You can connect to your DuckDB (Parquet) data from Power BI via the high-performance DuckDB (Parquet) ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to DuckDB (Parquet)
  • Working with DuckDB (Parquet) data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for DuckDB (Parquet).
Download DuckDB (Parquet) JDBC driver
To connect to DuckDB (Parquet), you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit DuckDB (Parquet) website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar.
Create data source using DuckDB (Parquet) ODBC Driver
To get data from DuckDB (Parquet) using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in DuckDB (Parquet).
    In-Memory Connection
    DuckDB (Parquet) authentication
    Query Parquet with DuckDB JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. The wizard downloads DuckDB JDBC 1.4.5.0 (LTS) and the Titanic sample Parquet into C:\ZappySys\Jdbc\DuckDB (Parquet).
    2. This Auth is in-memory (jdbc:duckdb:memory:). After Finish, query the sample with SELECT * FROM "C:\ZappySys\Jdbc\DuckDB (Parquet)\titanic.parquet".
    3. Use the File Auth if you want a persistent .duckdb database instead of memory.
    3. Finally, hit OK button:
    • Connection string: jdbc:duckdb:memory:
    • Driver class: org.duckdb.DuckDBDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar
    DuckdbParquetDSN
    jdbc:duckdb:memory:
    optional for DuckDB (Parquet)
    Find full details in the DuckDB (Parquet) Connector authentication reference.
    Local DuckDB file
    Persistent DuckDB file from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. The wizard still downloads the JDBC JAR (and Titanic sample) into C:\ZappySys\Jdbc\DuckDB (Parquet).
    2. After Finish, point the JDBC URL at your .duckdb file if you do not want mydb.duckdb.
    3. You can still query Parquet with SELECT * FROM 'C:\ZappySys\Jdbc\DuckDB (Parquet)\titanic.parquet'.
    • Connection string: jdbc:duckdb:C:\ZappySys\Jdbc\DuckDB (Parquet)\mydb.duckdb
    DuckdbParquetDSN
    Jump to troubleshooter
    DuckdbParquetDSN
    SELECT *
    SELECT *
Connect to DuckDB (Parquet) data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose DuckdbParquetDSN and continue:
    DuckdbParquetDSN
    DuckdbParquetDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from DuckDB (Parquet) in a Power BI report:
If you wish to import DuckDB (Parquet) data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
DuckdbParquetDSN
SELECT *
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local DuckDB (Parquet) ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=DuckdbParquetDSN"}
    = Odbc.Query("dsn=DuckdbParquetDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports DuckDB (Parquet) data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from DuckDB (Parquet) Service
    SELECT * FROM OPENQUERY([LS_TO_DUCKDB_PARQUET_IN_GATEWAY], 'SELECT * FROM "C:\ZappySys\Jdbc\DuckDB (Parquet)\titanic.parquet"')
    DirectQuery option for Power BI (read DuckDB (Parquet) data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your DuckDB (Parquet) data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - DuckDB (Parquet)
    Query Parquet and DuckDB files from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    DuckdbParquetDSN
    DuckdbParquetDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:duckdb:memory:';ClassName='org.duckdb.DuckDBDriver';DriverPath='C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar';UserName='optional for DuckDB (Parquet)';UserPassword='optional for DuckDB (Parquet)';ConnParams='optional for DuckDB (Parquet)'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.duckdb.DuckDBDriver):
  6. Go to the Libraries tab, click Add File, and select your DuckDB (Parquet) driver library file(s), e.g. C:\ZappySys\Jdbc\DuckDB (Parquet)\duckdb_jdbc-1.4.5.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:duckdb:memory:), click Test Connection to verify it works, and then click Finish:
    jdbc:duckdb:memory:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide DuckDB (Parquet) data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create DuckDB (Parquet) data source in the gateway
In this section we will create a data source for DuckDB (Parquet) in the Data Gateway. Let's follow these steps to accomplish that:
    DuckdbParquetDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the DuckDB (Parquet) ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      DuckdbParquetDSN
      DuckdbParquetDSN
      DuckdbParquetDSN
  5. Then set the default database property to DuckdbParquetDSN (the one we used in the Data Gateway):
    DuckdbParquetDSN
    DuckdbParquetDSN
Finally, we are ready to read data from DuckDB (Parquet) in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to DuckDB (Parquet) data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to DuckDB (Parquet) in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to DuckDB (Parquet), but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
