You can connect to your Zoho CRM data from Power BI via the high-performance Zoho CRM ODBC Driver. We'll walk you through the entire setup.
- Configuring a secure connection to Zoho CRM
- Working with Zoho CRM data directly inside Power BI
To get data from Zoho CRM using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
When the Configuration window appears give your data source a name if you haven't done that already, then select "Zoho CRM" from the list of Popular Connectors. If "Zoho CRM" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
ZohoCrmDSNZoho CRM
- Configure the authentication in Zoho CRM.
Zoho CRM authentication
- Click Add Client link
- Click CREATE.
ZohoCrmDSNZoho CRMOAuth [OAuth]https://www.zohoapis.com/crm/[$Version$]Optional Parameters ClientId ClientSecret Permissions ZohoCRM.settings.all ZohoCRM.modules.all ZohoCRM.coql.READ AccountUrl https://accounts.zoho.com RedirectUrl https://zappysys.com/oauth API Version v2 RetryMode RetryWhenStatusCodeMatch RetryStatusCodeList 429 RetryCountMax 5 RetryMultiplyWaitTime True
Find full details in the Zoho CRM Connector authentication reference. -
ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSN
Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Zoho CRM. Hit OK button to use this query in the next step.
SELECT * from Accounts
Some parameters configured in this window will be passed to the Zoho CRM API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful datamuch faster . -
ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSNSELECT * from Accounts
You can also access data quickly from the tables dropdown by selecting <Select table>.AWHEREclause,LIMITkeyword will be performed on the client side, meaning that thewhole result set will be retrieved from the Zoho CRM API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Zoho CRM servers). -
Connect to Zoho CRM data in Power BI
Another window opens and asks to select a Data Source we already created. Choose ZohoCrmDSN and continue:
ZohoCrmDSN
ZohoCrmDSN
Finally, finally, read extracted data from Zoho CRM in a Power BI report:
If you wish to import Zoho CRM data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Zoho CRM ODBC data source:
ODBC{"connectionstring":"dsn=ZohoCrmDSN"}
dsn=ZohoCrmDSN
dsn=ZohoCrmDSN
= Odbc.Query("dsn=ZohoCrmDSN", "SELECT ProductID, ProductName, UnitPrice, UnitsInStock FROM Products WHERE UnitPrice > " & Text.From(MyParameter) & " ORDER BY UnitPrice")
By default, Power BI imports Zoho CRM data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
OPENQUERYsyntax below (replace[LINKED_SERVER_NAME]with your actual Linked Server name):SELECT * FROM OPENQUERY([LS_TO_ZOHO_CRM_IN_GATEWAY], 'SELECT * from Accounts')
SELECT * FROM OPENQUERY([LS_TO_ZOHO_CRM_IN_GATEWAY], 'SELECT * from Accounts') - Click OK and load the data. Your Zoho CRM data is now linked live rather than imported.
ZohoCrmDSNDRIVER={ZappySys API Driver};ServiceUrl=https://www.zohoapis.com/crm/[$Version$];Provider=Custom;OAuthVersion=OAuth2;ScopeSeparator={space};ReturnUrl=[$RedirectUrl$];ExtraAttributesForAuthRequest=access_type=offline&prompt=consent;AuthUrl=[$AccountUrl$]/oauth/v2/auth;TokenUrl=[$AccountUrl$]/oauth/v2/token;ClientId=[$ClientId$];ClientSecret=[$ClientSecret$];Scope=[$Permissions$];ExpiresInAttribute=expires_in_sec;
Zoho CRM Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Zoho CRM operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
- Read Data (Direct COQL Query - Auto Paging)
- Read Data (COQL Query Builder)
- List Modules
- List Territories
- List Module Settings
- List Tags
- Gets record count for specific tag for module
- Add / Update Tags for records
- List Module Fields
- List Views
- Read [Dynamic Endpoint]
- Read [Dynamic Endpoint] (Use this for fewer than 50 Fields in v3+)
- Search [Dynamic Endpoint]
- Delete [Dynamic Endpoint]
- Insert [Dynamic Endpoint]
- Update [Dynamic Endpoint]
- Upsert [Dynamic Endpoint] (Update or Insert)
In some situations, you may need to provide Zoho CRM data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Zoho CRM data source in the gateway
In this section we will create a data source for Zoho CRM in the Data Gateway. Let's follow these steps to accomplish that:
ZohoCrmDSNZappySys API Driver
When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Zoho CRM ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
ZohoCrmDSNZappySys API Driver - Configuration [Version: 2.0.1.10418]ZappySys API Driver - Zoho CRMRead and write Zoho CRM data effortlessly. Integrate, manage, and automate accounts, leads, contacts, and deals — almost no coding required.ZohoCrmDSN
ZohoCrmDSN(the one we used in the Data Gateway):ZohoCrmDSNZohoCrmDSN
Finally, we are ready to read data from Zoho CRM in Power BI via the Data Gateway. Follow these final steps:
Now you can connect to Zoho CRM data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Zoho CRM in Power BI and integrate your data — all without writing complex code.
