You can connect to your Outlook Mail (Office 365) data from Power BI via the high-performance Outlook Mail (Office 365) ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Outlook Mail (Office 365)
- Working with Outlook Mail (Office 365) data directly inside Power BI
Create data source using Outlook Mail (Office 365) ODBC Driver
To get data from Outlook Mail (Office 365) using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Outlook Mail (Office 365)" from the list of Popular Connectors. If "Outlook Mail (Office 365)" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
OutlookMailOffice365DSNOutlook Mail (Office 365)
- Configure the authentication in Outlook Mail (Office 365).
User Credentials
Outlook Mail (Office 365) authentication
WARNING: If you are planning to automate processes, we recommend that you use a Application Credentials authentication method. In case, you still need to use User Credentials, then make sure you use a system/generic account (e.g.automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.- Navigate to the Azure Portal and log in using your credentials.
- Access Microsoft Entra ID.
Register a new application by going to App registrations and clicking on New registration button:
Supported account type
- Use
- Use
Redirect URI:
- Set the type to
- Set the type to
Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs to use later in the configuration:
In the Permissions (Scope) field use the default or pick labeled permissions. [System] covers sign-in and refresh token. [User] is the signed-in user’s mailbox (use
Mail.ReadBasicorMail.Readfor read-only). [Shared] adds shared or delegated mail folders. [Tenant] entries (User.ReadBasic.All,User.Read.All,Group.Read.All) are broad directory permissions that usually need an administrator to approve the app. The default includesUser.ReadBasic.Allfor the Default User Id drop down; addUser.Read.Allonly if you need full user profiles (not required for listing users).-
offline_access,openid,profile,email -
User.Read,Mail.ReadBasic,Mail.Read,Mail.ReadWrite,Mail.Send -
Mail.Read.Shared,Mail.ReadBasic.Shared,Mail.ReadWrite.Shared,Mail.Send.Shared -
User.ReadBasic.All,Group.Read.All(often admin consent; user drop down / group lookups) -
User.Read.All(optional — full user profiles; broader than needed for user drop down)
- Broad mail or directory scopes such as
Mail.ReadWrite,User.ReadBasic.All,User.Read.All, andGroup.Read.Allmay still require admin consent.
Choose Default User Id from the drop down menu after token generation. This calls
GET /usersand requiresUser.ReadBasic.Allin your token (included in the default scope list). Regenerate the token if you add or remove this scope later. Keepmefor your own mailbox, or pick another user when accessing a shared or delegated mailbox. You can also type a user id or email manually if listing fails. - Click Test Connection to confirm the connection is working.
OutlookMailOffice365DSNOutlook Mail (Office 365)User Credentials [OAuth]https://graph.microsoft.com/v1.0Required Parameters Authorization URL Fill-in the parameter... Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Permissions (Scope) Fill-in the parameter... Return URL Fill-in the parameter... Optional Parameters Client Secret Refresh Token File Path Login Prompt Option Default User Id (Select after clicking **Generate Token**) me RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Outlook Mail (Office 365) Connector authentication reference.Application Credentials
Follow these simple steps below to create Microsoft Entra ID application with application access permissions.
- e.g. select
Accounts in this organizational directory onlyif you need access to data in your organization only.
- e.g. select
Redirect URI:
- Set the type to
Public client/native (mobile & desktop). - Leave the URL field empty.
- Set the type to
Then copy OAuth authorization endpoint (v2) & OAuth token endpoint (v2) URLs:
Continue and create Client secret:
Then copy the Client secret for later steps:
Continue by adding permissions for the app by going to the API permissions section, and clicking on Add a permission:
Select Microsoft Graph:
Then choose Application permissions option:
Continue by adding these Mail (Outlook) application permissions (for example
Mail.Read,Mail.ReadWrite, orMail.Senddepending on your needs):
If you want the Default User Id drop down to list organization users (calls
GET /users), repeat Add a permission and also add the User.Read.All application permission. Add Group.Read.All if you need group lookups. Search forUserunder Application permissions, select User.Read.All, then click Add permissions. -
Finish by clicking Add permissions button:
Now it's time to Grant admin consent for your application:
Confirm all the permissions are granted (Mail scopes plus
User.Read.Allwhen using the user drop down):
Now go to SSIS package or ODBC data source and use the copied values in Application Credentials authentication configuration:
- In the Client Secret field paste the Client secret value you copied in the previous step.
