You can connect to your HSQLDB data from Power BI via the high-performance HSQLDB ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
- Configuring a secure connection to HSQLDB
- Working with HSQLDB data directly inside Power BI
Download HSQLDB JDBC driver
To connect to HSQLDB, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
Visit HSQLDB website or MVN Repository.
C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar.
Create data source using HSQLDB ODBC Driver
To get data from HSQLDB using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
- Configure the authentication in HSQLDB.
In-memory
HSQLDB authentication
HSQLDB in-memory JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- No server. Data lasts for this DSN process only.
- Default user is often
SAwith empty password. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:hsqldb:mem:[$Database$] -
Driver class :org.hsqldb.jdbc.JDBCDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar -
Database name :MyDatabase -
User name : -
Password :
HsqldbDSNjdbc:hsqldb:mem:[$Database$]org.hsqldb.jdbc.JDBCDriverC:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jaroptional for HSQLDB
Find full details in the HSQLDB Connector authentication reference.Local file
HSQLDB file JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- The wizard downloads the JDK 8 JAR into
C:\ZappySys\Jdbc\HSQLDB. The database files are created ashsqldb.*in that folder. - Default user
SA/ empty password unless you set one. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:hsqldb:file:C:\ZappySys\Jdbc\HSQLDB\hsqldb -
User name : -
Password :
HsqldbDSNjdbc:hsqldb:file:C:\ZappySys\Jdbc\HSQLDB\hsqldborg.hsqldb.jdbc.JDBCDriverC:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jaroptional for HSQLDB
Find full details in the HSQLDB Connector authentication reference.HSQL server
HSQLDB server JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
- Start an HSQL server (default port
9001) or use an existing one. - Replace host, port, and catalog. Fill user and password from that server.
Connection string :jdbc:hsqldb:hsql://[$HostName$]:[$Port$]/[$Database$] -
Host :MyHostName -
TCP port :9001 -
User name : -
Password :
HsqldbDSNjdbc:hsqldb:hsql://[$HostName$]:[$Port$]/[$Database$]org.hsqldb.jdbc.JDBCDriverC:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jaroptional for HSQLDB
Find full details in the HSQLDB Connector authentication reference. -
HsqldbDSNSELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'PUBLIC' ORDER BY TABLE_NAME
SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = 'PUBLIC' ORDER BY TABLE_NAMEYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Connect to HSQLDB data in Power BI
Another window opens and asks to select a Data Source we already created. Choose HsqldbDSN and continue:
HsqldbDSN
HsqldbDSN
Finally, finally, read extracted data from HSQLDB in a Power BI report:
If you wish to import HSQLDB data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local HSQLDB ODBC data source:
ODBC{"connectionstring":"dsn=HsqldbDSN"}
dsn=HsqldbDSN
dsn=HsqldbDSN
= Odbc.Query("dsn=HsqldbDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports HSQLDB data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_HSQLDB_IN_GATEWAY], 'SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = ''PUBLIC'' ORDER BY TABLE_NAME')
SELECT * FROM OPENQUERY([LS_TO_HSQLDB_IN_GATEWAY], 'SELECT TABLE_NAME FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA = ''PUBLIC'' ORDER BY TABLE_NAME') - Click OK and load the data. Your HSQLDB data is now linked live rather than imported.
ZappySys JDBC Bridge Driver - HSQLDBRead and write HyperSQL (HSQLDB) embedded or server databases from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.HsqldbDSN
HsqldbDSNDRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:hsqldb:mem:[$Database$]';ClassName='org.hsqldb.jdbc.JDBCDriver';DriverPath='C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar';UserName='';UserPassword='';ConnParams='optional for HSQLDB'
Open DBeaver.
org.hsqldb.jdbc.JDBCDriver):
Go to the Libraries tab, click Add File, and select your HSQLDB driver library file(s), e.g.
C:\ZappySys\Jdbc\HSQLDB\hsqldb-2.7.4-jdk8.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:hsqldb:mem:[$Database$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In some situations, you may need to provide HSQLDB data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create HSQLDB data source in the gateway
In this section we will create a data source for HSQLDB in the Data Gateway. Let's follow these steps to accomplish that:
HsqldbDSNZappySys JDBC Bridge Driver
When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the HSQLDB ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
HsqldbDSN
ZappySys JDBC Bridge Driver - Configuration [Version: 2.0.1.10418]ZappySys JDBC Bridge Driver - HSQLDBRead and write HyperSQL (HSQLDB) embedded or server databases from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.HsqldbDSN
HsqldbDSN(the one we used in the Data Gateway):HsqldbDSNHsqldbDSN
Finally, we are ready to read data from HSQLDB in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to HSQLDB data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to HSQLDB in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to HSQLDB, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
