You can connect to your Arrow Flight SQL data from Qlik Cloud via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Minimum required version: Java 11
Visit Arrow Flight SQL website or MVN Repository.
C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
Create data source using Arrow Flight SQL ODBC Driver
Watch this quick walkthrough to see how to configure your Arrow Flight SQL ODBC data source, or scroll down for the step-by-step written guide.
To get data from Arrow Flight SQL using Qlik Cloud, we first need to create an ODBC data source. We will later read this data in Qlik Cloud. Perform these steps:
- Configure the authentication in Arrow Flight SQL.
User and password
- Note the Flight SQL host and port (Dremio often uses
32010; other servers differ). Default encryption is on. - Create a database user on the Flight SQL server. Paste user and password.
- If the Bridge JVM is Java 16 or newer, add
--add-opens=java.base/java.nio=ALL-UNNAMEDto the JDBC Bridge JVM options when Arrow reports module-access errors. - After Finish, replace host and port. Set
useEncryption=falseonly for a local plaintext lab. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:arrow-flight-sql://[$HostName$]:[$Port$] -
Driver class :org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar -
Host :MyHostName -
TCP port :32010 -
User name : -
Password : -
Use encryption :true
ArrowFlightSqlDSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jaroptional for Arrow Flight SQL
Find full details in the Arrow Flight SQL Connector authentication reference.Token
- Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
- Paste the token into Token. Leave user/password empty unless the server requires both.
- Java 16+ may need
--add-opens=java.base/java.nio=ALL-UNNAMEDon the Bridge JVM. - After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
Host :MyHostName -
TCP port :32010 -
Token : -
ArrowFlightSqlDSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jaroptional for Arrow Flight SQLoptional for Arrow Flight SQLoptional for Arrow Flight SQL
Find full details in the Arrow Flight SQL Connector authentication reference. -
ArrowFlightSqlDSNSELECT * FROM information_schema.tables
SELECT * FROM information_schema.tablesYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Set up Qlik Direct Access data gateway
To connect to the Arrow Flight SQL data, you need a secure pipeline between your Qlik Cloud tenant and the Arrow Flight SQL ODBC DSN. Let's download, deploy, and register the Qlik data gateway to make this happen.
First, log into your My Qlik tenants portal and choose your tenant:
Navigate to Administration.
Select Spaces.
Create a shared space if you do not have one yet:
Click Create new.
Name shared space and confirm.
Next, let's grab the gateway installer:
Select Data gateways.
Download the gateway:
Click Deploy.
Select Data Gateway - Direct Access (Windows).
Check acknowledgement box.
Click Download.
If you are not running this locally, copy the installer to your target machine.
The ODBC PowerPack and the Qlik Direct Access gateway must be installed on the exact same machine. -
Install the Qlik Direct Access gateway.
Once installed, open an elevated Command Prompt on the gateway machine:
Link the gateway to your tenant:
Navigate to ConnectorAgent directory.
Run tenant URL setup command.
cd \ cd "Program Files\Qlik\ConnectorAgent\ConnectorAgent" ConnectorAgent.exe qcs set_config --tenant_url https://<tenant>.qlikcloud.com -
Generate your data gateway key:
ConnectorAgent.exe qcs generate_keys -
Start the gateway service:
ConnectorAgent.exe service start -
Generate and copy the registration payload:
Run registration command.
Copy output text.
ConnectorAgent.exe qcs get_registration -
Now let's head back to the Qlik Cloud Administration page to complete the data gateway registration.
Create the gateway entry in your tenant and apply the key:
Name gateway.
Select Direct Access for Gateway type.
Select shared space.
Paste generated key.
Click Create.
Finally, verify the status shows Connected:
Create ODBC connection in Analytics
With the gateway actively running, let's build the actual ODBC connection in Analytics.
