You can connect to your Neo4j data from Power BI via the high-performance Neo4j ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Neo4j
  • Working with Neo4j data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Neo4j.
Download Neo4j JDBC driver
To connect to Neo4j, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Neo4j website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar.
Create data source using Neo4j ODBC Driver
To get data from Neo4j using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Neo4j.
    Non-SSL Connection (SQL queries)
    Neo4j authentication
    Neo4j JDBC (full bundle) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. This Auth sets enableSQLTranslation=true so you can run SQL such as SELECT * FROM Movie from Power BI.
    2. Create a database user in Neo4j Desktop, Aura console, or CREATE USER. Paste user and password.
    3. After Finish, replace the host (e.g. MyHostName) on the DSN Main UI. Aura always uses TLS (neo4j+s).
    4. Do not use a personal employee login for unattended Linked Server or Power BI refresh.
    3. Finally, hit OK button:
    • Connection string: jdbc:neo4j://[$HostName$]:[$Port$]?enableSQLTranslation=true
    • Driver class: org.neo4j.jdbc.Neo4jDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Find full details in the Neo4j Connector authentication reference.
    Non-SSL Connection (Cypher queries)
    1. This Auth omits SQL translation. Use Cypher (MATCH ... RETURN) from the DSN query window.
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    • Connection string: jdbc:neo4j+s://[$HostName$]:[$Port$]?enableSQLTranslation=true
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    • Host: MyHostName
    • TCP port: 7687
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Neo4j AuraDB Connection (SQL queries)
    1. Copy the Aura connection URI host (something like 1234abcd.databases.neo4j.io). This Auth uses neo4j+s plus SQL translation.
    • Connection string: jdbc:neo4j+s://[$HostName$]?enableSQLTranslation=true
    • Host: MyHostName
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Neo4j Aura Connection (Cypher queries)
    1. Same Aura host as SQL Auth, but Cypher only (no SQL translation).
    • Host: MyHostName
    • User name:
    • Password:
    Neo4jDSN
    optional for Neo4j
    Jump to troubleshooter
    Neo4jDSN
    SELECT * FROM Movie
    SELECT * FROM Movie
Connect to Neo4j data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose Neo4jDSN and continue:
    Neo4jDSN
    Neo4jDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Neo4j in a Power BI report:
If you wish to import Neo4j data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Neo4jDSN
SELECT * FROM Movie
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Neo4j ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=Neo4jDSN"}
    dsn=Neo4jDSN
    dsn=Neo4jDSN
    = Odbc.Query("dsn=Neo4jDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Neo4j data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Neo4j Service
    SELECT * FROM OPENQUERY([LS_TO_NEO4J_IN_GATEWAY], 'SELECT * FROM Movie')
    DirectQuery option for Power BI (read Neo4j data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Neo4j data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Neo4j
    Query Neo4j graphs with SQL or Cypher from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    Neo4jDSN
    Neo4jDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:neo4j://[$HostName$]:[$Port$]?enableSQLTranslation=true';ClassName='org.neo4j.jdbc.Neo4jDriver';DriverPath='C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar';UserName='';UserPassword='';ConnParams='optional for Neo4j'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.neo4j.jdbc.Neo4jDriver):
  6. Go to the Libraries tab, click Add File, and select your Neo4j driver library file(s), e.g. C:\ZappySys\Jdbc\Neo4j\neo4j-jdbc-full-bundle-6.3.1.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:neo4j://[$HostName$]:[$Port$]?enableSQLTranslation=true), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Neo4j data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Neo4j data source in the gateway
In this section we will create a data source for Neo4j in the Data Gateway. Let's follow these steps to accomplish that:
    Neo4jDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Neo4j ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      Neo4jDSN
      Neo4jDSN
      Neo4jDSN
  5. Then set the default database property to Neo4jDSN (the one we used in the Data Gateway):
    Neo4jDSN
    Neo4jDSN
Finally, we are ready to read data from Neo4j in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Neo4j data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Neo4j in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Neo4j, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
