You can connect to your JSON File data from Power BI via the high-performance JSON File ODBC Driver. We'll walk you through the entire setup.
  • Working with JSON File data directly inside Power BI
  • Exploring advanced JSON Driver features
Create data source using JSON File ODBC Driver
To get data from JSON File using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  3. Create a User data source (User DSN) based on the ZappySys JSON Driver driver:
    Create new User DSN for ZappySys JSON Driver
  4. You can use pass single file or multiple file path using wildcard pattern in path and you can use select single file by clicking [...] path button or multiple file using wildcard pattern in path.
    Note: If you want to operation with multiple files then use wild card pattern as below
    (when you use wild card pattern in source path then system will treat target path as folder regardless you end with slash)
    C:\SSIS\Test\reponse.json (will read only single reponse.json file)
    C:\SSIS\Test\j*.json (all files starting with file name)
    C:\SSIS\Test\*.json (all files with .json Extension and located under folder subfolder)
  5. Now enter JSONPath expression in Array Filter textbox to extract only specific part of JSON file as below ($.value[*] will get content of value attribute from JSON document. Value attribute is array of JSON documents so we have to use [*] to indicate we want all records of that array)
    NOTE: Here, We are using our desired filter, but you need to select your desired filter based on your requirement.
    Click on Test Connection button to view whether the Test Connection is SUCCESSFUL or Not.
    $.value[*]
    ZappySys ODBC Driver - Configure JSON Driver
  6. Once you configured a data source, you can preview data. Hit Preview tab, and use similar settings to preview data:
    ZappySys ODBC Driver - Preview JSON Driver
  7. Click OK to finish creating the data source
  8. That's it; we are done. In a few clicks we configured the call to JSON File using ZappySys JSON File Connector
Connect to JSON File data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose JsonFileDSN and continue:
    JsonFileDSN
    JsonFileDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from JSON File in a Power BI report:
If you wish to import JSON File data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
JsonFileDSN
                ProductID,
                ProductName,
                SupplierID,
                CategoryID,
                QuantityPerUnit,
                UnitPrice
            FROM _root_
            WHERE UnitPrice > 20
Be aware, that if you type an invalid SQL query, Power BI may try to import a table instead of importing data using a query. In SQL query, make sure you do not use $ as the table name, e.g., SELECT * FROM $. Use _root_ instead, e.g., SELECT * FROM _root_.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local JSON File ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=JsonFileDSN"}
    dsn=JsonFileDSN
    dsn=JsonFileDSN
    = Odbc.Query("dsn=JsonFileDSN",
                            "SELECT * FROM _root_
                            WITH (SRC='http://my-api-provider.com/api/" & MyParameter & "/items')")
By default, Power BI imports JSON File data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from JSON File Service
    SELECT * FROM OPENQUERY([LS_TO_JSON_FILE_IN_GATEWAY], 'SELECT * FROM Orders')
    DirectQuery option for Power BI (read JSON File data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your JSON File data is now linked live rather than imported.
    ZappySys JSON Driver - Configuration [Version: 2.0.1.10418]
    ZappySys JSON Driver - JSON File
    Read and write JSON files effortlessly. Extract, filter, and sync JSON from local files and strings for analytics, reporting, and data pipelines — almost no coding required.
    JsonFileDSN
    JsonFileDSN
    DRIVER={ZappySys JSON Driver};DataPath='C:\my-folder\file-*.json'
In some situations, you may need to provide JSON File data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create JSON File data source in the gateway
In this section we will create a data source for JSON File in the Data Gateway. Let's follow these steps to accomplish that:
    • Then select Native - ZappySys JSON Driver
    JsonFileDSN
  4. When the ZappySys JSON Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the JSON File ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      JsonFileDSN
      JsonFileDSN
      JsonFileDSN
  5. Then set the default database property to JsonFileDSN (the one we used in the Data Gateway):
    JsonFileDSN
    JsonFileDSN
Finally, we are ready to read data from JSON File in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to JSON File data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to JSON File in Power BI and integrate your data — all without writing complex code.
