You can connect to your Zoho SalesIQ data from Power BI via the high-performance Zoho SalesIQ ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Zoho SalesIQ
  • Working with Zoho SalesIQ data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Zoho SalesIQ Connector.
To get data from Zoho SalesIQ using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho SalesIQ" from the list of Popular Connectors. If "Zoho SalesIQ" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ZohoSalesiqDSN
    Zoho SalesIQ
    • Configure the authentication in Zoho SalesIQ.
    Zoho SalesIQ authentication
    1. Go to Zoho API Console
    2. Click Add Client link
    7. Click CREATE.
    ZohoSalesiqDSN
    Zoho SalesIQ
    OAuth [OAuth]
    https://salesiq.zoho.com/api/v2/[$Compnay$]
    Company Screen Name for URL (e.g. mycompany)
    ClientId
    ClientSecret
    Permissions SalesIQ.operators.READ SalesIQ.conversations.READ SalesIQ.feedbacks.READ SalesIQ.departments.READ
    Find full details in the Zoho SalesIQ Connector authentication reference.
    ZappySys API Driver - Zoho SalesIQ
    Read and write Zoho SalesIQ data effortlessly. Integrate, manage, and automate chats and visits — almost no coding required.
    ZohoSalesiqDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Zoho SalesIQ. Hit OK button to use this query in the next step.
    SELECT * FROM Departments
    Some parameters configured in this window will be passed to the Zoho SalesIQ API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    ZohoSalesiqDSN
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Zoho SalesIQ API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho SalesIQ servers).
Connect to Zoho SalesIQ data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ZohoSalesiqDSN and continue:
    ZohoSalesiqDSN
    ZohoSalesiqDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Zoho SalesIQ in a Power BI report:
If you wish to import Zoho SalesIQ data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ZohoSalesiqDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Zoho SalesIQ ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ZohoSalesiqDSN"}
    dsn=ZohoSalesiqDSN
    dsn=ZohoSalesiqDSN
    = Odbc.Query("dsn=ZohoSalesiqDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Zoho SalesIQ data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Zoho SalesIQ Service
    SELECT * FROM OPENQUERY([LS_TO_ZOHO_SALESIQ_IN_GATEWAY], 'SELECT * FROM Departments')
    DirectQuery option for Power BI (read Zoho SalesIQ data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Zoho SalesIQ data is now linked live rather than imported.
    ZohoSalesiqDSN
    ZohoSalesiqDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://salesiq.zoho.com/api/v2/[$Compnay$];Provider=Custom;OAuthVersion=OAuth2;ScopeSeparator={space};ReturnUrl=[$RedirectUrl$];ExtraAttributesForAuthRequest=access_type=offline&prompt=consent;AuthUrl=[$AccountUrl$]/oauth/v2/auth;TokenUrl=[$AccountUrl$]/oauth/v2/token;ClientId=[$ClientId$];ClientSecret=[$ClientSecret$];Scope=[$Permissions$];ExpiresInAttribute=expires_in_sec;
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho SalesIQ operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Zoho SalesIQ data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Zoho SalesIQ data source in the gateway
In this section we will create a data source for Zoho SalesIQ in the Data Gateway. Let's follow these steps to accomplish that:
    ZohoSalesiqDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zoho SalesIQ ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ZohoSalesiqDSN
      ZohoSalesiqDSN
      ZohoSalesiqDSN
  5. Then set the default database property to ZohoSalesiqDSN (the one we used in the Data Gateway):
    ZohoSalesiqDSN
    ZohoSalesiqDSN
Finally, we are ready to read data from Zoho SalesIQ in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Zoho SalesIQ data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Zoho SalesIQ in Power BI and integrate your data — all without writing complex code.
