You can connect to your FTP/SFTP JSON File data from Power BI via the high-performance FTP/SFTP JSON File ODBC Driver. We'll walk you through the entire setup.
Create data source using FTP/SFTP JSON File ODBC Driver
To get data from FTP/SFTP JSON File using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
Create a User data source (User DSN) based on the ZappySys SFTP JSON Driver driver:
Create and configure a connection for the FTP/SFTP storage account.
You can use select your desired single file by clicking [...] path button.
mybucket/dbo.tblNames.jsondbo.tblNames.json
----------OR----------You can also read the multiple files stored in FTP/SFTP Storage using wildcard pattern supported e.g. dbo.tblNames*.json.
Note: If you want to operation with multiple files then use wild card pattern as below (when you use wild card pattern in source path then system will treat target path as folder regardless you end with slash) mybucket/dbo.tblNames.json (will read only single .JSON file) mybucket/dbo.tbl*.json (all files starting with file name) mybucket/*.json (all files with .json Extension and located under folder subfolder)
mybucket/dbo.tblNames*.json
----------OR----------You can also read the zip and gzip compressed files also without extracting it in using FTP/SFTP JSON Source File Task.
mybucket/dbo.tblNames*.gz
Now select/enter Path expression in Path textbox to extract only specific part of JSON string as below ($.value[*] will get content of value attribute from JSON document. Value attribute is array of JSON documents so we have to use [*] to indicate we want all records of that array)
NOTE: Here, We are using our desired filter, but you need to select your desired filter based on your requirement.Go to Preview Tab.
Navigate to the Preview Tab and let's explore the different modes available to access the data.
--- Using Direct Query ---
Click on Preview Tab, Select Table from Tables Dropdown and select [value] and click Preview.
--- Using Stored Procedure ---
Note : For this you have to Save ODBC Driver configuration and then again reopen to configure same driver. For more information click here.Click on the Custom Objects Tab, Click on Add button and select Add Procedure and Enter an appropriate name and Click on OK button to create.
--- Without Parameters ---
Now Stored Procedure can be created with or without parameters (see example below). If you use parameters then Set default value otherwise it may fail to compilation)
--- With Parameters ---
Note : Here you can use Placeholder with Paramters in Stored Procedure. Example : SELECT * FROM $ WHERE OrderID = '<@OrderID, FUN_TRIM>' or CustId = '<@CustId>' and Total >= '<@Total>'
--- Using Virtual Table ---
Note : For this you have to Save ODBC Driver configuration and then again reopen to configure same driver. For more information click here.ZappySys APi Drivers support flexible Query language so you can override Default Properties you configured on Data Source such as URL, Body. This way you don't have to create multiple Data Sources if you like to read data from multiple EndPoints. However not every application support supplying custom SQL to driver so you can only select Table from list returned from driver.
Many applications like MS Access, Informatica Designer wont give you option to specify custom SQL when you import Objects. In such case Virtual Table is very useful. You can create many Virtual Tables on the same Data Source (e.g. If you have 50 Buckets with slight variations you can create virtual tables with just URL as Parameter setting).
vt__Customers DataPath=mybucket_1/customers.json vt__Orders DataPath=mybucket_2/orders.json vt__Products DataPath=mybucket_3/products.json
Click on the Custom Objects Tab, Click on Add button and select Add Table and Enter an appropriate name and Click on OK button to create.
Once you see Query Builder Window on screen Configure it.
Click on Preview Tab, Select Virtual Table(prefix with vt__) from Tables Dropdown or write SQL query with Virtual Table name and click Preview.
That's it; we are done. In a few clicks we configured the to Read the FTP/SFTP JSON File data using ZappySys FTP/SFTP JSON File Connector
Connect to FTP/SFTP JSON File data in Power BI
Another window opens and asks to select a Data Source we already created. Choose FtpSftpJsonFileDSN and continue:
FtpSftpJsonFileDSN
FtpSftpJsonFileDSN
Finally, finally, read extracted data from FTP/SFTP JSON File in a Power BI report:
If you wish to import FTP/SFTP JSON File data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ProductID,
ProductName,
SupplierID,
CategoryID,
QuantityPerUnit,
UnitPrice
FROM _root_
WHERE UnitPrice > 20
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local FTP/SFTP JSON File ODBC data source:
ODBC{"connectionstring":"dsn=FtpSftpJsonFileDSN"}
= Odbc.Query("dsn=FtpSftpJsonFileDSN", "SELECT * FROM _root_ WITH (SRC='http://my-api-provider.com/api/" & MyParameter & "/items')")
By default, Power BI imports FTP/SFTP JSON File data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_FTP_SFTP_JSON_FILE_IN_GATEWAY], 'SELECT * FROM Orders')
SELECT * FROM OPENQUERY([LS_TO_FTP_SFTP_JSON_FILE_IN_GATEWAY], 'SELECT * FROM Orders') - Click OK and load the data. Your FTP/SFTP JSON File data is now linked live rather than imported.
ZappySys SFTP JSON Driver - FTP/SFTP JSON FileRead and write JSON files over FTP/SFTP effortlessly. Streamline, manage, and automate JSON files on FTP and SFTP for analytics, reporting, and data pipelines — almost no coding required.FtpSftpJsonFileDSN
FtpSftpJsonFileDSNDRIVER={ZappySys SFTP JSON Driver};DataPath='/my-folder/file-*.json';EncryptionMode='TlsSslImplicit';ServerName='101.102.203.204';IgnoreCertificateErrors=1;UserName='my-user-name';Password='my-password'
In some situations, you may need to provide FTP/SFTP JSON File data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create FTP/SFTP JSON File data source in the gateway
In this section we will create a data source for FTP/SFTP JSON File in the Data Gateway. Let's follow these steps to accomplish that:
- Then select Native - ZappySys SFTP JSON Driver
FtpSftpJsonFileDSNZappySys SFTP JSON Driver
When the ZappySys SFTP JSON Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the FTP/SFTP JSON File ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
FtpSftpJsonFileDSN
ZappySys SFTP JSON Driver - Configuration [Version: 2.0.1.10418]ZappySys SFTP JSON Driver - FTP/SFTP JSON FileRead and write JSON files over FTP/SFTP effortlessly. Streamline, manage, and automate JSON files on FTP and SFTP for analytics, reporting, and data pipelines — almost no coding required.FtpSftpJsonFileDSN
FtpSftpJsonFileDSN(the one we used in the Data Gateway):FtpSftpJsonFileDSNFtpSftpJsonFileDSN
Finally, we are ready to read data from FTP/SFTP JSON File in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to FTP/SFTP JSON File data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to FTP/SFTP JSON File in Power BI and integrate your data — all without writing complex code.
