You can connect to your OData data from Power BI via the high-performance OData ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to OData
  • Working with OData data directly inside Power BI
Create data source using OData ODBC Driver
To get data from OData using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "OData" from the list of Popular Connectors. If "OData" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    OdataDSN
    OData
    • Configure the authentication in OData.
    No Authentication
    OData authentication
    No instructions available.
    1. Set Authentication Type to No Authentication [Http]
    OdataDSN
    OData
    https://services.odata.org/V3/Northwind/Northwind.svc
    IgnoreSSLCertificateErrors
    SslVersion
    Find full details in the OData Connector authentication reference.
    Windows Authentication
    1. Set Authentication Type to Windows Authentication [Http]
    OdataDSN
    OData
    There are no parameters to configure.
    Basic Authentication
    1. Set Authentication Type to Basic Authentication [Http]
    OdataDSN
    OData
    SslVersion
    NTLM Authentication
    1. Set Authentication Type to NTLM Authentication [Http]
    OdataDSN
    OData
    UserName (i.e. Domain\UserName) Fill-in the parameter...
    SslVersion
    Token Authentication
    1. Set Authentication Type to Token Authentication [Http]
    OdataDSN
    OData
    AuthScheme Bearer
    AuthHeader Authorization
    SslVersion
    OAuth Connection for OData API
    1. Set Authentication Type to OAuth Connection for OData API [OAuth]
    OdataDSN
    OData
    GrantType Default
    OAuthVersion Default
    ClientId
    ClientSecret
    UserName
    Password
    Scope
    AuthUrl https://some-domain.com/api/auth
    TokenUrl https://some-domain.com/api/token
    ReturnUrl https://zappysys.com/oauth
    ExtraAttributesForTokenRequest
    ExtraAttributesForAuthRequest
    DoNotIncludeCredentialsInHeader
    DoNotIncludeCredentialsInBody
    RenewBeforeSec
    ExtraHeaders (e.g. x-hdr1:AAA||x-hdr2:BBB)
    ContentType
    EnableCodeVerifier
    RemoveAuthHeader
    CustomAuthHeader
    CustomTokenPrefix
    SslVersion
    ZappySys API Driver - OData
    Read and write OData API data effortlessly. Query, integrate, and manage entities and feeds — almost no coding required.
    OdataDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from OData. Hit OK button to use this query in the next step.
    SELECT * FROM Customers
    Some parameters configured in this window will be passed to the OData API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    OdataDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the OData API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in OData servers).
Connect to OData data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose OdataDSN and continue:
    OdataDSN
    OdataDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from OData in a Power BI report:
If you wish to import OData data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
OdataDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local OData ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=OdataDSN"}
    dsn=OdataDSN
    dsn=OdataDSN
    = Odbc.Query("dsn=OdataDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports OData data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from OData Service
    SELECT * FROM OPENQUERY([LS_TO_ODATA_IN_GATEWAY], 'SELECT * FROM Customers')
    DirectQuery option for Power BI (read OData data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your OData data is now linked live rather than imported.
    OdataDSN
    OdataDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://services.odata.org/V3/Northwind/Northwind.svc;URL=https://ignored;
OData Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential OData operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide OData data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create OData data source in the gateway
In this section we will create a data source for OData in the Data Gateway. Let's follow these steps to accomplish that:
    OdataDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the OData ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      OdataDSN
      OdataDSN
      OdataDSN
  5. Then set the default database property to OdataDSN (the one we used in the Data Gateway):
    OdataDSN
    OdataDSN
Finally, we are ready to read data from OData in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to OData data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to OData in Power BI and integrate your data — all without writing complex code.
