You can connect to your Gmail data from Power BI via the high-performance Gmail ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Gmail
- Working with Gmail data directly inside Power BI
Create data source using Gmail ODBC Driver
To get data from Gmail using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Gmail" from the list of Popular Connectors. If "Gmail" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
GmailDSNGmail
- Configure the authentication in Gmail.
User Account
Gmail authentication
To make this work you will have to create a Google Cloud project. This project forms the basis for creating, enabling, and using all Google Cloud services, including managing APIs, enabling billing, adding and removing collaborators, and managing permissions.
- Go to the Google Cloud Console
- In the Google Cloud console, go to menu IAM & Admin, and then Create a Project.
- Enter the name of the new project into the Project Name field and select the appropriate organization, then click Create.
- The console navigates to the Dashboard page and your project is created within a few minutes.
- In the Google Cloud console, go to menu More products, Google Workspace, and then Product Library.
- Now we need to enable the Gmail API.
- Search for Gmail API. Select it and then click ENABLE.
- Select the Credentials tab on the left side of the screen.
- Select the + CREATE CREDENTIALS link to reveal a drop down menu.
- In the dropdown menu, select OAuth client ID.
- If presented, click the CONFIGURE CONSENT SCREEN button and then elect the appropriate User Type based on your business needs. Otherwise, continue to step 16.
- In the OAuth consent screen tab fill in your app's website and domain information, and then click SAVE AND CONTINUE.
- In the Scopes section of the app registration, click ADD OR REMOVE SCOPES and add the following scopes:
- openid
- https://mail.google.com/
- https://www.googleapis.com/auth/userinfo.email
- https://www.googleapis.com/auth/userinfo.profile
- https://www.googleapis.com/auth/gmail.labels
- https://www.googleapis.com/auth/gmail.send
- https://www.googleapis.com/auth/gmail.modify
- https://www.googleapis.com/auth/gmail.compose
- https://www.googleapis.com/auth/gmail.readonly
- After the scopes have been added, click SAVE AND CONTINUE.
- Complete the wizard setting up scopes.
- In the Application type drop down, select Desktop application and then give your app client a name.
- Select the CREATE button.
- A popup window will appear that provides important information you should record for your records:
- Client ID
- Client secret
- Go to OAuth Consent Screen tab. Under Publishing Status click PUBLISH APP to ensure your refresh token doesnt expire often. If you planning to use App for Private use then do not have to worry about Verification Status after Publish.
- Back to Connection UI, Enter the client ID and client secret into the required parameters.
User Account [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
GmailDSNGmailUser Account [OAuth]https://gmail.googleapis.com/Required Parameters UseCustomApp Fill-in the parameter... Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Default API Version Fill-in the parameter... Default User Id Fill-in the parameter... Scope Fill-in the parameter... Optional Parameters Client Id Client Secret RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True Redirect URL (Only for Web App)
Find full details in the Gmail Connector authentication reference. -
ZappySys API Driver - GmailRead and write Gmail data effortlessly. Send, manage, and sync messages, attachments, labels, and threads — almost no coding required.GmailDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Gmail. Hit OK button to use this query in the next step.
SELECT * FROM Messages
Some parameters configured in this window will be passed to the Gmail API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - GmailRead and write Gmail data effortlessly. Send, manage, and sync messages, attachments, labels, and threads — almost no coding required.GmailDSNSELECT * FROM Messages
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Gmail API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Gmail servers). -
Connect to Gmail data in Power BI
Another window opens and asks to select a Data Source we already created. Choose GmailDSN and continue:
GmailDSN
GmailDSN
Finally, finally, read extracted data from Gmail in a Power BI report:
If you wish to import Gmail data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Gmail ODBC data source:
ODBC{"connectionstring":"dsn=GmailDSN"}
dsn=GmailDSN
dsn=GmailDSN
= Odbc.Query("dsn=GmailDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Gmail data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_GMAIL_IN_GATEWAY], 'SELECT * FROM Messages')
SELECT * FROM OPENQUERY([LS_TO_GMAIL_IN_GATEWAY], 'SELECT * FROM Messages') - Click OK and load the data. Your Gmail data is now linked live rather than imported.
GmailDSNDRIVER={ZappySys API Driver};ServiceUrl=https://gmail.googleapis.com/;Provider=Google;OAuthVersion=OAuth2;Scope=[$Scope$];ScopeSeparator={space};
Gmail Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Gmail operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get List of Messages for a Specific User
- Get Message Attachments (With search condition)
- Download Message Attachments (With search condition)
- Get a Specific Message for a Specific User
- Get List of Messages for the Current User
- Get a Specific Message for the Current User
- Get message attachment for user
- Get a Specific Attachment included in a Specific Message for the Current User
- Get labels
- Send a New Message for the specified User
In some situations, you may need to provide Gmail data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Gmail data source in the gateway
In this section we will create a data source for Gmail in the Data Gateway. Let's follow these steps to accomplish that:
GmailDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Gmail ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
GmailDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - GmailRead and write Gmail data effortlessly. Send, manage, and sync messages, attachments, labels, and threads — almost no coding required.GmailDSN
GmailDSN(the one we used in the Data Gateway):GmailDSNGmailDSN
Finally, we are ready to read data from Gmail in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Gmail data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Gmail in Power BI and integrate your data — all without writing complex code.
