You can connect to your Google BigQuery data from Power BI via the high-performance Google BigQuery ODBC Driver. We'll walk you through the entire setup.
  • Configuring a secure connection to Google BigQuery
  • Working with Google BigQuery data directly inside Power BI
While this video uses the OData Connector as an example, the core concepts and setup process are exactly the same for the Google BigQuery Connector.
Create data source using Google BigQuery ODBC Driver
To get data from Google BigQuery using Power BI, we first need to create an ODBC data source. We will later read this data in Power BI. Perform these steps:
  4. When the Configuration window appears give your data source a name if you haven't done that already, then select "Google BigQuery" from the list of Popular Connectors. If "Google BigQuery" is not present in the list, then click "Search Online" and download it. Then set the path to the location where you downloaded it. Finally, click Continue >> to proceed with configuring the DSN:
    GoogleBigqueryDSN
    Google BigQuery
    • Configure the authentication in Google BigQuery.
    User Account
    Google BigQuery authentication
    User accounts represent a developer, administrator, or any other person who interacts with Google APIs and services. User accounts are managed as Google Accounts, either with Google Workspace or Cloud Identity. They can also be user accounts that are managed by a third-party identity provider and federated with Workforce Identity Federation. [API reference]
    Follow these steps on how to create Client Credentials (User Account principle) to authenticate and access BigQuery API in SSIS package or ODBC data source:
    WARNING: If you are planning to automate processes, we recommend that you use a Service Account authentication method. In case, you still need to use User Account, then make sure you use a system/generic account (e.g. automation@my-company.com). When you use a personal account which is tied to a specific employee profile and that employee leaves the company, the token may become invalid and any automated processes using that token will start to fail.
    Step-1: Create project
    This step is optional, if you already have a project in Google Cloud and can use it. However, if you don't, proceed with these simple steps to create one:
    1. First of all, go to Google API Console.
    2. Then click Select a project button and then click NEW PROJECT button:
      Start creating a new project in Google Cloud
    3. Name your project and click CREATE button:
      Create a new project in Google Cloud
    4. Wait until the project is created:
      Wait until project is created in Google Cloud
    5. Done! Let's proceed to the next step.
    Step-2: Enable Google Cloud APIs
    In this step we will enable BigQuery API and Cloud Resource Manager API:
    1. Select your project on the top bar:
      Select project in Google Cloud
    2. Then click the "hamburger" icon on the top left and access APIs & Services:
      Access APIs and services in Google Cloud
    3. Now let's enable several APIs by clicking ENABLE APIS AND SERVICES button:
      Enable API for project in Google Cloud
    4. In the search bar search for bigquery api and then locate and select BigQuery API:
      Search for API in Google Cloud
    5. If BigQuery API is not enabled, enable it:
      Enable Google BigQuery API
    6. Then repeat the step and enable Cloud Resource Manager API as well:
      Enable Cloud Resource Manager API
    7. Done! Let's proceed to the next step.
    Step-3: Create OAuth application
    1. First of all, click the "hamburger" icon on the top left and then hit VIEW ALL PRODUCTS:
      View all products in Google Cloud
    2. Then access Google Auth Platform to start creating an OAuth application:
      Open Google Auth Platform in Google Cloud
    3. Start by pressing GET STARTED button:
      Start creating an app in Google Cloud
    4. Next, continue by filling in App name and User support email fields:
      Fill app info in Google Cloud
    5. Choose Internal option, if it's enabled, otherwise select External:
      Choose app audience in Google Cloud
    6. Optional step if you used Internal option in the previous step. Nevertheless, if you had to use External option, then click ADD USERS to add a user:
      Add test user in Google Cloud app
    7. Then add your contact Email address:
      Enter app contact info in Google Cloud
    8. Finally, check the checkbox and click CREATE button:
      Create app in Google Cloud
    9. Done! Let's create Client Credentials in the next step.
    Step-4: Create Client Credentials
    1. In Google Auth Platform, select Clients menu item and click CREATE CLIENT button:
      Start creating app client in Google Cloud
    2. Choose Desktop app as Application type and name your credentials:
      Create OAuth app client in Google Cloud
    3. Continue by opening the created credentials:
      View app client credentials in Google Cloud
    4. Finally, copy Client ID and Client secret for the later step:
      Use client ID and secret to read Google REST API data
    5. Done! We have all the data needed for authentication, let's proceed to the last step!
    Step-5: Configure connection
    1. Now go to SSIS package or ODBC data source and use previously copied values in User Account authentication configuration:
      • In the ClientId field paste the Client ID value.
      • In the ClientSecret field paste the Client secret value.
