You can connect to your Apache Phoenix data from Power BI via the high-performance Apache Phoenix ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Phoenix
  • Working with Apache Phoenix data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Phoenix.
Download Apache Phoenix JDBC driver
To connect to Apache Phoenix, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Phoenix website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Phoenix\phoenix-client-embedded-hbase-2.5-5.3.1.jar.
Create data source using Apache Phoenix ODBC Driver
To get data from Apache Phoenix using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Phoenix.
    ZooKeeper (thick client)
    Apache Phoenix authentication
    Apache Phoenix JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Get the ZooKeeper quorum and HBase znode (often /hbase).
    2. This thick client JAR talks to ZK + HBase. Network access to ZK and region servers is required from the DSN host (gateway or Power BI on-prem).
    3. Create a Phoenix user if Kerberos/HBase auth is enabled; otherwise leave user/password empty.
    3. Finally, hit OK button:
    • Connection string: jdbc:phoenix+zk:[$HostName$]:[$Port$]:/hbase
    • Driver class: org.apache.phoenix.jdbc.PhoenixDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Phoenix\phoenix-client-embedded-hbase-2.5-5.3.1.jar
    • Host: MyHostName
    • TCP port: 2181
    • User name:
    • Password:
    ApachePhoenixDSN
    optional for Apache Phoenix
    Find full details in the Apache Phoenix Connector authentication reference.
    Query Server (thin)
    Apache Phoenix Query Server JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Start or locate Phoenix Query Server (default port 8765).
    2. Replace host in the JDBC URL. User/password only if the server requires them.
    • Connection string: jdbc:phoenix:thin:url=http://[$HostName$]:[$Port$]
    • Host: MyHostName
    • TCP port: 2181
    • User name:
    • Password:
    ApachePhoenixDSN
    Jump to troubleshooter
    ApachePhoenixDSN
    SELECT DISTINCT TABLE_NAME FROM SYSTEM.CATALOG WHERE TABLE_TYPE = 'u' ORDER BY TABLE_NAME
Connect to Apache Phoenix data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApachePhoenixDSN and continue:
    ApachePhoenixDSN
    ApachePhoenixDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Phoenix in a Power BI report:
If you wish to import Apache Phoenix data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApachePhoenixDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Phoenix ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApachePhoenixDSN"}
    = Odbc.Query("dsn=ApachePhoenixDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Phoenix data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Phoenix Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_PHOENIX_IN_GATEWAY], 'SELECT DISTINCT TABLE_NAME FROM SYSTEM.CATALOG WHERE TABLE_TYPE = ''u'' ORDER BY TABLE_NAME')
    DirectQuery option for Power BI (read Apache Phoenix data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Phoenix data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Phoenix
    SQL on HBase with Apache Phoenix JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApachePhoenixDSN
    ApachePhoenixDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:phoenix+zk:[$HostName$]:[$Port$]:/hbase';ClassName='org.apache.phoenix.jdbc.PhoenixDriver';DriverPath='C:\ZappySys\Jdbc\Apache Phoenix\phoenix-client-embedded-hbase-2.5-5.3.1.jar';UserName='';UserPassword='';ConnParams='optional for Apache Phoenix'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.phoenix.jdbc.PhoenixDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Phoenix driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Phoenix\phoenix-client-embedded-hbase-2.5-5.3.1.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:phoenix+zk:[$HostName$]:[$Port$]:/hbase), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Phoenix data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Phoenix data source in the gateway
In this section we will create a data source for Apache Phoenix in the Data Gateway. Let's follow these steps to accomplish that:
    ApachePhoenixDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Phoenix ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApachePhoenixDSN
      ApachePhoenixDSN
      ApachePhoenixDSN
  5. Then set the default database property to ApachePhoenixDSN (the one we used in the Data Gateway):
    ApachePhoenixDSN
    ApachePhoenixDSN
Finally, we are ready to read data from Apache Phoenix in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Phoenix data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Phoenix in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Phoenix, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
