0 SellerApiVersion v1 ShippingApiVersion v1 ServicesApiVersion v1 FbaApiVersion v1 SalesApiVersion v1 ReportsApiVersion 2021-06-30 ProductsFeesApiVersion v0 ProductPricingApiVersion v0 CatalogItemsApiVersion 2022-04-01 VendorOrdersApiVersion v1 RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Amazon Selling Partner (SP-API) Connector authentication reference. -
ZappySys API Driver - Amazon Selling Partner (SP-API)Read and write Amazon Selling Partner (SP-API) data effortlessly. Integrate, manage, and automate listings, orders, payments, and reports — almost no coding required.AmazonSellingPartnerSpApiDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Amazon Selling Partner (SP-API). Hit OK button to use this query in the next step.
SELECT * FROM Orders --WHERE AmazonOrderId='902-1845936-5435065' WITH( CreatedAfter='1900-01-01T00:00:00' -- , CreatedBefore='1900-01-01T00:00:00' -- , LastUpdatedAfter='1900-01-01T00:00:00' -- , LastUpdatedBefore='1900-01-01T00:00:00' -- , OrderStatuses='Pending~Unshipped~PartiallyShipped~PendingAvailability~Shipped~Canceled~Unfulfillable' -- , MarketplaceIds='ATVPDKIKX0DER~A2Q3Y263D00KWC~A2EUQ1WTGCTBG2' -- , FulfillmentChannels='AFN~MFN' -- , PaymentMethods='COD~CVS~Other' -- , AmazonOrderIds='1111111,222222,333333' ) --CONNECTION( -- ServiceUrl='https://sellingpartnerapi-na.amazon.com' --)
Some parameters configured in this window will be passed to the Amazon Selling Partner (SP-API) API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - Amazon Selling Partner (SP-API)Read and write Amazon Selling Partner (SP-API) data effortlessly. Integrate, manage, and automate listings, orders, payments, and reports — almost no coding required.AmazonSellingPartnerSpApiDSNSELECT * FROM Orders --WHERE AmazonOrderId='902-1845936-5435065' WITH( CreatedAfter='1900-01-01T00:00:00' -- , CreatedBefore='1900-01-01T00:00:00' -- , LastUpdatedAfter='1900-01-01T00:00:00' -- , LastUpdatedBefore='1900-01-01T00:00:00' -- , OrderStatuses='Pending~Unshipped~PartiallyShipped~PendingAvailability~Shipped~Canceled~Unfulfillable' -- , MarketplaceIds='ATVPDKIKX0DER~A2Q3Y263D00KWC~A2EUQ1WTGCTBG2' -- , FulfillmentChannels='AFN~MFN' -- , PaymentMethods='COD~CVS~Other' -- , AmazonOrderIds='1111111,222222,333333' ) --CONNECTION( -- ServiceUrl='https://sellingpartnerapi-na.amazon.com' --)
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Amazon Selling Partner (SP-API) API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Amazon Selling Partner (SP-API) servers). -
Connect to Amazon Selling Partner (SP-API) data in Power BI
Another window opens and asks to select a Data Source we already created. Choose AmazonSellingPartnerSpApiDSN and continue:
Finally, finally, read extracted data from Amazon Selling Partner (SP-API) in a Power BI report:
If you wish to import Amazon Selling Partner (SP-API) data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Amazon Selling Partner (SP-API) ODBC data source:
ODBC{"connectionstring":"dsn=AmazonSellingPartnerSpApiDSN"}