    2. Press Generate Token button to generate Access and Refresh Tokens.
    3. Then choose ProjectId from the drop down menu.
    4. Continue by choosing DatasetId from the drop down menu.
    5. Finally, click Test Connection to confirm the connection is working.
    6. Done! Now you are ready to use Google BigQuery Connector!
    1. Set Authentication Type to User Account [OAuth]
    GoogleBigqueryDSN
    Google BigQuery
    https://www.googleapis.com/bigquery/v2
    UseCustomApp Fill-in the parameter...
    ProjectId (Choose after [Generate Token] clicked) Fill-in the parameter...
    DatasetId (Choose after [Generate Token] clicked and ProjectId selected) Fill-in the parameter...
    ClientId
    ClientSecret
    Scope https://www.googleapis.com/auth/bigquery https://www.googleapis.com/auth/bigquery.insertdata https://www.googleapis.com/auth/cloud-platform https://www.googleapis.com/auth/cloud-platform.read-only https://www.googleapis.com/auth/devstorage.full_control https://www.googleapis.com/auth/devstorage.read_only https://www.googleapis.com/auth/devstorage.read_write
    RetryStatusCodeList 429|503
    Job Location
    Redirect URL (Only for Web App)
    Find full details in the Google BigQuery Connector authentication reference.
    Service Account (Using *.json OR *.p12 key file)
    Service accounts are accounts that do not represent a human user. They provide a way to manage authentication and authorization when a human is not directly involved, such as when an application needs to access Google Cloud resources. Service accounts are managed by IAM. [API reference]
    Follow these steps on how to create Service Account to authenticate and access BigQuery API in SSIS package or ODBC data source:
    7. Done! Let's proceed to the next step and create a service account.
    Step-3: Create Service Account
    Use the steps below to create a Service Account in Google Cloud:
    1. First of all, go to IAM & Admin in Google Cloud console:
      Access IAM & Admin in Google Cloud
    2. Once you do that, click Service Accounts on the left side and click CREATE SERVICE ACCOUNT button:
      Start creating service account in Google Cloud
    3. Then name your service account and click CREATE AND CONTINUE button:
      Create service account in Google Cloud
    4. Continue by clicking Select a role dropdown and start granting service account BigQuery Admin and Project Viewer roles:
      Start granting service account project roles in Google Cloud
    5. Find BigQuery group on the left and then click on BigQuery Admin role on the right:
      Grant service account BigQuery Admin role
    6. Then click ADD ANOTHER ROLE button, find Project group and select Viewer role:
      Grant service account project viewer role
    7. Finish adding roles by clicking CONTINUE button:
      Finish granting service account project roles in Google Cloud
      You can always add or modify permissions later in IAM & Admin.
    8. Finally, in the last step, just click button DONE:
      Finish configuring service account in Google Cloud
    9. Done! We are ready to add a Key to this service account in the next step.
    Step-4: Add Key to Service Account
    We are ready to add a Key (JSON or P12 key file) to the created Service Account:
    1. In Service Accounts open newly created service account:
      Open service account in Google Cloud
    2. Next, copy email address of your service account for the later step:
      Copy service account email address in Google Cloud
    3. Continue by selecting KEYS tab, then press ADD KEY dropdown, and click Create new key menu item:
      Start creating key for service account in Google Cloud
    4. Finally, select JSON (Engine v19+) or P12 option and hit CREATE button:
      Create JSON or P12 key for service account in Google Cloud
    5. Key file downloads into your machine. We have all the data needed for authentication, let's proceed to the last step!
    1. Now go to SSIS package or ODBC data source and configure these fields in Service Account authentication configuration:
      • In the Service Account Email field paste the service account Email address value you copied in the previous step.
      • In the Service Account Private Key Path (i.e. *.json OR *.p12) field use downloaded certificate's file path.
    2. Done! Now you are ready to use Google BigQuery Connector!
    1. Set Authentication Type to Service Account (Using *.json OR *.p12 key file) [OAuth]
    GoogleBigqueryDSN
    Google BigQuery
    Service Account Email Fill-in the parameter...
    Service Account Private Key Path (i.e. *.json OR *.p12) Fill-in the parameter...
    ProjectId Fill-in the parameter...
    DatasetId (Choose after ProjectId) Fill-in the parameter...
    Job Location
    Impersonate As (Enter Email Id)
    ZappySys API Driver - Google BigQuery
    Read and write Google BigQuery data effortlessly. Query, integrate, and manage datasets, tables, and jobs — almost no coding required.
