You can connect to your Asana data from Power BI via the high-performance Asana ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Asana
- Working with Asana data directly inside Power BI
To get data from Asana using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Asana" from the list of Popular Connectors. If "Asana" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
AsanaDSNAsana
- Configure the authentication in Asana.
Personal Access Token
Asana authentication
Here is how to obtain a Personal Access Token (PAT) in Asana:-
Open My apps in Asana portal
and click Create new token button:
Once a popup opens, name your new token:
Then click Copy button to copy the token:
- Now go to SSIS package or ODBC data source and use this token in Personal Access Token authentication configuration.
- Choose Default Workspace and Default Project to work with.
- Done! Now you are ready to use Asana Connector!
Personal Access Token [Http] - Optional step. Modify API Base URL if needed (in most cases default will work).
AsanaDSNAsanaPersonal Access Token [Http]https://app.asana.com/api/1.0Required Parameters Enter Token (Personal Access Token - PAT) Fill-in the parameter... Default Workspace Fill-in the parameter... Default Project Fill-in the parameter... Optional Parameters RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Asana Connector authentication reference.OAuth app
Here is how to register an OAuth app in Asana:-
and click Create new app button:
Once a popup opens, name your app and check two options, and click Create app button:
Then copy Client ID and Client secret and save them in a file (we will need them for authentication):
Continue by selecting OAuth menu item on your left and click Add redirect URL button (you can have your own or use
https://zappysys.com/oauth):
- Proceed by clicking on the Manage distribution section on your left.
Then specify workspaces your app needs to access (use Any workspace to access them all):
- Once you do that, click Save changes button.
- Now go to SSIS package or ODBC data source and use Client ID, Client Secret, and Redirect URL in OAuth app authentication configuration.
OAuth app [OAuth] - Optional step. Modify API Base URL if needed (in most cases default will work).
AsanaDSNAsanaOAuth app [OAuth]https://app.asana.com/api/1.0Required Parameters ClientId Fill-in the parameter... Client Secret Fill-in the parameter... Default Workspace (** Select after Token is generated **) Fill-in the parameter... Default Project (** Select after Token is generated **) Fill-in the parameter... Optional Parameters Permissions default Redirect URL https://zappysys.com/oauth RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Asana Connector authentication reference. -
ZappySys API Driver - AsanaRead and write Asana data effortlessly. Integrate, manage, and automate tasks, projects, workspaces, and time entries — almost no coding required.AsanaDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Asana. Hit OK button to use this query in the next step.
SELECT * FROM Workspaces
Some parameters configured in this window will be passed to the Asana API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - AsanaRead and write Asana data effortlessly. Integrate, manage, and automate tasks, projects, workspaces, and time entries — almost no coding required.AsanaDSNSELECT * FROM Workspaces
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Asana API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Asana servers). -
Connect to Asana data in Power BI
Another window opens and asks to select a Data Source we already created. Choose AsanaDSN and continue:
AsanaDSN
AsanaDSN
Finally, finally, read extracted data from Asana in a Power BI report:
If you wish to import Asana data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Asana ODBC data source:
ODBC{"connectionstring":"dsn=AsanaDSN"}
dsn=AsanaDSN
dsn=AsanaDSN
= Odbc.Query("dsn=AsanaDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Asana data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_ASANA_IN_GATEWAY], 'SELECT * FROM Workspaces')
SELECT * FROM OPENQUERY([LS_TO_ASANA_IN_GATEWAY], 'SELECT * FROM Workspaces') - Click OK and load the data. Your Asana data is now linked live rather than imported.
AsanaDSNDRIVER={ZappySys API Driver};ServiceUrl=https://app.asana.com/api/1.0;CredentialType=Token;
Asana Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Asana operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Get Workspaces
- Get Workspace (Single)
- Get Projects
- Get Project (Single)
- Get Tasks
- Get Sub Tasks
- Get Workspace Tasks
- Search Tasks (Advanced Filter)
- Get Task (Single)
- Get Workspace Teams
- Get Project Sections
- Get Users
- Get User (Single)
- Get Allocations
- Get Attachments (For Project refer to Key-Resources Upload only)
- Download Attachment
- Download Multiple Attachments
- Get Portfolios
- Get Goals
- Get Workspace Custom Fields
- Get Project Custom Fields
- Get Portfolio Custom Fields
- Get User Task Lists
- Get Memberships
- Get Tags
- Get Time Tracking Entries
In some situations, you may need to provide Asana data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Asana data source in the gateway
In this section we will create a data source for Asana in the Data Gateway. Let's follow these steps to accomplish that:
AsanaDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Asana ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
AsanaDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - AsanaRead and write Asana data effortlessly. Integrate, manage, and automate tasks, projects, workspaces, and time entries — almost no coding required.AsanaDSN
AsanaDSN(the one we used in the Data Gateway):AsanaDSNAsanaDSN
Finally, we are ready to read data from Asana in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Asana data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Asana in Power BI and integrate your data — all without writing complex code.