= Odbc.Query("dsn=AmazonSellingPartnerSpApiDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Amazon Selling Partner (SP-API) data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_AMAZON_SELLING_PARTNER_SP_API_IN_GATEWAY], 'SELECT * FROM Orders --WHERE AmazonOrderId=''902-1845936-5435065'' WITH( CreatedAfter=''1900-01-01T00:00:00'' -- , CreatedBefore=''1900-01-01T00:00:00'' -- , LastUpdatedAfter=''1900-01-01T00:00:00'' -- , LastUpdatedBefore=''1900-01-01T00:00:00'' -- , OrderStatuses=''Pending~Unshipped~PartiallyShipped~PendingAvailability~Shipped~Canceled~Unfulfillable'' -- , MarketplaceIds=''ATVPDKIKX0DER~A2Q3Y263D00KWC~A2EUQ1WTGCTBG2'' -- , FulfillmentChannels=''AFN~MFN'' -- , PaymentMethods=''COD~CVS~Other'' -- , AmazonOrderIds=''1111111,222222,333333'' ) --CONNECTION( -- ServiceUrl=''https://sellingpartnerapi-na.amazon.com'' --)')
SELECT * FROM OPENQUERY([LS_TO_AMAZON_SELLING_PARTNER_SP_API_IN_GATEWAY], 'SELECT * FROM Orders --WHERE AmazonOrderId=''902-1845936-5435065'' WITH( CreatedAfter=''1900-01-01T00:00:00'' -- , CreatedBefore=''1900-01-01T00:00:00'' -- , LastUpdatedAfter=''1900-01-01T00:00:00'' -- , LastUpdatedBefore=''1900-01-01T00:00:00'' -- , OrderStatuses=''Pending~Unshipped~PartiallyShipped~PendingAvailability~Shipped~Canceled~Unfulfillable'' -- , MarketplaceIds=''ATVPDKIKX0DER~A2Q3Y263D00KWC~A2EUQ1WTGCTBG2'' -- , FulfillmentChannels=''AFN~MFN'' -- , PaymentMethods=''COD~CVS~Other'' -- , AmazonOrderIds=''1111111,222222,333333'' ) --CONNECTION( -- ServiceUrl=''https://sellingpartnerapi-na.amazon.com'' --)') - Click OK and load the data. Your Amazon Selling Partner (SP-API) data is now linked live rather than imported.
AmazonSellingPartnerSpApiDSNDRIVER={ZappySys API Driver};ServiceUrl=https://sellingpartnerapi-na.amazon.com;ScopeSeparator={space};UseCustomApp=True;CustomAuthHeader=x-amz-access-token;AccessToken=fake
Amazon Selling Partner (SP-API) Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Amazon Selling Partner (SP-API) operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Download Report File to Local Disk
- Get Report Data - Tab Separated File (TSV)
- Get Report Data - Comma Separated File (CSV)
- Get Report Data - XML File
- Get Report Data - JSON File
- Get Report Options
- Get Report Filters
- Get FBA Inventory Summaries (Fulfilled By Amazon)
- Search Catalog Items
- Get Report Types
- Get Market Place Participations
- Get Vendor PurchaseOrders
- Get Vendor PurchaseOrder Items
- Get Orders
- Get Order (Single)
- Get Order Items (For Single Order)
- Get Orders Items (For All Orders **Slow**)
In some situations, you may need to provide Amazon Selling Partner (SP-API) data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Amazon Selling Partner (SP-API) data source in the gateway
In this section we will create a data source for Amazon Selling Partner (SP-API) in the Data Gateway. Let's follow these steps to accomplish that:
AmazonSellingPartnerSpApiDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Amazon Selling Partner (SP-API) ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
AmazonSellingPartnerSpApiDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Amazon Selling Partner (SP-API)Read and write Amazon Selling Partner (SP-API) data effortlessly. Integrate, manage, and automate listings, orders, payments, and reports — almost no coding required.AmazonSellingPartnerSpApiDSN
AmazonSellingPartnerSpApiDSN(the one we used in the Data Gateway):AmazonSellingPartnerSpApiDSNAmazonSellingPartnerSpApiDSN
Finally, we are ready to read data from Amazon Selling Partner (SP-API) in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Amazon Selling Partner (SP-API) data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Amazon Selling Partner (SP-API) in Power BI and integrate your data — all without writing complex code.