- Choose Default User Id from the drop down menu (requires
User.Read.Allapplication permission and admin consent), or type a user id or email manually.
- That's it! Now you can use the connector.
Application Credentials [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
OutlookMailOffice365DSNOutlook Mail (Office 365)Application Credentials [OAuth]https://graph.microsoft.com/v1.0Required Parameters Token URL Fill-in the parameter... Application (client) ID Fill-in the parameter... Client Secret Fill-in the parameter... Scope Fill-in the parameter... Default User Id Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429|503 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Outlook Mail (Office 365) Connector authentication reference. -
ZappySys API Driver - Outlook Mail (Office 365)Read and write Microsoft Outlook Mail (Office 365) data effortlessly. Send, manage, and sync messages, attachments, and folders — almost no coding required.OutlookMailOffice365DSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Outlook Mail (Office 365). Hit OK button to use this query in the next step.
SELECT * FROM MyMessages
Some parameters configured in this window will be passed to the Outlook Mail (Office 365) API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - Outlook Mail (Office 365)Read and write Microsoft Outlook Mail (Office 365) data effortlessly. Send, manage, and sync messages, attachments, and folders — almost no coding required.OutlookMailOffice365DSNSELECT * FROM MyMessages
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Outlook Mail (Office 365) API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Outlook Mail (Office 365) servers). -
Connect to Outlook Mail (Office 365) data in Power BI
Another window opens and asks to select a Data Source we already created. Choose OutlookMailOffice365DSN and continue:
Finally, finally, read extracted data from Outlook Mail (Office 365) in a Power BI report:
If you wish to import Outlook Mail (Office 365) data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Outlook Mail (Office 365) ODBC data source:
ODBC{"connectionstring":"dsn=OutlookMailOffice365DSN"}
= Odbc.Query("dsn=OutlookMailOffice365DSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Outlook Mail (Office 365) data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_OUTLOOK_MAIL_OFFICE_365_IN_GATEWAY], 'SELECT * FROM MyMessages')
SELECT * FROM OPENQUERY([LS_TO_OUTLOOK_MAIL_OFFICE_365_IN_GATEWAY], 'SELECT * FROM MyMessages') - Click OK and load the data. Your Outlook Mail (Office 365) data is now linked live rather than imported.
OutlookMailOffice365DSNDRIVER={ZappySys API Driver};ServiceUrl=https://graph.microsoft.com/v1.0;Provider=Custom;OAuthVersion=OAuth2;GrantType=Default;Scope=[$Scope$];ScopeSeparator={space};
Outlook Mail (Office 365) Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Outlook Mail (Office 365) operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Tables
- Get Table Columns
- Get My Information
- Get Messages
- Send Mail
- Get My Mail Folders [only works with User Credentials]
- Get Mail Folder by Id [only works with User Credentials]
- Get Users
- Get User by Id
- Get Groups
- Get Group by Id
- Get Mail Folders
- Get My Messages [only works with User Credentials]
- Get My Message by Id [only works with User Credentials]
- Get Message Attachments
- Get Messages by Search Filters - Output binary data (EML RFC 822 / MIME)
- Get Message by Id (Single) - Output binary data (EML RFC 822 / MIME)
- Delete Message by Id (Single)
- Delete Messages - Using Search Condition (Bulk Delete)
- Download Message by Id (Single *.EML File RFC 822 / MIME)
- Download Messages by Search Condition (Multiple *.EML Files RFC 822 / MIME)
- Download Message Attachment (Single File)
- Download Message Attachments (Multiple Files) - Using Search Condition
In some situations, you may need to provide Outlook Mail (Office 365) data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Outlook Mail (Office 365) data source in the gateway
In this section we will create a data source for Outlook Mail (Office 365) in the Data Gateway. Let's follow these steps to accomplish that:
OutlookMailOffice365DSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Outlook Mail (Office 365) ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
OutlookMailOffice365DSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Outlook Mail (Office 365)Read and write Microsoft Outlook Mail (Office 365) data effortlessly. Send, manage, and sync messages, attachments, and folders — almost no coding required.OutlookMailOffice365DSN
OutlookMailOffice365DSN(the one we used in the Data Gateway):OutlookMailOffice365DSNOutlookMailOffice365DSN
Finally, we are ready to read data from Outlook Mail (Office 365) in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Outlook Mail (Office 365) data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Outlook Mail (Office 365) in Power BI and integrate your data — all without writing complex code.
