You can connect to your ServiceNow data from Power BI via the high-performance ServiceNow ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to ServiceNow
  • Working with ServiceNow data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the ServiceNow Connector.
Create data source using ServiceNow ODBC Driver
To get data from ServiceNow using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "ServiceNow" from the list of Popular Connectors. If "ServiceNow" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    ServicenowDSN
    ServiceNow
    • Configure the authentication in ServiceNow.
    Basic Auth (UserName and Password)
    ServiceNow authentication
    Authenticate using ServiceNow instance username and password.
    Locate your ServiceNow instance credentials and use them for HTTP authentication:
    1. Go to https://developer.servicenow.com/dev.do and log in.
    2. Click on your profile picture.
    3. When a menu appears, click on Manage instance password or a similar option:
      Manage instance password in ServiceNow
    4. In a new window you will see your HTTP Basic Authentication credentials:
      Use instance credentials to authenticate to ServiceNow
    5. Done! Use this username and password when configuring HTTP Authentication parameters.
    1. Set Authentication Type to Basic Auth (UserName and Password) [Http]
    ServicenowDSN
    ServiceNow
    https://[$InstanceName$].service-now.com/api/now
    InstanceName (e.g. mycompany) Fill-in the parameter...
    User name Fill-in the parameter...
    ApiVersion v2
    Date Time Value Handling
    Find full details in the ServiceNow Connector authentication reference.
    OAuth Authorization Code Grant (User Creds)
    Authenticate using OAuth 2.0 Authorization Code Flow (3-legged)
    Create OAuth application and use it for authentication:
    1. Login to your instance at https://your-instance-id.service-now.com.
    2. Start by clicking on menu item All, then search for oauth, and click Application Registry option:
      Locate OAuth configuration in ServiceNow
    3. Then click button New:
      Create new OAuth application in ServiceNow
    4. Continue by clicking Create an OAuth API endpoint for external clients option:
      Use ServiceNow OAuth application for external clients
    5. Move on by naming your OAuth application and entering a Client Secret (or let it be generated automatically).
    6. Click on the lock icon next to the Redirect URL. Enter https://zappysys.com/oauth. This is not needed if you use Client Credentials Grant or Password Grant
    7. Finally give it a final touch by increasing the Refresh Token Lifespan value to 315,360,000 (it should last for 10 years):
      Configure OAuth application in ServiceNow
    8. Change Default Grant Type as per your need.
      NOTE: If you prefer to use Client Credentials grant (Service account style access without using real userid-password) then your admin must enable it. Client Credentials is only supported on instances where it is explicitly enabled by the ServiceNow administrator. Its not supported in Dev / Free instance.
    9. Done! Now you can use Client ID and Client Secret when configuring OAuth Authentication parameters.
    Enable Client Credentials Grant Type
    • Enable the Client Credentials Grant Type: Go to System Properties > All Properties, create a new property named glide.oauth.inbound.client.credential.grant_type.enabled, and set it to true.
    • Configure the OAuth Application: Navigate to System OAuth > Application Registry, click New, and select Create an OAuth API endpoint for external clients. Set the name and save the record. In the Default Grant Type field, select Client Credentials and associate it with the integration user.
    1. Set Authentication Type to OAuth Authorization Code Grant (User Creds) [OAuth]
    ServicenowDSN
    ServiceNow
    Redirect URI (***Must match as App Registry Page***) Fill-in the parameter...
    OAuth Client Credentials Grant (Must be enabled by Admin)
    Authenticate using OAuth Client Credentials Grant (Client ID and Client Secret). [API reference]
    1. Set Authentication Type to OAuth Client Credentials Grant (Must be enabled by Admin) [OAuth]
    ServicenowDSN
    ServiceNow
    There are no parameters to configure.
    OAuth Password Grant
    Authenticate using OAuth Password Grant (ServiceNow instance username, password, OAuth Client ID, and Client Secret). [API reference]
    1. Set Authentication Type to OAuth Password Grant [OAuth]
    ServicenowDSN
    ServiceNow
    ZappySys API Driver - ServiceNow
    Read and write ServiceNow data effortlessly. Integrate, manage, and automate incidents, tasks, attachments, and records — almost no coding required.
    ServicenowDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from ServiceNow. Hit OK button to use this query in the next step.
    SELECT * FROM incident
    --Using Primary Key
    --SELECT * FROM any_table_here WHERE sys_id='109562a3c611227500a7b7ff98cc0dc7' --Primary Key in WHERE clause
    --OR--
    --Use below to query system / hidden tables (faster response - No Table name lookup needed in below)
    SELECT * FROM get_table_rows WITH(TableName='incident', Query='number=INC0000001')
    --Examples: Using Filter Expression
    -- Incremental Load Pattern: Load only incidents updated in the last 24 hours (see FUN_TO_DATETIME function help for more information, you can use +/- d, m, y, min,h,s along with now, today, yesterday, weekstart, weekend, monthstart, monthend, yearstart, yearend functions)
    --SELECT * FROM incident WITH(Query='sys_updated_on>=<<today-1d,FUN_TO_DATETIME>>')
    --SELECT * FROM incident WITH(Query='number=INC0000001') --Equal condition
    --SELECT * FROM incident WITH(Query='number!=INC0000001') --Not equal condition
    --SELECT * FROM incident WITH(Query='numberININC0000001,INC0000002,INC0000003') --IN condition
    --SELECT * FROM incident WITH(Query='number=INC0000001^state=7') --AND condition
    --SELECT * FROM incident WITH(Query='number=INC0000001^ORnumber=INC0000002') --OR condition
    --SELECT * FROM incident WITH(Query='numberLIKE0001') --LIKE condition
    --SELECT * FROM incident WITH(Query='numberSTARTSWITHINC00') --StartWith condition
    --SELECT * FROM incident WITH(Query='numberENDSWITH0001') --StartWith condition
    --SELECT * FROM incident WITH(Query='number=INC0000001^state=7^NQORnumber=INC0000002') --AND / OR MIXED using NQ (NewQuery Operator)  -- (number=INC0000001 and state=7) OR (number=INC0000002)
    --more information about filter here https://docs.servicenow.com/bundle/utah-platform-user-interface/page/use/common-ui-elements/reference/r_OpAvailableFiltersQueries.html
    -- To read all available tables execute this query:
    -- SELECT * FROM Tables
    -- Other common tables:
    -- SELECT * FROM sys_db_object
    -- SELECT * FROM sys_dictionary
    -- SELECT * FROM sys_user
    -- SELECT * FROM sys_user_has_role
    -- SELECT * FROM sys_user_grmember
    -- SELECT * FROM task
    -- SELECT * FROM task_sla
    -- SELECT * FROM incident
    -- SELECT * FROM incident_sla
    -- SELECT * FROM change_request
    -- SELECT * FROM cmdb_ci_computer
    -- SELECT * FROM cmdb_ci_outage
    -- SELECT * FROM sn_customerservice_case
    -- SELECT * FROM kb_knowledge
    -- SELECT * FROM kb_use
    -- SELECT * FROM sc_req_item
    -- SELECT * FROM sc_request
    -- SELECT * FROM sc_task
    Some parameters configured in this window will be passed to the ServiceNow API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    ServicenowDSN
    --Using Primary Key
    --OR--
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the ServiceNow API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ServiceNow servers).
