You can connect to your Databend data from Power BI via the high-performance Databend ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to Databend
- Working with Databend data directly inside Power BI
Download Databend JDBC driver
To connect to Databend, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit Databend website or MVN Repository.
C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar.
Create data source using Databend ODBC Driver
To get data from Databend using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in Databend.
Host (HTTP)
Databend authentication
Databend JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- In Databend Cloud or self-hosted, copy the warehouse host and port (often
8000HTTP or443TLS). - Create a SQL user and database. Paste user and password here.
- For Cloud SSL, use the HTTPS Auth and keep SSL flags as documented in Databend JDBC Connection.md.
Connection string :jdbc:databend://[$HostName$]:[$Port$]/[$Database$] -
Driver class :com.databend.jdbc.DatabendDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar -
Host :MyHostName -
TCP port :8000 -
Database name :MyDatabase -
User name : -
Password :
DatabendDSNjdbc:databend://[$HostName$]:[$Port$]/[$Database$]com.databend.jdbc.DatabendDriverC:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jaroptional for Databend
Find full details in the Databend Connector authentication reference.Host (SSL)
Databend SSL JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Use the Cloud SQL endpoint and port 443.
- Create a user in the Databend console. Paste user and password.
- Do not turn SSL off on Cloud.
Connection string :jdbc:databend://[$HostName$]:[$Port$]/[$Database$]?ssl=[$Ssl$] -
Host :MyHostName -
TCP port :443 -
SSL :true -
User name : -
Password :
DatabendDSNjdbc:databend://[$HostName$]:[$Port$]/[$Database$]?ssl=[$Ssl$]com.databend.jdbc.DatabendDriverC:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jaroptional for Databend
Find full details in the Databend Connector authentication reference. -
DatabendDSNSHOW TABLES
SHOW TABLESYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to Databend data in Power BI
Another window opens and asks to select a Data Source we already created. Choose DatabendDSN and continue:
DatabendDSN
DatabendDSN
Finally, finally, read extracted data from Databend in a Power BI report:
If you wish to import Databend data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
SHOW TABLES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Databend ODBC data source:
ODBC{"connectionstring":"dsn=DatabendDSN"}
dsn=DatabendDSN
dsn=DatabendDSN
= Odbc.Query("dsn=DatabendDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Databend data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_DATABEND_IN_GATEWAY], 'SHOW TABLES')
SELECT * FROM OPENQUERY([LS_TO_DATABEND_IN_GATEWAY], 'SHOW TABLES') - Click OK and load the data. Your Databend data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - DatabendQuery Databend (cloud warehouse) with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.DatabendDSN
DatabendDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:databend://[$HostName$]:[$Port$]/[$Database$]';ClassName='com.databend.jdbc.DatabendDriver';DriverPath='C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar';UserName='';UserPassword='';ConnParams='optional for Databend'
Open DBeaver.
com.databend.jdbc.DatabendDriver):
Go to the Libraries tab, click Add File, and select your Databend driver library file(s), e.g.
C:\ZappySys\Jdbc\Databend\databend-jdbc-0.3.9.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:databend://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide Databend data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Databend data source in the gateway
In this section we will create a data source for Databend in the Data Gateway. Let's follow these steps to accomplish that:
DatabendDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Databend ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
DatabendDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - DatabendQuery Databend (cloud warehouse) with the official JDBC driver from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.DatabendDSN
DatabendDSN(the one we used in the Data Gateway):DatabendDSNDatabendDSN
Finally, we are ready to read data from Databend in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Databend data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Databend in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Databend, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