Navigate to your My Qlik tenants page, choose your tenant, select the Analytics tile, and click the Create menu item:
Click the Data connection tile:
Next, let's create the ODBC data connection by selecting your shared space and finding the right connector:
Pick your shared space.
Search for odbc.
Choose the ODBC (via Direct Access gateway) option.
Finally, configure the ODBC connection fields to wrap up the setup:
Select your Data gateway.
Select the System DSN option.
Choose the ODBC source (DSN).
Select the DB2 SQL syntax.
Name the connection.
Click Test connection, then click Create.
ArrowFlightSqlDSN
Connection is ready!
You are now successfully wired up to your Arrow Flight SQL data. Let's see how to actually load it into your dashboard.
Load Arrow Flight SQL data into Qlik Cloud
Depending on your specific use case, you can choose one of the two methods below to bring your data into the Qlik Cloud environment for analysis.
Use Analytics app with Data load editor
This is the best method if you need to run dynamic SQL. We will use your new gateway connection in the Data load editor to pull the data and verify it visually.
Click the Application tile to start creating a new application:
Next, create the application within your shared space:
Name the application.
Select your shared space.
Click the Create button.
Now, open the new application and click the Data load editor option:
With the editor open, you can configure your DSN and SQL query before running the data load:
Select your shared space connection.
Click the gateway connection button to use the ODBC (via Direct Access gateway) option.
Name the table as MyData and prepare your SQL load script.
Click Load data.
SELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tablesSELECT * FROM information_schema.tables SELECT * FROM information_schema.tables
LIB CONNECT TO 'My Shared Space:Gateway Connection'; MyData: LOAD *; SQL SELECT * FROM information_schema.tables -
Once the data has successfully loaded, go to the sheet to build your dashboard:
Select the Sheet option.
Select the Fields section.
Drag and drop the fields onto the sheet to create your visuals.
MyData
Your Arrow Flight SQL data is now ready for analysis!
Use Data flow for data integration
Use this method if you want to build a complete source-to-destination pipeline directly inside Qlik Cloud.
Click the Data flow tile to start building your integration:
Next, create the data flow within your shared space:
Name your data flow.
Now that the data flow is created, open the editor and browse your available connections:
Select the Editor tab.
Click the Browse connections button.
Select the gateway-backed ODBC connection we set up earlier:
Choose your gateway connection.
Click Next.
Select your source tables and the specific fields you want to import:
Select one or multiple tables.
Uncheck any unwanted columns (optional).
Click Finish.
Map your source and destination nodes to define the flow:
Connect the source node to the destination node.
Click Run flow to start the integration process.
Wait for the successful completion message to appear:
Your Arrow Flight SQL data integration is now complete!
Open DBeaver.
org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g.
C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Arrow Flight SQL data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
To achieve this, you must first create a data source in the Data Gateway (server-side) and then create an ODBC data source in Qlik Cloud (client-side) to connect to it.
Create Arrow Flight SQL data source in the gateway
ArrowFlightSqlDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Arrow Flight SQL ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZappySys JDBC Bridge Driver - Arrow Flight SQLQuery any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ArrowFlightSqlDSN
ArrowFlightSqlDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Arrow Flight SQLQuery any Arrow Flight SQL endpoint with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ArrowFlightSqlDSN
In this part we will create an ODBC data source to connect to the ZappySys Data Gateway from Qlik Cloud. To achieve that, let's perform these steps:
ArrowFlightSqlDSN(the one we used in the Data Gateway):ArrowFlightSqlDSNArrowFlightSqlDSN
Access data in Qlik Cloud via the gateway
Finally, we are ready to read data from Arrow Flight SQL in Qlik Cloud via the Data Gateway. Follow these final steps:
Go back to Qlik Cloud.
Search for odbc.
Now you can connect to Arrow Flight SQL data in Qlik Cloud via the ZappySys Data Gateway.
john and your password.
In this guide, we demonstrated how to connect to Arrow Flight SQL in Qlik Cloud and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