Connect to ServiceNow data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ServicenowDSN and continue:
    ServicenowDSN
    ServicenowDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from ServiceNow in a Power BI report:
If you wish to import ServiceNow data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ServicenowDSN
--Using Primary Key
--OR--
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local ServiceNow ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ServicenowDSN"}
    dsn=ServicenowDSN
    dsn=ServicenowDSN
    = Odbc.Query("dsn=ServicenowDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports ServiceNow data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from ServiceNow Service
    SELECT * FROM OPENQUERY([LS_TO_SERVICENOW_IN_GATEWAY], 'SELECT * FROM incident --Using Primary Key --SELECT * FROM any_table_here WHERE sys_id=''109562a3c611227500a7b7ff98cc0dc7'' --Primary Key in WHERE clause --OR-- --Use below to query system / hidden tables (faster response - No Table name lookup needed in below) SELECT * FROM get_table_rows WITH(TableName=''incident'', Query=''number=INC0000001'') --================================= --Examples: Using Filter Expression --================================= -- Incremental Load Pattern: Load only incidents updated in the last 24 hours (see FUN_TO_DATETIME function help for more information, you can use +/- d, m, y, min,h,s along with now, today, yesterday, weekstart, weekend, monthstart, monthend, yearstart, yearend functions) --SELECT * FROM incident WITH(Query=''sys_updated_on>=<<today-1d,FUN_TO_DATETIME>>'') --SELECT * FROM incident WITH(Query=''number=INC0000001'') --Equal condition --SELECT * FROM incident WITH(Query=''number!=INC0000001'') --Not equal condition --SELECT * FROM incident WITH(Query=''numberININC0000001,INC0000002,INC0000003'') --IN condition --SELECT * FROM incident WITH(Query=''number=INC0000001^state=7'') --AND condition --SELECT * FROM incident WITH(Query=''number=INC0000001^ORnumber=INC0000002'') --OR condition --SELECT * FROM incident WITH(Query=''numberLIKE0001'') --LIKE condition --SELECT * FROM incident WITH(Query=''numberSTARTSWITHINC00'') --StartWith condition --SELECT * FROM incident WITH(Query=''numberENDSWITH0001'') --StartWith condition --SELECT * FROM incident WITH(Query=''number=INC0000001^state=7^NQORnumber=INC0000002'') --AND / OR MIXED using NQ (NewQuery Operator) -- (number=INC0000001 and state=7) OR (number=INC0000002) --more information about filter here https://docs.servicenow.com/bundle/utah-platform-user-interface/page/use/common-ui-elements/reference/r_OpAvailableFiltersQueries.html -- To read all available tables execute this query: -- SELECT * FROM Tables -- Other common tables: ----------------------- -- SELECT * FROM sys_db_object -- SELECT * FROM sys_dictionary -- SELECT * FROM sys_user -- SELECT * FROM sys_user_has_role -- SELECT * FROM sys_user_grmember -- SELECT * FROM task -- SELECT * FROM task_sla -- SELECT * FROM incident -- SELECT * FROM incident_sla -- SELECT * FROM change_request -- SELECT * FROM cmdb_ci_computer -- SELECT * FROM cmdb_ci_outage -- SELECT * FROM cmdb_ci -- SELECT * FROM sn_customerservice_case -- SELECT * FROM kb_knowledge -- SELECT * FROM kb_use -- SELECT * FROM sc_req_item -- SELECT * FROM sc_request -- SELECT * FROM sc_task')
    DirectQuery option for Power BI (read ServiceNow data example using SQL Server Linked Server and ZappySys Data Gateway)
    --Using Primary Key
    --OR--
  7. Click OK and load the data. Your ServiceNow data is now linked live rather than imported.
    ServicenowDSN
    ServicenowDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://[$InstanceName$].service-now.com/api/now;CredentialType=Basic;UserName=[$UserName$];Password=[$Password$];RetryMode=[$RetryMode$];RetryCountMax=[$RetryCountMax$];RetryMultiplyWaitTime=[$RetryMultiplyWaitTime$];RetryStatusCodeList=[$RetryStatusCodeList$];
ServiceNow Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential ServiceNow operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide ServiceNow data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create ServiceNow data source in the gateway
In this section we will create a data source for ServiceNow in the Data Gateway. Let's follow these steps to accomplish that:
    ServicenowDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the ServiceNow ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ServicenowDSN
      ServicenowDSN
      ServicenowDSN
  5. Then set the default database property to ServicenowDSN (the one we used in the Data Gateway):
    ServicenowDSN
    ServicenowDSN
Finally, we are ready to read data from ServiceNow in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to ServiceNow data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to ServiceNow in Power BI and integrate your data — all without writing complex code.
