You can connect to your Apache Cassandra data from Power BI via the high-performance Apache Cassandra ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Cassandra
  • Working with Apache Cassandra data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Cassandra.
Download Apache Cassandra JDBC driver
To connect to Apache Cassandra, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Cassandra website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Cassandra\cassandra-jdbc-wrapper-4.15.0-bundle.jar.
  4. Prefer the GitHub bundle JAR (cassandra-jdbc-wrapper-4.15.0-bundle.jar). The thin Maven artifact does not include the DataStax Java driver.
  5. Done! That was easy, wasn't it? Let's proceed to the next step.
Create data source using Apache Cassandra ODBC Driver
To get data from Apache Cassandra using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Cassandra.
    Cassandra connection
    Apache Cassandra authentication
    Apache Cassandra JDBC (ING wrapper + DataStax Java driver bundle) from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. One tile covers Cassandra, Amazon Keyspaces, and ScyllaDB -- edit the JDBC URL after Finish rather than picking a second connector.
    1. Note contact points (host1, host2), native port (default 9042), keyspace, and local datacenter name (required by the default load-balancing policy).
    2. Create a Cassandra role if the cluster requires authentication. Paste user and password. Lab clusters sometimes allow empty credentials.
    3. The wizard downloads the GitHub bundle JAR (shaded with the DataStax driver). Do not use the thin Maven JAR alone.
    4. After Finish, replace hosts (e.g. MyHostName), port (e.g. 9042), keyspace (e.g. MyKeyspace), and local datacenter (e.g. DC1). The driver uses -- between hosts (not a comma).
    5. Amazon Keyspaces: use jdbc:cassandra:aws://cassandra.REGION.amazonaws.com:9142/keyspace?awsregion=REGION plus SSL/IAM as in the AWS Keyspaces Java-driver docs. ScyllaDB uses the same jdbc:cassandra:// URL on port 9042.
    6. Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
    7. Done. You can query from C#, Python, PowerShell, and ODBC apps.
    3. Finally, hit OK button:
    • Connection string: jdbc:cassandra://[$HostName$]:[$Port$]/[$Keyspace$]?localdatacenter=[$LocalDataCenter$]
    • Driver class: com.ing.data.cassandra.jdbc.CassandraDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Cassandra\cassandra-jdbc-wrapper-4.15.0-bundle.jar
    • Host: MyHostName
    • TCP port: 9042
    • Keyspace: MyKeyspace
    • Local data center: DC1
    • User name:
    • Password:
    ApacheCassandraDSN
    optional for Apache Cassandra
    Find full details in the Apache Cassandra Connector authentication reference.
    SSL
    Cassandra / Scylla / Keyspaces with SSL. The bundle JAR still applies. Set JSSE truststore properties on the Bridge JVM when the cluster uses a private CA.
    1. Enable client-to-node encryption on the cluster (or use Amazon Keyspaces, which requires TLS on 9142).
    2. This Auth sets enablessl=true. Point javax.net.ssl.trustStore at a JKS that trusts the cluster CA if the default Java truststore is not enough.
    3. Create a database role. Paste user and password. For Keyspaces IAM, keep this tile and put access-key style credentials in user/password after switching the URL to the jdbc:cassandra:aws:// form -- do not add a second catalog tile.
    4. After Finish, replace hosts (e.g. MyHostName), keyspace (e.g. MyKeyspace), and local datacenter (for Keyspaces, local datacenter is the AWS region name).
    • Connection string: jdbc:cassandra://[$HostName$]:[$Port$]/[$Keyspace$]?localdatacenter=[$LocalDataCenter$]&enablessl=[$EnableSsl$]
    • Host: MyHostName
    • TCP port: 9042
    • Enable SSL: true
    • User name:
    • Password:
    ApacheCassandraDSN
    Jump to troubleshooter
    ApacheCassandraDSN
    SELECT table_name
    FROM system_schema.tables
    WHERE keyspace_name = 'MyKeyspace'
    SELECT table_name
Connect to Apache Cassandra data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheCassandraDSN and continue:
    ApacheCassandraDSN
    ApacheCassandraDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Cassandra in a Power BI report:
If you wish to import Apache Cassandra data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheCassandraDSN
SELECT table_name
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Cassandra ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheCassandraDSN"}
    = Odbc.Query("dsn=ApacheCassandraDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Cassandra data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Cassandra Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_CASSANDRA_IN_GATEWAY], 'SELECT table_name FROM system_schema.tables WHERE keyspace_name = ''MyKeyspace''')
    DirectQuery option for Power BI (read Apache Cassandra data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Cassandra data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Cassandra
    Query Apache Cassandra, Amazon Keyspaces, and ScyllaDB with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheCassandraDSN
    ApacheCassandraDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:cassandra://[$HostName$]:[$Port$]/[$Keyspace$]?localdatacenter=[$LocalDataCenter$]';ClassName='com.ing.data.cassandra.jdbc.CassandraDriver';DriverPath='C:\ZappySys\Jdbc\Apache Cassandra\cassandra-jdbc-wrapper-4.15.0-bundle.jar';UserName='';UserPassword='';ConnParams='optional for Apache Cassandra'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (com.ing.data.cassandra.jdbc.CassandraDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Cassandra driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Cassandra\cassandra-jdbc-wrapper-4.15.0-bundle.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:cassandra://[$HostName$]:[$Port$]/[$Keyspace$]?localdatacenter=[$LocalDataCenter$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Cassandra data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Cassandra data source in the gateway
In this section we will create a data source for Apache Cassandra in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheCassandraDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Cassandra ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheCassandraDSN
      ApacheCassandraDSN
      ApacheCassandraDSN
  5. Then set the default database property to ApacheCassandraDSN (the one we used in the Data Gateway):
    ApacheCassandraDSN
    ApacheCassandraDSN
Finally, we are ready to read data from Apache Cassandra in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Cassandra data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Cassandra in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Cassandra, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
