You can connect to your ManageEngine ServiceDesk Plus (Zoho) data from Power BI via the high-performance ManageEngine ServiceDesk Plus (Zoho) ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to ManageEngine ServiceDesk Plus (Zoho)
- Working with ManageEngine ServiceDesk Plus (Zoho) data directly inside Power BI
To get data from ManageEngine ServiceDesk Plus (Zoho) using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Click Add Client link
- Click CREATE.
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from ManageEngine ServiceDesk Plus (Zoho). Hit OK button to use this query in the next step.
SELECT * FROM Requests
Some parameters configured in this window will be passed to the ManageEngine ServiceDesk Plus (Zoho) API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - ManageEngine ServiceDesk Plus (Zoho)Read and write ServiceDesk Plus (Zoho) data effortlessly. Integrate, manage, and automate requests, tasks, comments, and worklogs — almost no coding required.ManageengineServicedeskPlusZohoDSNSELECT * FROM Requests
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the ManageEngine ServiceDesk Plus (Zoho) API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in ManageEngine ServiceDesk Plus (Zoho) servers). -
Connect to ManageEngine ServiceDesk Plus (Zoho) data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ManageengineServicedeskPlusZohoDSN and continue:
Finally, finally, read extracted data from ManageEngine ServiceDesk Plus (Zoho) in a Power BI report:
If you wish to import ManageEngine ServiceDesk Plus (Zoho) data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local ManageEngine ServiceDesk Plus (Zoho) ODBC data source:
ODBC{"connectionstring":"dsn=ManageengineServicedeskPlusZohoDSN"}
= Odbc.Query("dsn=ManageengineServicedeskPlusZohoDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports ManageEngine ServiceDesk Plus (Zoho) data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_MANAGEENGINE_SERVICEDESK_PLUS_ZOHO_IN_GATEWAY], 'SELECT * FROM Requests')
SELECT * FROM OPENQUERY([LS_TO_MANAGEENGINE_SERVICEDESK_PLUS_ZOHO_IN_GATEWAY], 'SELECT * FROM Requests') - Click OK and load the data. Your ManageEngine ServiceDesk Plus (Zoho) data is now linked live rather than imported.
ManageengineServicedeskPlusZohoDSNDRIVER={ZappySys API Driver};ServiceUrl=https://sdpondemand.manageengine.com/api/v3;Provider=Custom;OAuthVersion=OAuth2;ScopeSeparator={space};ReturnUrl=[$RedirectUrl$];ExtraAttributesForAuthRequest=access_type=offline&prompt=consent;AuthUrl=[$AccountUrl$]/oauth/v2/auth;TokenUrl=[$AccountUrl$]/oauth/v2/token;ClientId=[$ClientId$];ClientSecret=[$ClientSecret$];Scope=[$Permissions$];ExpiresInAttribute=expires_in_sec;
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential ManageEngine ServiceDesk Plus (Zoho) operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Requests
- Get Request Details
- Get Request Tasks
- Get Request Task Details
- Get Request Task Comments
- Get Request Notes
- Get Request Note Details
- Get Request Worklogs
- Get Request Worklog Details
- Get Request Task Worklogs
- Delete Request
- Test Connection
- Get Changes
- Get Change Details
- Get Change Tasks
- Get Change Task Details
- Get Change Task Comments
- Get Change Notes
- Get Change Note Details
- Get Change Worklogs
- Get Change Worklog Details
- Get Change Task Worklogs
- Get Problems
- Get Problem Details
- Get Problem Tasks
- Get Problem Task Details
- Get Problem Task Comments
- Get Problem Task Comment Details
- Get Problem Notes
- Get Problem Note Details
- Get Problem Worklogs
- Get Problem Worklog Details
- Get Problem Task Worklogs
- Get Projects
- Get Project Details
- Get Project Tasks
- Get Project Members
- Get Project Milestones
- Get Project Milestone Tasks
- Get Project Task Details
- Get Project Task Comments
- Get Project Notes
- Get Project Note Details
- Get Project Worklogs
- Get Project Worklog Details
- Get Project Task Worklogs
- Get Releases
- Get Release Details
- Get Release Tasks
- Get Release Task Details
- Get Release Task Comments
- Get Release Notes
- Get Release Note Details
- Get Release Worklogs
- Get Release Worklog Details
- Get Release Task Worklogs
- Get Assets
- Get Asset Details
- Get Tasks
- Get Task Details
- Get Contracts
- Get Contract Details
- Get Purchase Orders
- Get Purchase Order Details
In some situations, you may need to provide ManageEngine ServiceDesk Plus (Zoho) data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create ManageEngine ServiceDesk Plus (Zoho) data source in the gateway
In this section we will create a data source for ManageEngine ServiceDesk Plus (Zoho) in the Data Gateway. Let's follow these steps to accomplish that:
ManageengineServicedeskPlusZohoDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the ManageEngine ServiceDesk Plus (Zoho) ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ManageengineServicedeskPlusZohoDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - ManageEngine ServiceDesk Plus (Zoho)Read and write ServiceDesk Plus (Zoho) data effortlessly. Integrate, manage, and automate requests, tasks, comments, and worklogs — almost no coding required.ManageengineServicedeskPlusZohoDSN
ManageengineServicedeskPlusZohoDSN(the one we used in the Data Gateway):ManageengineServicedeskPlusZohoDSNManageengineServicedeskPlusZohoDSN
Finally, we are ready to read data from ManageEngine ServiceDesk Plus (Zoho) in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to ManageEngine ServiceDesk Plus (Zoho) data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to ManageEngine ServiceDesk Plus (Zoho) in Power BI and integrate your data — all without writing complex code.
