You can connect to your Arrow Flight SQL data from Azure Data Factory (Pipeline) via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  1. Visit Arrow Flight SQL website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using Arrow Flight SQL ODBC Driver
Watch this quick walkthrough to see how to configure your Arrow Flight SQL ODBC data source, or scroll down for the step-by-step written guide.
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Arrow Flight SQL.
To get data from Arrow Flight SQL using Azure Data Factory (Pipeline), we first need to create an ODBC data source. We will later read this data in Azure Data Factory (Pipeline). Perform these steps:
    When deployed to production, Azure Data Factory (Pipeline) runs under a Service Account. Therefore, for the production environment, you must create and use a System DSN.
    • Configure the authentication in Arrow Flight SQL.
    User and password
    1. Note the Flight SQL host and port (Dremio often uses 32010; other servers differ). Default encryption is on.
    2. Create a database user on the Flight SQL server. Paste user and password.
    3. If the Bridge JVM is Java 16 or newer, add --add-opens=java.base/java.nio=ALL-UNNAMED to the JDBC Bridge JVM options when Arrow reports module-access errors.
    4. After Finish, replace host and port. Set useEncryption=false only for a local plaintext lab.
    3. Finally, hit OK button:
    • Connection string: jdbc:arrow-flight-sql://[$HostName$]:[$Port$]
    • Driver class: org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar
    • Host: MyHostName
    • TCP port: 32010
    • User name:
    • Password:
    • Use encryption: true
    ArrowFlightSqlDSN
    optional for Arrow Flight SQL
    Find full details in the Arrow Flight SQL Connector authentication reference.
    Token
    1. Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
    2. Paste the token into Token. Leave user/password empty unless the server requires both.
    3. Java 16+ may need --add-opens=java.base/java.nio=ALL-UNNAMED on the Bridge JVM.
    4. After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
    • Host: MyHostName
    • TCP port: 32010
    • Token:
    ArrowFlightSqlDSN
    Jump to troubleshooter
    ArrowFlightSqlDSN
    SELECT * FROM information_schema.tables
Read data in Azure Data Factory (ADF) from ODBC datasource (Arrow Flight SQL)
  1. Sign in to Azure Portal
    • Open your browser and go to: https://portal.azure.com
    • Enter your Azure credentials and complete MFA if required.
    • After login, go to Data factories.
    Azure Portal
  2. Under Azure Data Factory Resource - Create or select the Data Factory you want to work with.
    Select the Data Factory
  3. Inside the Data Factory resource page, click Launch studio.
    Launch Azure Data Factory Studio
  4. Create a New Integration Runtime (Self-Hosted):
    • In Azure Data Factory Studio, go to the Manage section (left menu).
    • Under Connections, select Integration runtimes.
    • Click + New to create a new integration runtime.
    Create new Self-Hosted integration runtime
  5. Select Azure, Self-Hosted option:
  6. Select Self-Hosted option:
  7. Set a name, we will use OnPremisesRuntime:
    Set a name for IR
  8. Download and install Microsoft Integration Runtime.
  9. Launch Integration Runtime and copy/paste Authentication Key from Integration Runtime configuration in Azure Portal:
    Copy/paste Authentication Key
  10. After finishing registering the Integration Runtime node, you should see a similar view:
    Check Integration Runtime node status
  11. Go back to Azure Portal and finish adding new Integration Runtime. You should see it was successfully added:
    Integration Runtime status
  12. Create a New Linked service:
    • In the Manage section (left menu).
    • Under Connections, select Linked services.
    • Click + New to create a new Linked service based on ODBC.
    Add new Linked service
  13. Select ODBC service:
    Add new ODBC service
  14. Configure new ODBC service. Use the same DSN name we used in the previous step and copy it to Connection string box:
    ArrowFlightSqlDSN
    DSN=ArrowFlightSqlDSN
  15. For created ODBC service create ODBC-based dataset:
    Add new ODBC dataset
  16. Go to your pipeline and add Copy data connector into the flow. In Source section use OdbcDataset we created as a source dataset:
    Set source in Copy data
  17. Then go to Sink section and select a destination/sink dataset. In this example we use precreated AzureBlobStorageDataset which saves data into an Azure Blob:
    Set sink in Copy data
  18. Finally, run the pipeline and see data being transferred from OdbcDataset to your destination dataset:
    Run the flow
Executing SQL queries using Lookup activity
If you need to execute commands in Arrow Flight SQL instead of retrieving data, use the Lookup activity for that purpose. Use this approach when you want data to be changed on the Arrow Flight SQL side, but you don't need the data on your side (a "fire-and-forget" scenario).
Perform these simple steps to accomplish that:
  1. Go to your pipeline in Azure Data Factory
  2. Find Lookup activity in the Activities pane
  3. Then drag-and-drop the Lookup activity onto your pipeline canvas
  4. Click Settings tab
  5. Select OdbcDataset in the Source dataset field
  6. Finally, enter your SQL query in the Query text box:
Configuring Lookup activity in ADF pipeline to perform a command in Arrow Flight SQL
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
  6. Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g. C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Arrow Flight SQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Azure Data Factory (Pipeline) (client-side) to connect to it.
Create Arrow Flight SQL data source in the gateway
    ArrowFlightSqlDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Arrow Flight SQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZappySys JDBC Bridge Driver - Arrow Flight SQL
      Query any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
      ArrowFlightSqlDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Azure Data Factory (Pipeline). To achieve that, let's perform these steps:
  5. Then set the default database property to ArrowFlightSqlDSN (the one we used in the Data Gateway):
    ArrowFlightSqlDSN
    ArrowFlightSqlDSN
Access data in Azure Data Factory (Pipeline) via the gateway
Finally, we are ready to read data from Arrow Flight SQL in Azure Data Factory (Pipeline) via the Data Gateway. Follow these final steps:
  1. Go back to Azure Data Factory (Pipeline).
    DSN=ZappySysGatewayDSN
  5. Read the data the same way we discussed at the beginning of this article.
  6. That's it!
Now you can connect to Arrow Flight SQL data in Azure Data Factory (Pipeline) via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Arrow Flight SQL in Azure Data Factory (Pipeline) and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