    GoogleBigqueryDSN
  7. Start by selecting the Table or Endpoint you are interested in and then configure the parameters. This will generate a query that we will use in Power BI to retrieve data from Google BigQuery. Hit OK button to use this query in the next step.
    #DirectSQL
    SELECT *
    FROM bigquery-public-data.samples.wikipedia
    LIMIT 1000
    Some parameters configured in this window will be passed to the Google BigQuery API, e.g. filtering parameters. It means that filtering will be done on the server side (instead of the client side), enabling you to get only the meaningful data much faster.
    GoogleBigqueryDSN
    #DirectSQL
    SELECT *
    LIMIT 1000
    A WHERE clause, LIMIT keyword will be performed on the client side, meaning that the whole result set will be retrieved from the Google BigQuery API first, and only then the filtering will be applied to the data. If possible, it is recommended to use parameters in Query Builder to filter the data on the server side (in Google BigQuery servers).
Connect to Google BigQuery data in Power BI
    Power Bi Get Data
    Power Bi ODBC Get Data
  3. Another window opens and asks to select a Data Source we already created. Choose GoogleBigqueryDSN and continue:
    GoogleBigqueryDSN
    GoogleBigqueryDSN
    Power Bi DSN Authentication
    Power Bi Load DSN Table Data
  6. Finally, finally, read extracted data from Google BigQuery in a Power BI report:
If you wish to import Google BigQuery data from SQL query rather than a table then you can use advanced options during import steps (as below). After selecting DSN you can click on advanced options to see SQL Query editor.
GoogleBigqueryDSN
#DirectSQL
SELECT *
LIMIT 1000
Power BI allows you to refresh semantic models (previously known as "datasets") that are based on data sources residing on-premises. This is achieved using the Microsoft On-premises data gateway. It acts as a secure bridge between Power BI cloud services and your local Google BigQuery ODBC data source:
Standard mode
  • Starts automatically
Personal mode
    • Go back to Power BI portal
    • Check firewall settings
    ODBC{"connectionstring":"dsn=GoogleBigqueryDSN"}
    = Odbc.Query("dsn=GoogleBigqueryDSN",
                             FROM Products
                             ORDER BY UnitPrice")
By default, Power BI imports Google BigQuery data into its internal cache. However, if you require real-time data, you can use the DirectQuery mode.
Architecture diagram: Power BI (DirectQuery) connected to SQL Server, bridging to ZappySys Data Gateway via Linked Server, and finally fetching data from Google BigQuery Service
    SELECT * FROM OPENQUERY([LS_TO_GOOGLE_BIGQUERY_IN_GATEWAY], '#DirectSQL SELECT * FROM bigquery-public-data.samples.wikipedia LIMIT 1000')
    DirectQuery option for Power BI (read Google BigQuery data example using SQL Server Linked Server and ZappySys Data Gateway)
    SELECT *
    LIMIT 1000')
  7. Click OK and load the data. Your Google BigQuery data is now linked live rather than imported.
    GoogleBigqueryDSN
    GoogleBigqueryDSN
    DRIVER={ZappySys API Driver};ServiceUrl=https://www.googleapis.com/bigquery/v2;Provider=GoogleBigQuery;
Google BigQuery Connector actions
Got a specific use case in mind? We've mapped out exactly how to perform a variety of essential Google BigQuery operations directly in Power BI, so you don't have to figure out the setup from scratch. Check out the step-by-step guides below:
In some situations, you may need to provide Google BigQuery data access to multiple users or services. Configuring the data source on a Data Gateway creates a single, centralized connection point for this purpose.
Create Google BigQuery data source in the gateway
In this section we will create a data source for Google BigQuery in the Data Gateway. Let's follow these steps to accomplish that:
    GoogleBigqueryDSN
  4. When the ZappySys API Driver configuration window opens, go back to ODBC Data Source Administrator where you already have the Google BigQuery ODBC data source created and configured, and follow these steps on how to Import data source configuration into the Gateway:
      GoogleBigqueryDSN
      GoogleBigqueryDSN
      GoogleBigqueryDSN
  5. Then set the default database property to GoogleBigqueryDSN (the one we used in the Data Gateway):
    GoogleBigqueryDSN
    GoogleBigqueryDSN
Finally, we are ready to read data from Google BigQuery in Power BI via the Data Gateway. Follow these final steps:
  1. Go back to Power BI.
    Power Bi Get Data
    • Hit the Connect button
  7. That's it!
Now you can connect to Google BigQuery data in Power BI via the ZappySys Data Gateway.
In this guide, we demonstrated how to connect to Google BigQuery in Power BI and integrate your data — all without writing complex code.
