You can connect to your Amazon Athena data from Power BI via the high-performance Amazon Athena ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Amazon Athena
- Working with Amazon Athena data directly inside Power BI
Download Amazon Athena JDBC driver
To connect to Amazon Athena, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Amazon Athena official website.
C:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jar. -
Create data source using Amazon Athena ODBC Driver
To get data from Amazon Athena using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Amazon Athena.
IAM access key
Amazon Athena authentication
Athena JDBC v3 uses IAM access keys (same idea as a Stripe secret key). Query results land in S3. Bridge then serves Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Sign in to the IAM console.
- Create (or reuse) an IAM user or role with Athena and Glue catalog permissions plus
s3:GetObject/s3:PutObjecton the query-results bucket. - Open Security credentials and create an access key. Copy Access key ID into User name and Secret access key into Password. Do not check keys into XML or TFVC.
- In the Athena console, note Region, WorkGroup (often
primary), Catalog, and the S3 output location (s3://your-bucket/prefix/). - After Finish, edit the JDBC URL on the DSN Main UI to replace WorkGroup, Region, Catalog, and OutputLocation.
Connection string :jdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$]; -
Driver class :com.amazon.athena.jdbc.AthenaDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jar -
Workgroup :primary -
AWS region :us-east-1 -
Athena catalog :MyAwsDataCatalog -
Output location :s3://my-s3-bucket/ -
Access key ID : -
Secret access key :
AmazonAthenaDSNjdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];com.amazon.athena.jdbc.AthenaDriverC:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jaroptional for Amazon Athena
Find full details in the Amazon Athena Connector authentication reference.Default AWS credential chain
Use credentials already available to the Windows account that runs the ZappySys JDBC Bridge. The AWS SDK default credential provider chain can use environment variables, shared AWS files, container credentials, or an EC2 instance role.
- Grant the selected IAM principal Athena and Glue catalog permissions plus access to the query-results S3 location.
- Configure credentials for the Windows account that runs the driver. For unattended refresh, prefer an EC2 instance role, container role, or another short-lived credential source over long-lived access keys.
- Enter Region and Workgroup. Enter Output location only when the workgroup does not enforce one.
- Finish the wizard. Then click Test Connection on the DSN Main UI.
- If the test cannot find credentials, verify them while signed in as the service account that runs the process, not only as your interactive user.
Connection string :jdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];CredentialsProvider=DefaultChain; -
Athena catalog :AwsDataCatalog -
Output location :
AmazonAthenaDSNjdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];CredentialsProvider=DefaultChain;com.amazon.athena.jdbc.AthenaDriverC:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jaroptional for Amazon Athenaoptional for Amazon Athenaoptional for Amazon Athena
Find full details in the Amazon Athena Connector authentication reference.AWS or IAM Identity Center profile
Use a named AWS profile, including an IAM Identity Center (AWS SSO) profile, instead of storing an access key in the DSN.
- Create the named profile in the shared AWS config for the same Windows account that runs the ZappySys JDBC Bridge.
- For IAM Identity Center, configure the profile with
aws configure sso, then sign in withaws sso login --profile athena-idc. - Enter that exact profile name, Region, and Workgroup. Enter Output location only when the workgroup does not enforce one.
- For scheduled jobs, make sure the profile session remains valid or use the Default AWS credential chain with a workload role.
Connection string :jdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];CredentialsProvider=ProfileCredentials;ProfileName=[$ProfileName$]; -
AWS profile name :athena -
Output location :
AmazonAthenaDSNjdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];CredentialsProvider=ProfileCredentials;ProfileName=[$ProfileName$];com.amazon.athena.jdbc.AthenaDriverC:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jaroptional for Amazon Athenaoptional for Amazon Athenaoptional for Amazon Athena
Find full details in the Amazon Athena Connector authentication reference. -
AmazonAthenaDSNSELECT * FROM "r53_rlogs" ORDER BY query_timestamp DESC
SELECT * FROM "r53_rlogs" ORDER BY query_timestamp DESCYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Amazon Athena data in Power BI
Another window opens and asks to select a Data Source we already created. Choose AmazonAthenaDSN and continue:
AmazonAthenaDSN
AmazonAthenaDSN
Finally, finally, read extracted data from Amazon Athena in a Power BI report:
If you wish to import Amazon Athena data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Amazon Athena ODBC data source:
ODBC{"connectionstring":"dsn=AmazonAthenaDSN"}
dsn=AmazonAthenaDSN
dsn=AmazonAthenaDSN
= Odbc.Query("dsn=AmazonAthenaDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Amazon Athena data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_AMAZON_ATHENA_IN_GATEWAY], 'SELECT * FROM "r53_rlogs" ORDER BY query_timestamp DESC')
SELECT * FROM OPENQUERY([LS_TO_AMAZON_ATHENA_IN_GATEWAY], 'SELECT * FROM "r53_rlogs" ORDER BY query_timestamp DESC') - Click OK and load the data. Your Amazon Athena data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Amazon AthenaQuery Amazon Athena catalogs and S3 results from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.AmazonAthenaDSN
AmazonAthenaDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];';ClassName='com.amazon.athena.jdbc.AthenaDriver';DriverPath='C:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jar';UserName='';UserPassword='';ConnParams='optional for Amazon Athena'
Open DBeaver.
com.amazon.athena.jdbc.AthenaDriver):
Go to the Libraries tab, click Add File, and select your Amazon Athena driver library file(s), e.g.
C:\ZappySys\Jdbc\Amazon Athena\athena-jdbc-3.8.1-with-dependencies.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:athena://WorkGroup=[$WorkGroup$];Region=[$Region$];Catalog=[$Catalog$];OutputLocation=[$OutputLocation$];), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Amazon Athena data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Amazon Athena data source in the gateway
In this section we will create a data source for Amazon Athena in the Data Gateway. Let's follow these steps to accomplish that:
AmazonAthenaDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Amazon Athena ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
AmazonAthenaDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Amazon AthenaQuery Amazon Athena catalogs and S3 results from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.AmazonAthenaDSN
AmazonAthenaDSN(the one we used in the Data Gateway):AmazonAthenaDSNAmazonAthenaDSN
Finally, we are ready to read data from Amazon Athena in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Amazon Athena data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Amazon Athena in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Amazon Athena, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
