You can connect to your Hubspot data from Power BI via the high-performance Hubspot ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Hubspot
  • Working with Hubspot data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Hubspot Connector.
Create data source using Hubspot ODBC Driver
To get data from Hubspot using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Hubspot" from the list of Popular Connectors. If "Hubspot" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    HubspotDSN
    Hubspot
    • Configure the authentication in Hubspot.
    Private app (Static Access Token)
    Hubspot authentication
    Private apps allow you to use HubSpot's APIs to access specific data from your HubSpot account. You can authorize what each private app can request or change in your account, which will generate an access token that's unique to your app. [API reference]
    Follow these instructions to create a Private app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
    1. First of all, go to HubSpot portal.
    2. Then click Data Management option on the left and then hit Integrations menu item: Go to integrations in HubSpot
    3. Move on by clicking Private Apps menu item and then click Create a private app button to create one: Create private app to get HubSpot data via REST API
    4. Then continue by following the instructions on HubSpot Docs.
    5. Once you create an app, go to SSIS package or ODBC data source and in Private App authentication set these parameters:
      • For AccessToken field use Access token value from the Private app configuration in HubSpot.
    6. Done! Now you are ready to use HubSpot Connector!
    1. Set Authentication Type to Private app (Static Access Token) [Http]
    HubspotDSN
    Hubspot
    https://api.hubapi.com
    AccessToken Fill-in the parameter...
    Find full details in the Hubspot Connector authentication reference.
    Public app
    In HubSpot, a public app is a type of integration that can be installed on customer accounts or listed on the App Marketplace. It requires authentication via OAuth. Once a user installs your app on their HubSpot account, you’ll be able to make API calls to that account using an OAuth access token. [API reference]
    Follow these instructions to create a Public app in HubSpot and configure HubSpot authentication in SSIS package or ODBC data source:
    1. First of all, if you don't have HubSpot Developer's account, register one.
    2. Go to HubSpot and select your Developer account.
    3. Click Apps on the left hand side and then click Create app button to create a Public app: Create public app to get HubSpot data via REST API
    4. Then continue by following the instructions in HubSpot Docs.
      NOTE: If you don't have a working Redirect URL, you can use https://zappysys.com/oauth (it's safe).
    5. Once you create an app, go to SSIS package or ODBC data source and in Public app authentication set these parameters (use values from your Public app configuration in HubSpot):
      • For ClientId field use Client ID value.
      • For ClientSecret field use Client secret value.
      • For Scope field use Scopes values, e.g.:
        accounting
        tickets
        files
        crm.lists.read
        crm.lists.write
        crm.objects.contacts.read
        crm.objects.contacts.write
        crm.schemas.contacts.read
        crm.objects.custom.read
        crm.objects.custom.write
        crm.schemas.custom.read
        crm.objects.companies.read
        crm.objects.companies.write
        crm.schemas.companies.read
        crm.objects.deals.read
        crm.objects.deals.write
        crm.schemas.deals.read
        crm.objects.quotes.read
        crm.objects.quotes.write
        crm.schemas.quotes.read
        crm.objects.line_items.read
        crm.objects.line_items.write
        crm.schemas.line_items.read
        NOTE: You can use other scopes too, but they must match the scopes defined in your Public app.
      • For ReturnUrl field use one of Redirect URLs.
    6. When you are done with that, click Generate Token button to generate Access and Refresh Tokens.
    7. Done! Now you are ready to use HubSpot Connector!
    1. Set Authentication Type to Public app [OAuth]
    HubspotDSN
    Hubspot
    Public app [OAuth]
    UseCustomApp Fill-in the parameter...
    Scope (Must Match with App Scopes) Fill-in the parameter...
    Client ID
    Client Secret
    ReturnUrl
    Authorization URL (leave blank for default)
    Token URL (leave blank for default)
    Developer API key (Deprecated)
    Deprecated authentication method. Use [Private app] instead. [API reference]
    Using HubSpot API key is deprecated method for authentication. Use Private app authentication instead. If you still need one, then follow these instructions to get HubSpot API key:
    • First of all, if you don't have HubSpot Developer's account, register one.
    • Go to HubSpot and select your Developer account.
    • Click Apps on the left hand side and then click Get HubSpot API key button to get one: Get HubSpot API key
    • When a popup appears, click Show Key button and then hit Copy button to copy API key: Use API key to read HubSpot data via REST API
    • Once copy the API key, go to SSIS package or ODBC data source and use it in API Key authentication configuration:
      • Paste it in ApiKey parameter field.
    • Done! Now you are ready to use HubSpot Connector!
    1. Set Authentication Type to Developer API key (Deprecated) [Http]
    HubspotDSN
    Hubspot
    ApiKey Fill-in the parameter...
    ZappySys API Driver - Hubspot
    Read and write HubSpot data effortlessly. Integrate, manage, and automate contacts, companies, deals, and tickets — almost no coding required.
    HubspotDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Hubspot. Hit OK button to use this query in the next step.
    SELECT * FROM Companies
    -- WHERE Id=123
    Some parameters configured in this window will be passed to the Hubspot API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    HubspotDSN
    -- WHERE Id=123
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Hubspot API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Hubspot servers).
Connect to Hubspot data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose HubspotDSN and continue:
    HubspotDSN
    HubspotDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Hubspot in a Power BI report:
If you wish to import Hubspot data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
HubspotDSN
-- WHERE Id=123
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Hubspot ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=HubspotDSN"}
    dsn=HubspotDSN
    dsn=HubspotDSN
    = Odbc.Query("dsn=HubspotDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Hubspot data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Hubspot Service
    SELECT * FROM OPENQUERY([LS_TO_HUBSPOT_IN_GATEWAY], 'SELECT * FROM Companies -- WHERE Id=123')
    DirectQuery option for Power BI (read Hubspot data example using SQL Server Linked Server and ZappySys Data Gateway)
    -- WHERE Id=123')
  7. Click OK and load the data. Your Hubspot data is now linked live rather than imported.
    HubspotDSN
    HubspotDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://api.hubapi.com;CredentialType=Token;
Hubspot Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Hubspot operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Hubspot data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Hubspot data source in the gateway
In this section we will create a data source for Hubspot in the Data Gateway. Let's follow these steps to accomplish that:
    HubspotDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Hubspot ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      HubspotDSN
      HubspotDSN
      HubspotDSN
  5. Then set the default database property to HubspotDSN (the one we used in the Data Gateway):
    HubspotDSN
    HubspotDSN
Finally, we are ready to read data from Hubspot in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Hubspot data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Hubspot in Power BI and integrate your data — all without writing complex code.
