You can connect to your Arrow Flight SQL data from Talend Studio via the high-performance Arrow Flight SQL ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
Minimum required version: Java 11
Visit Arrow Flight SQL website or MVN Repository.
C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar.
ArrowFlightSqlDSNZappySys JDBC Bridge Driver
- Configure the authentication in Arrow Flight SQL.
User and password
- Note the Flight SQL host and port (Dremio often uses
32010; other servers differ). Default encryption is on. - Create a database user on the Flight SQL server. Paste user and password.
- If the Bridge JVM is Java 16 or newer, add
--add-opens=java.base/java.nio=ALL-UNNAMEDto the JDBC Bridge JVM options when Arrow reports module-access errors. - After Finish, replace host and port. Set
useEncryption=falseonly for a local plaintext lab. - Finish the wizard. Then click Test Connection on the DSN Main UI (the wizard does not run Test Connection).
Connection string :jdbc:arrow-flight-sql://[$HostName$]:[$Port$] -
Driver class :org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver -
JDBC driver file(s) :C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar -
Host :MyHostName -
TCP port :32010 -
User name : -
Password : -
Use encryption :true
ArrowFlightSqlDSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jaroptional for Arrow Flight SQL
Find full details in the Arrow Flight SQL Connector authentication reference.Token
- Create an API token or personal access token in the Flight SQL server UI (same idea as a Stripe secret key).
- Paste the token into Token. Leave user/password empty unless the server requires both.
- Java 16+ may need
--add-opens=java.base/java.nio=ALL-UNNAMEDon the Bridge JVM. - After Finish, replace host and port. Cloud endpoints often use 443 with TLS.
Host :MyHostName -
TCP port :32010 -
Token : -
ArrowFlightSqlDSNjdbc:arrow-flight-sql://[$HostName$]:[$Port$]org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriverC:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jaroptional for Arrow Flight SQLoptional for Arrow Flight SQLoptional for Arrow Flight SQL
Find full details in the Arrow Flight SQL Connector authentication reference. -
ArrowFlightSqlDSNSELECT * FROM information_schema.tables
SELECT * FROM information_schema.tablesYou can also click on the <Select Table> dropdown and select a table from the list.The ZappySys JDBC Bridge Driver acts as a transparent intermediary, passing SQL queries directly to the JDBC driver, which then handles the query execution. This means the JDBC-ODBC Bridge Driver simply relays the SQL query without altering it.
Read Arrow Flight SQL data in Talend Studio
To read Arrow Flight SQL data in Talend Studio, we'll need to complete several steps. Let's get through them all right away!
Create connection for input
Create a new connection:
Name your connection:
ArrowFlightSqlDSN
Add input
Add output
Run the job
Finally, run the job and integrate your Arrow Flight SQL data:
Open DBeaver.
org.apache.arrow.driver.jdbc.ArrowFlightJdbcDriver):
Go to the Libraries tab, click Add File, and select your Arrow Flight SQL driver library file(s), e.g.
C:\ZappySys\Jdbc\Arrow Flight SQL\flight-sql-jdbc-driver-19.0.0.jar:
Your JDBC driver
jarlibrary is now added:
Enter your JDBC URL (e.g.
jdbc:arrow-flight-sql://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
Learn how to merge multiple
In this guide, we demonstrated how to connect to Arrow Flight SQL in Talend Studio and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Arrow Flight SQL, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
