You can connect to your Apache Flink data from Power BI via the high-performance Apache Flink ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Flink
  • Working with Apache Flink data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Flink.
Download Apache Flink JDBC driver
To connect to Apache Flink, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Flink website or MVN Repository.
  3. Download the JDBC driver, and save it locally, e.g. to C:\ZappySys\Jdbc\Apache Flink\flink-sql-jdbc-driver-bundle-1.19.3.jar.
Create data source using Apache Flink ODBC Driver
To get data from Apache Flink using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Flink.
    Flink SQL Gateway
    Apache Flink authentication
    Apache Flink SQL Gateway JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools. Match the bundle to the gateway major version. This pin is 1.19.3 (Java 11 gateways).
    1. Start a Flink SQL Gateway REST endpoint (default port 8083) bound to your Flink cluster.
    2. The gateway currently ignores user name and password; leave them empty unless your distribution documents otherwise.
    3. JDBC against the gateway is for batch queries. Do not expect interactive streaming CHANGELOG results in Power BI or Linked Server.
    4. After Finish, replace the host (e.g. MyHostName) (and port if the gateway is not on 8083).
    3. Finally, hit OK button:
    • Connection string: jdbc:flink://[$HostName$]:[$Port$]
    • Driver class: org.apache.flink.table.jdbc.FlinkDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Flink\flink-sql-jdbc-driver-bundle-1.19.3.jar
    • Host: MyHostName
    • TCP port: 8083
    • User name:
    • Password:
    ApacheFlinkDSN
    optional for Apache Flink
    Find full details in the Apache Flink Connector authentication reference.
    Jump to troubleshooter
    ApacheFlinkDSN
    SHOW TABLES
    SHOW TABLES
Connect to Apache Flink data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheFlinkDSN and continue:
    ApacheFlinkDSN
    ApacheFlinkDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Flink in a Power BI report:
If you wish to import Apache Flink data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheFlinkDSN
SHOW TABLES
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Flink ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheFlinkDSN"}
    dsn=ApacheFlinkDSN
    dsn=ApacheFlinkDSN
    = Odbc.Query("dsn=ApacheFlinkDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Flink data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Flink Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_FLINK_IN_GATEWAY], 'SHOW TABLES')
    DirectQuery option for Power BI (read Apache Flink data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Flink data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Flink
    Query Apache Flink SQL Gateway with JDBC from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheFlinkDSN
    ApacheFlinkDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:flink://[$HostName$]:[$Port$]';ClassName='org.apache.flink.table.jdbc.FlinkDriver';DriverPath='C:\ZappySys\Jdbc\Apache Flink\flink-sql-jdbc-driver-bundle-1.19.3.jar';UserName='';UserPassword='';ConnParams='optional for Apache Flink'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.flink.table.jdbc.FlinkDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Flink driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Flink\flink-sql-jdbc-driver-bundle-1.19.3.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:flink://[$HostName$]:[$Port$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Flink data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Flink data source in the gateway
In this section we will create a data source for Apache Flink in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheFlinkDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Flink ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheFlinkDSN
      ApacheFlinkDSN
      ApacheFlinkDSN
  5. Then set the default database property to ApacheFlinkDSN (the one we used in the Data Gateway):
    ApacheFlinkDSN
    ApacheFlinkDSN
Finally, we are ready to read data from Apache Flink in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Flink data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Flink in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Flink, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
