You can connect to your Trino data from Power BI via the high-performance Trino ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Trino
- Working with Trino data directly inside Power BI
Minimum required version: Java 11
Download Trino JDBC driver
To connect to Trino, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Trino website or MVN Repository.
C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar.
Create data source using Trino ODBC Driver
To get data from Trino using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Trino.
Non-SSL connection
Trino authentication
Trino from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note coordinator host and HTTP port (often
8080for lab,443for Cloud TLS). - Create an application user if the cluster requires a password. Some labs allow any user with an empty password.
- After Finish, set catalog/schema on the DSN Main UI or qualify tables as
tpch.sf1.orders. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:trino://[$HostName$]:[$Port$] -
Driver class :io.trino.jdbc.TrinoDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar -
Host :MyHostName -
TCP port :8080 -
User name : -
Password :
TrinoDSNjdbc:trino://[$HostName$]:[$Port$]io.trino.jdbc.TrinoDriverC:\ZappySys\Jdbc\Trino\trino-jdbc-476.jaroptional for Trino
Find full details in the Trino Connector authentication reference.SSL connection
Trino with TLS from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Same as Non-SSL Auth. Use port 443 (or your TLS port) and
SSL=true. - Fill user and password from the coordinator or Starburst Galaxy/Galaxy-like console.
Connection string :jdbc:trino://[$HostName$]:[$Port$]?SSL=[$Ssl$] -
Host :MyHostName -
TCP port :443 -
SSL :true -
User name : -
Password :
TrinoDSNjdbc:trino://[$HostName$]:[$Port$]?SSL=[$Ssl$]io.trino.jdbc.TrinoDriverC:\ZappySys\Jdbc\Trino\trino-jdbc-476.jaroptional for Trino
Find full details in the Trino Connector authentication reference. -
TrinoDSNSELECT * FROM tpch.sf1.orders
SELECT * FROM tpch.sf1.ordersYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Trino data in Power BI
Another window opens and asks to select a Data Source we already created. Choose TrinoDSN and continue:
TrinoDSN
TrinoDSN
Finally, finally, read extracted data from Trino in a Power BI report:
If you wish to import Trino data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Trino ODBC data source:
ODBC{"connectionstring":"dsn=TrinoDSN"}
dsn=TrinoDSN
dsn=TrinoDSN
= Odbc.Query("dsn=TrinoDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Trino data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_TRINO_IN_GATEWAY], 'SELECT * FROM tpch.sf1.orders')
SELECT * FROM OPENQUERY([LS_TO_TRINO_IN_GATEWAY], 'SELECT * FROM tpch.sf1.orders') - Click OK and load the data. Your Trino data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - TrinoQuery Trino catalogs from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.TrinoDSN
TrinoDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:trino://[$HostName$]:[$Port$]';ClassName='io.trino.jdbc.TrinoDriver';DriverPath='C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar';UserName='';UserPassword='';ConnParams='optional for Trino'
Open DBeaver.
io.trino.jdbc.TrinoDriver):
Go to the Libraries tab, click Add File, and select your Trino driver library file(s), e.g.
C:\ZappySys\Jdbc\Trino\trino-jdbc-476.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:trino://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Trino data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Trino data source in the gateway
In this section we will create a data source for Trino in the Data Gateway. Let's follow these steps to accomplish that:
TrinoDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Trino ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
TrinoDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - TrinoQuery Trino catalogs from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.TrinoDSN
TrinoDSN(the one we used in the Data Gateway):TrinoDSNTrinoDSN
Finally, we are ready to read data from Trino in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Trino data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Trino in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Trino, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
