You can connect to your ClickHouse data from Power BI via the high-performance ClickHouse ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to ClickHouse
  • Working with ClickHouse data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for ClickHouse.
Download ClickHouse JDBC driver
To connect to ClickHouse, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit ClickHouse website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar.
Create data source using ClickHouse ODBC Driver
To get data from ClickHouse using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in ClickHouse.
    HTTP
    ClickHouse authentication
    ClickHouse HTTP JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Copy the ClickHouse HTTP host and port (default 8123).
    2. Create a user (CREATE USER) with access to the database. Paste user and password.
    3. Use the HTTPS Auth when the endpoint is TLS (often Cloud, port 8443).
    3. Finally, hit OK button:
    • Connection string: jdbc:clickhouse://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: com.clickhouse.jdbc.ClickHouseDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar
    • Host: MyHostName
    • TCP port: 8123
    • Database name: MyDatabase
    • User name:
    • Password:
    ClickhouseDSN
    optional for ClickHouse
    Find full details in the ClickHouse Connector authentication reference.
    HTTPS
    ClickHouse HTTPS JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Use the Cloud or TLS HTTP interface (often port 8443).
    2. Create a user in the ClickHouse Cloud console. Paste user and password.
    3. Do not disable TLS on Cloud.
    • Connection string: jdbc:clickhouse:https://[$HostName$]:[$Port$]/[$Database$]
    • Host: MyHostName
    • TCP port: 8443
    • User name:
    • Password:
    ClickhouseDSN
    Jump to troubleshooter
    ClickhouseDSN
    SHOW TABLES
    SHOW TABLES
Connect to ClickHouse data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ClickhouseDSN and continue:
    ClickhouseDSN
    ClickhouseDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from ClickHouse in a Power BI report:
If you wish to import ClickHouse data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ClickhouseDSN
SHOW TABLES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local ClickHouse ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ClickhouseDSN"}
    dsn=ClickhouseDSN
    dsn=ClickhouseDSN
    = Odbc.Query("dsn=ClickhouseDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports ClickHouse data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from ClickHouse Service
    SELECT * FROM OPENQUERY([LS_TO_CLICKHOUSE_IN_GATEWAY], 'SHOW TABLES')
    DirectQuery option for Power BI (read ClickHouse data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your ClickHouse data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - ClickHouse
    Query ClickHouse with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ClickhouseDSN
    ClickhouseDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:clickhouse://[$HostName$]:[$Port$]/[$Database$]';ClassName='com.clickhouse.jdbc.ClickHouseDriver';DriverPath='C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar';UserName='';UserPassword='';ConnParams='optional for ClickHouse'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (com.clickhouse.jdbc.ClickHouseDriver):
  6. Go to the Libraries tab, click Add File, and select your ClickHouse driver library file(s), e.g. C:\ZappySys\Jdbc\ClickHouse\clickhouse-jdbc-0.9.0-all.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:clickhouse://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide ClickHouse data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create ClickHouse data source in the gateway
In this section we will create a data source for ClickHouse in the Data Gateway. Let's follow these steps to accomplish that:
    ClickhouseDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the ClickHouse ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ClickhouseDSN
      ClickhouseDSN
      ClickhouseDSN
  5. Then set the default database property to ClickhouseDSN (the one we used in the Data Gateway):
    ClickhouseDSN
    ClickhouseDSN
Finally, we are ready to read data from ClickHouse in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to ClickHouse data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to ClickHouse in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to ClickHouse, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
