You can connect to your Apache IoTDB data from Power BI via the high-performance Apache IoTDB ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Apache IoTDB
- Working with Apache IoTDB data directly inside Power BI
Download Apache IoTDB JDBC driver
To connect to Apache IoTDB, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Apache IoTDB website or MVN Repository.
C:\ZappySys\Jdbc\Apache IoTDB\iotdb-jdbc-2.0.8-jar-with-dependencies.jar.
Create data source using Apache IoTDB ODBC Driver
To get data from Apache IoTDB using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Apache IoTDB.
Tree model
Apache IoTDB authentication
Apache IoTDB (tree) JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Note the IoTDB host and RPC port (default
6667). - Create a user in IoTDB (
CREATE USER) or userootin a lab only. - Tree model uses path-style time series. Switch to Table dialect Auth if you enabled table SQL.
Connection string :jdbc:iotdb://[$HostName$]:[$Port$]/ -
Driver class :org.apache.iotdb.jdbc.IoTDBDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Apache IoTDB\iotdb-jdbc-2.0.8-jar-with-dependencies.jar -
Host :MyHostName -
TCP port :6667 -
User name : -
Password :
ApacheIotdbDSNjdbc:iotdb://[$HostName$]:[$Port$]/org.apache.iotdb.jdbc.IoTDBDriverC:\ZappySys\Jdbc\Apache IoTDB\iotdb-jdbc-2.0.8-jar-with-dependencies.jaroptional for Apache IoTDB
Find full details in the Apache IoTDB Connector authentication reference.Table dialect
Apache IoTDB (table) JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Same host/port as tree. Append
sql_dialect=table(already in this URL). - Fill user and password. Table dialect uses
SHOW TABLES/ relational SQL. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:iotdb://[$HostName$]:[$Port$]/?sql_dialect=[$SqlDialect$] -
Host :MyHostName -
TCP port :6667 -
SQL dialect :table -
User name : -
Password :
ApacheIotdbDSNjdbc:iotdb://[$HostName$]:[$Port$]/?sql_dialect=[$SqlDialect$]org.apache.iotdb.jdbc.IoTDBDriverC:\ZappySys\Jdbc\Apache IoTDB\iotdb-jdbc-2.0.8-jar-with-dependencies.jaroptional for Apache IoTDB
Find full details in the Apache IoTDB Connector authentication reference. -
ApacheIotdbDSNSHOW TIMESERIES
SHOW TIMESERIESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Apache IoTDB data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ApacheIotdbDSN and continue:
ApacheIotdbDSN
ApacheIotdbDSN
Finally, finally, read extracted data from Apache IoTDB in a Power BI report:
If you wish to import Apache IoTDB data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
SHOW TIMESERIES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache IoTDB ODBC data source:
ODBC{"connectionstring":"dsn=ApacheIotdbDSN"}
dsn=ApacheIotdbDSN
dsn=ApacheIotdbDSN
= Odbc.Query("dsn=ApacheIotdbDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Apache IoTDB data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_APACHE_IOTDB_IN_GATEWAY], 'SHOW TIMESERIES')
SELECT * FROM OPENQUERY([LS_TO_APACHE_IOTDB_IN_GATEWAY], 'SHOW TIMESERIES') - Click OK and load the data. Your Apache IoTDB data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - Apache IoTDBQuery Apache IoTDB with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheIotdbDSN
ApacheIotdbDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:iotdb://[$HostName$]:[$Port$]/';ClassName='org.apache.iotdb.jdbc.IoTDBDriver';DriverPath='C:\ZappySys\Jdbc\Apache IoTDB\iotdb-jdbc-2.0.8-jar-with-dependencies.jar';UserName='';UserPassword='';ConnParams='optional for Apache IoTDB'
Open DBeaver.
org.apache.iotdb.jdbc.IoTDBDriver):
Go to the Libraries tab, click Add File, and select your Apache IoTDB driver library file(s), e.g.
C:\ZappySys\Jdbc\Apache IoTDB\iotdb-jdbc-2.0.8-jar-with-dependencies.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:iotdb://[$HostName$]:[$Port$]/), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Apache IoTDB data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache IoTDB data source in the gateway
In this section we will create a data source for Apache IoTDB in the Data Gateway. Let's follow these steps to accomplish that:
ApacheIotdbDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache IoTDB ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ApacheIotdbDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - Apache IoTDBQuery Apache IoTDB with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.ApacheIotdbDSN
ApacheIotdbDSN(the one we used in the Data Gateway):ApacheIotdbDSNApacheIotdbDSN
Finally, we are ready to read data from Apache IoTDB in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Apache IoTDB data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache IoTDB in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache IoTDB, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
