You can connect to your Apache Derby data from Power BI via the high-performance Apache Derby ODBC Driver (powered by ZappySys JDBC-ODBC Bridge Driver). We'll walk you through the entire setup.
  • Configuring a secure connection to Apache Derby
  • Working with Apache Derby data directly inside Power BI
While this video demonstrates how to connect to Postgres, the core concepts and setup process are exactly the same for Apache Derby.
Download Apache Derby JDBC driver
To connect to Apache Derby, you will have to download JDBC driver for it, which we will use in later steps. Let's perform these little steps right away:
  1. Visit Apache Derby website or MVN Repository.
  3. Download the JDBC drivers, and save them locally.
Create data source using Apache Derby ODBC Driver
To get data from Apache Derby using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
    • Configure the authentication in Apache Derby.
    Client/server
    Apache Derby authentication
    Apache Derby network server from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Start Network Server (default port 1527) or use an existing one.
    2. Create a database user if authentication is on. Lab often uses a simple user/password.
    3. Seed Driver class as ClientDriver (SPI can also load EmbeddedDriver).
    4. After Finish, replace the host (e.g. MyHostName) and database name (e.g. MyDatabase) on the DSN Main UI.
    3. Finally, hit OK button:
    • Connection string: jdbc:derby://[$HostName$]:[$Port$]/[$Database$]
    • Driver class: org.apache.derby.jdbc.ClientDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Derby\derbyclient-10.14.2.0.jar
    • Host: MyHostName
    • TCP port: 1527
    • Database name: MyDatabase
    • User name:
    • Password:
    ApacheDerbyDSN
    optional for Apache Derby
    Find full details in the Apache Derby Connector authentication reference.
    Embedded file
    Apache Derby embedded from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. No server. The database folder is created under C:\ZappySys\Jdbc\Apache Derby.
    2. Use EmbeddedDriver (do not leave class blank -- SPI is ambiguous with the client JAR).
    3. Optional: add ;create=true (already in this URL) the first time.
    • Connection string: jdbc:derby:C:\ZappySys\Jdbc\Apache Derby\mydatabase;create=true
    • Driver class: org.apache.derby.jdbc.EmbeddedDriver
    • JDBC driver file(s): C:\ZappySys\Jdbc\Apache Derby\derby-10.14.2.0.jar
    ApacheDerbyDSN
    In-memory
    Apache Derby in-memory from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools.
    1. Data lasts for this DSN Java process only.
    2. Keep EmbeddedDriver. Use for labs and Excel previews.
    • Connection string: jdbc:derby:memory:[$Database$];create=true
    ApacheDerbyDSN
    Jump to troubleshooter
    ApacheDerbyDSN
    SELECT * FROM "APP"."ORDERS"
Connect to Apache Derby data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose ApacheDerbyDSN and continue:
    ApacheDerbyDSN
    ApacheDerbyDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Apache Derby in a Power BI report:
If you wish to import Apache Derby data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
ApacheDerbyDSN
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Apache Derby ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=ApacheDerbyDSN"}
    dsn=ApacheDerbyDSN
    dsn=ApacheDerbyDSN
    = Odbc.Query("dsn=ApacheDerbyDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Apache Derby data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Apache Derby Service
    SELECT * FROM OPENQUERY([LS_TO_APACHE_DERBY_IN_GATEWAY], 'SELECT * FROM "APP"."ORDERS"')
    DirectQuery option for Power BI (read Apache Derby data example using SQL Server Linked Server and ZappySys Data Gateway)
  7. Click OK and load the data. Your Apache Derby data is now linked live rather than imported.
    ZappySys JDBC Bridge Driver - Apache Derby
    Read and write Apache Derby databases from Power BI, SQL Server Linked Server via ZappySys Data Gateway, Crystal Reports, SSRS, Azure Data Factory, and other ODBC tools -- almost no coding required.
    ApacheDerbyDSN
    ApacheDerbyDSN
    DRIVER={ZappySys JDBC Bridge Driver};JdbcConnectionString='jdbc:derby://[$HostName$]:[$Port$]/[$Database$]';ClassName='org.apache.derby.jdbc.ClientDriver';DriverPath='C:\ZappySys\Jdbc\Apache Derby\derbyclient-10.14.2.0.jar';UserName='';UserPassword='';ConnParams='optional for Apache Derby'
  2. Open DBeaver.
  5. Configure the connection settings by entering the Driver Name and Class Name (org.apache.derby.jdbc.ClientDriver):
  6. Go to the Libraries tab, click Add File, and select your Apache Derby driver library file(s), e.g. C:\ZappySys\Jdbc\Apache Derby\derbyclient-10.14.2.0.jar:
    JAR library added
    Add new property
    Set property value
    Select custom JDBC driver
  3. Enter your JDBC URL (e.g. jdbc:derby://[$HostName$]:[$Port$]/[$Database$]), click Test Connection to verify it works, and then click Finish:
    Confirm connection success
SUCCESS
  • Reason:
  • Action:
FAILURE
  • Reason:
  • Action:
Chat with an Expert
Frequent issues and solutions
In some situations, you may need to provide Apache Derby data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Apache Derby data source in the gateway
In this section we will create a data source for Apache Derby in the Data Gateway. Let's follow these steps to accomplish that:
    ApacheDerbyDSN
  4. When the ZappySys JDBC Bridge Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Apache Derby ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      ApacheDerbyDSN
      ApacheDerbyDSN
      ApacheDerbyDSN
  5. Then set the default database property to ApacheDerbyDSN (the one we used in the Data Gateway):
    ApacheDerbyDSN
    ApacheDerbyDSN
Finally, we are ready to read data from Apache Derby in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Apache Derby data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Apache Derby in Power BI and integrate your data — all without writing complex code. It's worth noting that ZappySys JDBC Bridge Driver allows you to connect not only to Apache Derby, but to any Java application that supports JDBC (just use a different JDBC driver and configure it appropriately).
