You can connect to your Amazon Ads data from Power BI via the high-performance Amazon Ads ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Amazon Ads
  • Working with Amazon Ads data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Amazon Ads Connector.
Create data source using Amazon Ads ODBC Driver
To get data from Amazon Ads using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Amazon Ads" from the list of Popular Connectors. If "Amazon Ads" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    AmazonAdsDSN
    Amazon Ads
    • Configure the authentication in Amazon Ads.
    OAuth Authentication
    Amazon Ads authentication
    Amazon OAuth Security Profile has be created in Amazon Developer portal. [API reference]
    1. Firstly, login into Amazon Developer portal in https://developer.amazon.com.
    2. Then click Sign in.
    3. If you don't have an account, press Create your Amazon Developer account button to create one.
    4. Once logged in, click on your profile icon on the right-top of the window and hit Settings:
      Amazon developer profile settings
    5. Then click Security Profiles and proceed with creating a new Security Profile:
      Create Amazon developer security profile
    6. After that, click Web Settings subtab, then hit Show Secret button to reveal the Client Secret (you will need it later), and click Edit to add a Redirect URL:
      Reveal client secret in Amazon developer security profile
    7. Continue by setting Allowed Return URLs (you can have your own or use https://zappysys.com/oauth):
      Set return URLs in Amazon developer security profile
    8. Done! Now you can use Client ID, Client Secret, and Redirect URL when configuring OAuth Authentication parameters:
      Use client ID and client secret to connect to REST API Amazon services
    1. Set Authentication Type to OAuth Authentication [OAuth]
    AmazonAdsDSN
    Amazon Ads
    https://advertising-api.amazon.com/v2
    AuthorizationUrl Fill-in the parameter...
    Profile (click 'Generate Token' before this) Fill-in the parameter...
    Find full details in the Amazon Ads Connector authentication reference.
    ZappySys API Driver - Amazon Ads
    Read and write Amazon Ads data effortlessly. Integrate, manage, and automate campaigns, ad groups, and performance metrics — almost no coding required.
    AmazonAdsDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Amazon Ads. Hit OK button to use this query in the next step.
    SELECT * FROM Profiles
    Some parameters configured in this window will be passed to the Amazon Ads API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    AmazonAdsDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Amazon Ads API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Amazon Ads servers).
Connect to Amazon Ads data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose AmazonAdsDSN and continue:
    AmazonAdsDSN
    AmazonAdsDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Amazon Ads in a Power BI report:
If you wish to import Amazon Ads data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
AmazonAdsDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Amazon Ads ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=AmazonAdsDSN"}
    dsn=AmazonAdsDSN
    dsn=AmazonAdsDSN
    = Odbc.Query("dsn=AmazonAdsDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Amazon Ads data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Amazon Ads Service
    SELECT * FROM OPENQUERY([LS_TO_AMAZON_ADS_IN_GATEWAY], 'SELECT * FROM Profiles')
    DirectQuery option for Power BI (read Amazon Ads data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Amazon Ads data is now linked live rather than imported.
    AmazonAdsDSN
    AmazonAdsDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://advertising-api.amazon.com/v2;Provider=Custom;OAuthVersion=OAuth2;AuthUrl=[$AuthorizationUrl$];ClientId=[$AppId$];Scope=[$Scope$];TokenUrl=https://api.amazon.com/auth/o2/token;ScopeSeparator={space};ContentType=application/x-www-form-urlencoded;
Amazon Ads Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Amazon Ads operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Amazon Ads data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Amazon Ads data source in the gateway
In this section we will create a data source for Amazon Ads in the Data Gateway. Let's follow these steps to accomplish that:
    AmazonAdsDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Amazon Ads ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      AmazonAdsDSN
      AmazonAdsDSN
      AmazonAdsDSN
  5. Then set the default database property to AmazonAdsDSN (the one we used in the Data Gateway):
    AmazonAdsDSN
    AmazonAdsDSN
Finally, we are ready to read data from Amazon Ads in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Amazon Ads data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Amazon Ads in Power BI and integrate your data — all without writing complex code.
