You can connect to your Mailchimp data from Power BI via the high-performance Mailchimp ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Mailchimp
- Working with Mailchimp data directly inside Power BI
Create data source using Mailchimp ODBC Driver
To get data from Mailchimp using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Mailchimp" from the list of Popular Connectors. If "Mailchimp" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
MailchimpDSNMailchimp
- Configure the authentication in Mailchimp.
Mailchimp authentication
To get the credentials you need in order to set up your OAuth workflow, you'll first need to register your application with Mailchimp:-
Login into your Mailchimp account, click on your Profile Icon, and hit Account & billing:
Navigate to the Registered Apps page in your Mailchimp account:
Click Register An App button:
Fill-in the Register An App form and click Create button:
NOTE: For Redirect URI use Redirect URI (also called "Redirect URL" or "Callback URL") given by your IT administrator or just usehttps://zappysys.com/oauth, if you don't have one. -
After successfully registering your application,
you'll see the Client ID and Client Secret,
record these values and store them securely:
Record your Mailchimp data center, since we will need it later.
The data center is located in your browser's address bar URL.
If the URL is
https://us21.admin.mailchimp.com/account/api, then your data center isus21. - Now go to SSIS package or ODBC data source OAuth authentication configuration.
- Proceed by entering the data center into the Data Center field that was recorded in the previous step.
- Then enter the Client ID value into the Client ID field that you recorded in the previous step.
- Enter the Client Secret value into the Client Secret field that was recorded in the previous step.
- Click Generate Token. If proper authentication occurs, you will see a confirmation notice. If you get an error, click Yes on the dialog box and then a large browser window will launch. Then log into your Mailchimp account and approve the use of the application.
- Finally, hit the Test Connection button at the bottom of the window to verify proper connectivity with your Mailchimp account.
- If the connection test succeeds, select OK.
- Done! Now you can use Mailchimp Connector!
MailchimpDSNMailchimpOAuth [OAuth]https://[$DataCenter$].api.mailchimp.comRequired Parameters Data Center Fill-in the parameter... Client Id Fill-in the parameter... Client Secret Fill-in the parameter... Default List Id Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Mailchimp Connector authentication reference.ApiKey Auth
The simplest way to authenticate a request to the Mailchimp Marketing API is by using an API key (If you require access to Mailchimp on behalf of other Mailchimp users, you'll want to set up OAuth authentication instead)::-
Navigate to the API keys page in your Mailchimp account:
In the Your API keys section of the page, click Create A Key button:
Give your new key a descriptive name that will remind you which application it's used for:
Copy the API key immediately and store it in a secure location (you won't be able to see or copy the key once you finish generating it):
If the URL is
https://us21.admin.mailchimp.com/account/api, then your data center isus21. - Now go to SSIS package or ODBC data source ApiKey Auth authentication configuration.
- Then enter the API key into the Api Key field that you copied earlier.
- Finally, click the Test Connection button at the bottom of the window to verify proper connectivity with your Mailchimp account.
ApiKey Auth [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
MailchimpDSNMailchimpApiKey Auth [Http]https://[$DataCenter$].api.mailchimp.comRequired Parameters Api Key Fill-in the parameter... Default List Id Fill-in the parameter... Optional Parameters Data Center RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Mailchimp Connector authentication reference. -
ZappySys API Driver - MailchimpRead and write Mailchimp data effortlessly. Integrate, manage, and automate campaigns, lists, members, and reports — almost no coding required.MailchimpDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Mailchimp. Hit OK button to use this query in the next step.
SELECT * FROM Campaigns
Some parameters configured in this window will be passed to the Mailchimp API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - MailchimpRead and write Mailchimp data effortlessly. Integrate, manage, and automate campaigns, lists, members, and reports — almost no coding required.MailchimpDSNSELECT * FROM Campaigns
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Mailchimp API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Mailchimp servers). -
Connect to Mailchimp data in Power BI
Another window opens and asks to select a Data Source we already created. Choose MailchimpDSN and continue:
MailchimpDSN
MailchimpDSN
Finally, finally, read extracted data from Mailchimp in a Power BI report:
If you wish to import Mailchimp data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Mailchimp ODBC data source:
ODBC{"connectionstring":"dsn=MailchimpDSN"}
dsn=MailchimpDSN
dsn=MailchimpDSN
= Odbc.Query("dsn=MailchimpDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Mailchimp data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_MAILCHIMP_IN_GATEWAY], 'SELECT * FROM Campaigns')
SELECT * FROM OPENQUERY([LS_TO_MAILCHIMP_IN_GATEWAY], 'SELECT * FROM Campaigns') - Click OK and load the data. Your Mailchimp data is now linked live rather than imported.
MailchimpDSNDRIVER={ZappySys API Driver};ServiceUrl=https://[$DataCenter$].api.mailchimp.com;Provider=MailChimp;ScopeSeparator={space};
Mailchimp Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Mailchimp operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get User Details
- Get List of Campaigns
- Get Campaign Details
- Add New List
- Get Lists
- Get List Details
- Delete List
- Update List Details
- Add New List Member
- Add or Update Upsert List Members (Bulk Subscribe or Unsubscribe)
- Add New List Members in Bulk
- Get List Members
- Get All Members in All Lists
- Get a Specific Member From All Lists
- Get List Member Details
- Delete List Member (Archive)
- Delete List Member (Permanent delete)
- Update List Member Details
In some situations, you may need to provide Mailchimp data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Mailchimp data source in the gateway
In this section we will create a data source for Mailchimp in the Data Gateway. Let's follow these steps to accomplish that:
MailchimpDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Mailchimp ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
MailchimpDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - MailchimpRead and write Mailchimp data effortlessly. Integrate, manage, and automate campaigns, lists, members, and reports — almost no coding required.MailchimpDSN
MailchimpDSN(the one we used in the Data Gateway):MailchimpDSNMailchimpDSN
Finally, we are ready to read data from Mailchimp in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Mailchimp data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Mailchimp in Power BI and integrate your data — all without writing complex code.
